Test/Review of Kinoko IMR18650 2250mAh (Gray)
Official specifications:
  • Brand: Kinoko
  • Nominal Voltage : 3.7V
  • Capacity : 2250mAH
  • Lowest Discharge Voltage : 2.50V
  • Standard Charge : CC/CV ( max. charging rate 1.5A )
  • Cycle Life : > 500 cycles
  • Weight: 55g
  • Length: 65.12
  • Diameter: 18.17
This battery size is obvious popular.
The discharge curves has a very good match and also fairly constant capacity at any current, this looks very good.
Conclusion
The battery uses an unspecified cell, with good performance.
Notes and links
The batteries was supplied by Illuminationsupply for review.
HKJ, I just compared this cell to the Keeppower IMR 2250mAh (Panasonic CGR18650CH) on your comparator and they look identical. Any thoughts?
The usual high standard review, HKJ, thanks. More useful for US members, I expect, as I’ve never seen this brand before.
My guess is that most 2250mAh batteries are based on very few actual cells and the CGR18650CH is one of the few.
