Match's Mods: The "Woot-Lite" 2D Magclone (part 1)
34 posts / 0 new
Match
Match's picture
Last seen: 3 years 11 months ago
Gentlemen,
Today we'll be looking at a very inexpensive 2D LED maglite-esque torch that I'll affectionately be calling the Woot-lite.  This nickname comes from the cheap source for these lights (Woot.Com) and also from the fact that it's real name, i.e. "LED 3-Watt CREE 120Lumen Flashlight" is rather cumbersome. It was originally discussed here, and then again here. While the first link shows the original woot deal, this light can be purchased all day long for ~$10 shipped at the second link.
  *** 4 reasons why this light should be on your radar ***
1.) A full size 2D torch makes a great car/house light...and a much better hammer than that itty-bitty p60 host.
2.) At $10 shipped, it's a fraction of the cost of a maglite...Same great taste, but less filling!
3.) Outstanding thrower! Decent spill. Good output and great runtime on cheap alk's.
4.) This light is silly-easy to upgrade!
First a quick overview of the stock torch:
Features
Video FeaturesBright 3-Watt Cree LED (Q3)
Video FeaturesHard Anodized Aluminum Case
Video FeaturesUp to 120 Lumens (approximate max)
Video FeaturesRubberized Push On/Off Button
Video FeaturesScrew On/Off End Cap for easy battery changes
Video FeaturesEach unit uses 2 “D” Batteries not included
Tech Specs
Tech SpecsMax output: 120 Lumens
Tech SpecsProduct Dimensions: (each ) 9.5” L x 2” D
Tech SpecsProduct Weight: without batteries – 0.65lbs / with batteries – 1.30lbs
Tech Specs
Body Color: Matte Black
Although it bears a slight resemblence to a 2D maglite, it really isn't a clone as none of the main parts are interchangeable. Speaking of parts, let's take a look at the what we have to work with here:
Points of interest that you should be aware of:
- Pill is thick and huge!  Only ruined by the manufacturer cutting corners and drilling all the way through.
- Pill will accept 20mm star and 18mm driver.
- All the opaque plastic pieces above make up the switch assembly (reverse clicky switch).
- The reflector is plastic, along with the lens which measures in at 40mm.
  Disassembly of the torch was a straight forward affair.  Of the three I got, one of the heads was glued on, which added an extra step and a handful of curse-words to the process. Let's take a closer look at that pill:
So... where to start with modding this?  This light offers a lot of possibilities, but in the interest of keeping it simple, we'll start off with (hence the part 1) an easy one that's free! Yup, total price is zero, ziltch, nadda...
  Let's take a closer look at that driver, since that's where the magic will happen:
Lacking Foy's macro skills, this is the all I can offer (I have noticed that 3 vodka martinis help make the image look almost normal). Thankfully the picture is clear enough to show what needs to be done. Notice the far right resistor (R5)? That's what we'll be modding:
**The only thing we're going to do is jumper it out.  Easiest way to do that is via a big solder blob on top of it, effectively taking it out of the circuit. **
 And that's it!  This is probably the easiest mod I've done to date. Ah, but is it effective you ask? (Go on...ask it!)  Barring any EOTWAWKI predictions, numbers don't lie....and here's the numbers:
             Stock    Modified
Lumens    99.6     149.2
Lux@1m   18,200  26,800
Tailcap A   980ma  2.1a
Emitter A  470ma  800ma
Wow!  For a small hit to efficiency we get nearly a 50% increase across the board on lumen and lux output! Considering it's running off of 2D batteries, runtime still won't be an issue. Guys, for a cheap boost driver this is huge.  It also maintained those numbers off of 2xAA's as well.
  Remember, these numbers are still on the stock Q3 emitter, so a simple swap here to an R2 or XP-G would see even greater gains.  For part 2 I have something slightly different in mind though, and here's a couple of teaser pics of the mod I'll be making to the pill:
Summary for Part 1.
 Even in stock form, this is a good solid light at a cheap price.  Adding 5min worth of soldering time, and it gets even better.  Beyond that, there are a lot of future options to explore... As soon as a few little yellow envelopes show up, I'll finish up part 2 below. I'lll also try and get some beamshots up later on this evening. Thanks for reading.
-Match
Edited by: sb56637 on 08/26/2014 - 17:29
Match
Match's picture
Reserved for Part 2
arenat
Last seen: 9 months 5 hours ago
Very nice as usual, just watch out with the XP-G or XP-E and that driver two cells. With the DX's boost modded as you did, not even as drastic because only added one 220 miliOhm in parallel totalling around 80 ... first XP-G got shorted , the XP-E just was open.
After a lot of curse did what should be did at first, puting a 3.3 Ohm as a load the measure was 3.9 V , 1,2 A  ,not much current but obviously the  V forward was to much...Cree say 3.75 V max
JohnnyMac
JohnnyMac's picture
Last seen: 2 years 4 months ago
Hey, Match, what is the outside diameter of that reflector?
Match
Match's picture
~40mm, same as the lens.  I found that DX sells a glass lens this size, of which I have 10 on order (I have never cared for plastic lens's).
rzezniq
Last seen: 7 years 5 months ago
I smell 3A+ xml :).
Piers
Last seen: 11 months 1 week ago
There you go again with that shiny copper porn Silly
Match
Match's picture
Hehe...yup.  I love the look of copper, and wish it was used more.  Unfortunately this copper slug will be hidden in the light.  Glad it's not just me who likes it Smile
Boaz
Boaz's picture
Last seen: 8 hours 17 min ago
This a mod even I can do ...Tongue out
EDIT: this is a mod I DID do ... A little piece of wire ,a little solder .. piece of cake ..
What's next ..
i'm hunting a piece of copper to fill the hole
agenthex
agenthex's picture
Last seen: 6 years 4 months ago
I got one of these and it's just as bright on a couple LSD AA's as an MRV on high. Very similar reflector frontal area. Tint is pretty white and high temp.
Really good deal if you want a thrower that runs off low voltage batteries.
Reading this makes you smarter: http://lesswrong.com/
Match
Match's picture
Yep. One of the big reasons I got these.   They'll make excellent gifts to folks who'd rather not mess with li-ion or nimh.
Congrats on the successful mod, Boaz!
sb56637
sb56637's picture
Last seen: 4 hours 28 min ago
Looking good Match! Simple and innovative as usual. Great job with these novel ideas for mods! Frontpage'd and Sticky'd.
Boaz
Boaz's picture
the trick is always  tinning and lots o flux ..  and having friends who work on electronics for a living (back up)
This light weighs almost a pound and a quarter  600 grams  . 4 times heavier than a
solarforce ,18650 and a drop in > 150 grams ..
I'm always  amazed how much D cells weigh.
jamjar
http://deals.woot.com/sellout
3 for $20 deliveried that is to the guys in the US - not so luck for us Aussies Sad
wec777
wec777's picture
Last seen: 8 years 8 months ago
Yeah, and now they're sold out. Gosh, I wonder how that happened? Wink That's alright - I'm a patient guy - I can wait. Cool
okyeung
okyeung's picture
Last seen: 4 years 3 months ago
Hi Match, how is your woot's light part 2 coming along.  We are all waiting for some copper porn.   Laughing  Thanks in advance.
3
achilles
Last seen: 8 years 7 months ago
the apperance is not good
JohnnyMac
JohnnyMac's picture
I'm wondering if a C8 reflector will fit into this baby.
CheapThrills
CheapThrills's picture
Last seen: 19 hours 6 min ago
Oh bugger... I have totally missed the deal on these!
Would have been very, very nice to be left in a car as backup...
Match
Match's picture
Part 2 has been done for awhile now, but I've been (and still am) on vacation so it'll have to wait till I get back. I'd be too tedious to post from my cell phone Smile
okyeung
okyeung's picture
Thanks Match.  Have a nice vacation.Smile
3
Essexman
Last seen: 7 hours 1 min ago
Looking forward to part 2. I love these types of mods!
lburgguy
Last seen: 8 years 4 months ago
I LOVE these flashlights as I ordered 3 from the last time Woot.com had them for sale.  They are no longer on Buy.com, does anyone have any idea where I could get similar lights?  Thanks in advance!
lburgguy
I dropped one of these lights, pretty hard on concrete and it no longer lights.  Any ideas on what to look for?  I looked at the circuit board as best I could and found nothing that looked cracked.  Thanks!
shhh
shhh's picture
Last seen: 1 month 14 hours ago
Instead of looking with your eyes look with a mutimeter. That way you see whats up
lburgguy
I guess what I meant to say is this:  I've scoured over the circuit board and found no cracks, is there a trouble area with cree lights as I am new to them.  Also, is an impact a known killer of cree LEDs?  Like I said, I am new to them.  Yes, a multimeter is a great idea and I will do that come to think of it.
lburgguy
Thanks to this thread, I fixed my light.  I found that the impact had cracked the solder connection of the capacitor.  I did the modification and honestly I'm not seeing an improvement but it could be battery related.  Thanks again!
lburgguy
Could someone verify I did the mod correctly.  I thought I had to jumper out the R5.  When I went to do this R5 came off the circuit board all together.  I soldered a piece of wire in where R5 used to be.  Now that I look at the photo again, I'm seeing something different.
Thanks in advance for any help.
rob799
Last seen: 5 months 19 hours ago
I tried to mod my “Woot-Lite” and now it doesn’t work. Anyone have a better picture of this mod? Also, can anyone recommend a replacement driver and emitter for this flashlight? I also searched for part 2 of Match’s mod, but can’t find it. Thanks!
gords1001
gords1001's picture
Last seen: 1 year 9 months ago
At the top it says the pill takes a 20mm star and 18mm driver, so that’s pretty much any led option (reflector opening allowing) and an 18mm driver (possibly 19mm sanded to fit?).
An example would be an xp-g 20mm star and a 1500ma (1.5a) capable of using two nicad cells (1.2v – 3v). Hope this helps.
raccoon city
raccoon city's picture
Last seen: 9 hours 29 min ago
Welcome to the site, rob799!
Best0270
