I’m looking for a driver for a P60-based light that has multiple modes with a REALLY LOW low and no mode memory.
I’d like to be able to leave the light on all night with the low mode acting as a help-you-find-it-in-the-dark function. Then be able to tap the switch and bump it up to a slightly higher level to use to navigate around the house. Then… cycle power to return it back to the really low mode (so I don’t have to cycle through higher modes to get back to the lowest mode).
NANJG101 or NANJG105C with custom firmware? I have my little evening flashlight with several levels of very low and low, no memory, with diffuser film, as not to disturb my family when I go to bed.
How about the KD driver? It’s got a pretty low low and you can choose to turn the mode memory on or off. You can also choose 4, 6, or 8x 7135 chips. Here’s the link for the 8x7135 driver: http://www.kaidomain.com/product/details.s020073. I ordered and received one a while ago, but haven’t gotten around to testing it or installing it in a light yet, so can’t directly comment. On paper, it looks promising though.
I’ve used it in quite a few lights, still have a few extras kicking around for future builds.
The moonlight fits my needs perfectly. The medium is 30% if I remember correctly and in my opinion is more than would be needed for moving around a dark house, at least on the 3040ma version. I actually find moonlight works well for that task.
I’ve used the KD driver before. It’s a good driver, but I need the lowest setting to be lower - like the glow mode on a Safe-Light. I may have to use the KD driver + a resistor.
