More Aurora SS Lights
100 posts / 0 new
Don
Don's picture
Last seen: 1 year 11 months ago
http://www.dealextreme.com/details.dx/sku.36024
Looks just like the Ultrafire C3 SS. Q5 emitter. 98mm long so probably the same as the later (less good) Ultrafire C3s. Pity it isn't an R2 or an XP-G emitter. Tempted but suspect the Ultrafire I already have is better. DX obviously think I need to have less money.
http://www.dealextreme.com/details.dx/sku.36025
5 mode CR2 light. Probably very nice.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
ky70
Last seen: 5 years 7 months ago
Don, I received this light Saturday and I really, really like it.  I have the a 3.7v RCR2 battery powering the light (blue label ultrafire battery purchased from goinggear.com) and this thing has very nice high on battery (equal to the high of the Romsien RC-A4 from shinningbeam with a Q5 emitter running on a 3.7v RCR123).  I don't know if the high would be less if using a 3.0 CR2 battery but I assume it would be.
I love the compactness of this light as it measures 75mm in length with the head diameter bring 20.5mm (the tail is slightly smaller at 19.5mm in diameter).
The Glow In The Dark clicky is very responsive and well executed.  The clicking action certainly doesn't scream "this is a $14 light" as it is a pleasure to operate.  The modes go in reverse (as it is listed on the website) starting in high, then M, L, Strobe, and finally SOS.  There is proper mode memory, so if you leave the light off for 2 seconds or more and it will turn on in the last mode that was used.
The clicky is also well recessed as it sits 2-3mm inside of the tailcap so tail standing is a breeze.  This assumes the lanyard is removed (which I did immediately as I'm not a wrist lanyard fan).  The light feels great in the hand and has been easy to transport via inside the pocket carry.  The modes are well spaced out as you can clearly see differences between high, medium and low.  The low is a decent low which is slightly brighter than the lowest low achievable on the programmable Akoray k-106 light.
Feel free to ask any specifics questions.  Here are a few pics I just took at my desk (I'm open to instructions on how to properly make pics fit):
Don
Don's picture
There is a hefty difference in output with 3V CR2s. I get 3090 lux on high at 1 metre with an RCR2 and about 550 lux on high with a 3V CR2. Brightness on a primary cell is quite depressing really.
ky70
Thanks for the headsup.  I won't even bother then with the 3v CR2 unless the 3.7v needs to be charged for some reason and isn't ready to go.
One intersting discovery I found was that the head from Quark mini 123 fits this light.  It was really cool to have the Quark mini XP-G R5 out put pumping out of this light and using a clicky.
Don
Don's picture
That does sound like a really nice combination. Lots of light and very small. Doubt it'll run for very long on high - but then what CR2 light does? In my Orb Raws I get 10-12 minutes on high. This combo will totally slaughter them on output and probably runtime too.
sb56637
sb56637's picture
Last seen: 17 hours 2 min ago
Thanks for the tip Don!  The SH-035 does look very tempting, although I already have the C3 SS (98mm version).  I'm actually very impressed with my C3 SS, my only complaint is that it doesn't tailstand perfectly.  I suspect this is a random manufacturing variation.  I'm interested in trying this Aurora SH-035 to see if maybe I get a better tailstander.
sb56637
sb56637's picture
The only difference I can see in the specs compared to the C3 SS is "XPE-WD Q5".  Is this anything significant?  The C3 SS says "Q5-WC".  I still don't understand the LED bin codes very well.
alfreddajero
alfreddajero's picture
Last seen: 1 year 4 months ago
I guess i have to dig out my wallett yet again for the 035.....nice looking light.
With Darkness, there will always be Light.
sb56637
sb56637's picture
I seem to remember that you already have a single-mode C3 SS, Al?  If so, the 5-mode C3 would be a nice addition, and I would hope that this SH-035 would be equally nice.  My C3 SS arrived in perfect working order, no tightening necessary, good memory, nice low mode.
alfreddajero
Yes i do man.......but i have the SS feeling now....blame Don, he's a bad influence. lol
sb56637
sb56637's picture
Ha!  I'm actually indifferent to SS or not, but I'm a sucker for quality mutli-mode AA lights for less than $14.00.  The C3 SS does fit the bill.
I wonder what alloy of stainless steel they use for these lights?  I used to work with designs that called for medical grade SS 17-4 and another alloy that was denominated "394".  They were prohibitively expensive though.
alfreddajero
It really should not matter since steel is stronger then aluminum......
Don
Don's picture
The WC and WD bits are chromaticity bins, Both are cool white, but the WD bin is a slightly lower colour temperature. WC is 6350-7000K, WD is 5700-6350K. On the whole, the WD tint is more desirable than the WC. I find that with blue tinted light I lose depth perception, lower colour temperatures improve this.
http://www.cree.com/products/pdf/XLampXP_B&L.pdf
As far as I know the XP-E is simply an XR-E die in a smaller package, the bit that emits light is identical to the equivalent bin XR-E. The Q5 bin is 107-114 lumens at 350mA no matter what sort of Cree die, an XP-G Q5 would put out the same amount of light as an XR-E Q5 or an XP-C Q5
Don
Don's picture
My guess is that the medical grade alloys need to pass stringent tests on chemical compatibility and corrosion resistance. There is a lot of chloride in the things that medical steel devices contact and cheaper grades of stainless steel can easily be pitted by this over time. When I worked in sewage treatment we used chloride as a rough measure of how much of the load on the works was from organic sources. Medical grade stuff will usually contain over 5% molybdenum for this reason. Not many alloys are expected to resist corrosion when being autoclaved and this would be a big part of material choice. 17-4 is an alloy that can be hardened but is readily machinable before hardening. It is a total pig to machine after hardening.
I'd guess these lights are made from 304 (18% chromium 8% nickel) 316 or 316L (Contains molybdenum for increased corrosion resistance, 316L contains less carbon than 316). 304 is the most common grade of stainless steel and is cheaper than 316. I'm not sure which one is easier to machine as this will be a big part of the reason for material choice.
Most decent stainless steels are only weakly magnetic or are completely non-magnetic. 316L is the usual grade for watch cases. If I still had access to the fun lab toys, I'd soon find out. But since those toys cost more than houses, they don't let random passers-by play with their kit.
Don
Don's picture
I went to DX to get a watch pin remover and some soldering tools when the mouse jumped out of my hand and ordered an Aurora SH-035 all by itself. Then the keyboard joined in and typed my PayPal password all by itself.
Just as well that I don't have to use that excuse to anyone but me.....
alfreddajero
Cool, im still debating on getting it, i still want another 18650 light.  Hmmm i might just get both.  Hey buddy in a PM could you please send me the link of the Aurora 18650 SS light that you have.
sb56637
sb56637's picture
Announcing the immediate availability of: BLFAMFPAS
(Budget Light Forum Administrator Moderated Flashlight Purchase Approval Service)
BudgetLightForum.cz.cc is pleased to announce the immediate availability of Budget Light Forum Administrator Moderated Flashlight Purchase Aproval Service, or BLFAMFPAS in abbreviated form.  This service is being offered by the administrator, who suffers frequently from pangs of conscience knowing that his users' average flashlight spending budget increases on average by 347% during the first three months of BLF usage.  The BLFAMFPAS system involves a special PayPal stoppage/moderation system which permits the administrator to personally approve all flashlight spending, thus resulting in hundreds of dollars of savings for the typical budget flashlight buyer who insists on owning at least one sample of ALL budget lights.  To subscribe to this service, please visit the following link:  <link removed>
Wink
alfreddajero
Now that is just too Funny....lmao.  Good one Mr. Admin.Laughing
Don
Don's picture
:DBig Smile :lol:" class="smiley-class smileysProcessed">:bigsmile:
brted
brted's picture
Last seen: 1 month 4 days ago
I may have to get the AA version. It seems like it would be a good host for a XP-G R5. DX says the runtime is the same on the CR2 and AA version at 35 minutes. Certainly it would be little longer with the AA (or 14500). That's a great price too.Seems like a misprint.
fishinfool
fishinfool's picture
Last seen: 2 years 9 months ago
You guys are just way too funny.  I especially like how Don's mouse and keyboard ordered a new light all on their own. LOL
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
brted
brted's picture
The weirdest thing happened . . . I was ordering some FUJIK thermal adhesive and somehow an Aurora SH-035 was in my cart and I was checked out.
sb56637
sb56637's picture
I may be the next victim... Except I don't have any excuses.  I don't order other small cheap items, I go to DX on purpose to buy flashlights!
Don
Don's picture
That's what like to see! Someone who doesn't need excuses...
Judging by the number of victims to that light we may well be needing BLFAMFPAS. But it could use a snappier name.
Something like, leave your wallet here....
Don
Don's picture
Took ages to train them.....   ;)Wink :wink:" class="smiley-class smileysProcessed">
alfreddajero
Im really glad my wife lets me collect lights........sometimes i forget to tell her and she gets really heated.  lol  All i can say is that im OLD and i forgot.
Don
Don's picture
I find the dog doesn't mind at all, just as long as I don't shine them in her face. Especially the powerful stuff. In fact, as long as I buy dog food and take her out she doesn't care what i buy - even if she would prefer that I bought her more bones.
I just object to picking up bone splinters for days afterwards.
Fizzydog
Don
Don's picture
I'm expecting reviews from each and every one of you...
Mine is currently "Waiting for Supplier" which it'll probably do for a week or two till they get around to posting it.
"In stock" is a very relative term at DX.
What I'd like is something brighter than the Ultrafire equivalent that doesn't get as hot. It's an XP-E instead of an XR-E so it may be a little more efficient.
I will start the testing with the hand torture test on a 14500. I lasted 4 minutes and 5 seconds on high with a 14500 (don't try this at home, my hands are more heat resistant than most) before the pain got too much with the Ultrafire. We'll see how long i can take with the Aurora when it arrives. This is as much a test of pain threshold as efficiency. But if I put the Ultrafire in the other hand I can see which one drops first.
alfreddajero
I have to wait for the cells and my L2M to get here first.......i really do like that light but i have others that i would like more of...18650.
brted
brted's picture
Packaging! It may not be the light, but at least part of my order is packaging.
Don
Don's picture
Get to it DX!!
