Reference: mitro's pile of battery graphs
60 replies [Last post]
mitro
Last seen: 15 hours 6 min ago
Title: ★★★★
I'm looking to compile a lot more data on different cells but I just can't afford to buy every size of every brand. Wink I was hoping I could get some members to send me theirs and then I can test them and send them back. All it would cost is the shipping to me and a week of being w/o your cells.
Just a few things:
1. I REALLY need to keep this within the US.
2. The newer the cells, the better. I'd appreciate if you'd include a note with the cells and let me know the age and approximate number of cycles (I know this is hard sometimes. Just get it in the ballpark)
3. I really prefer to have a pair (or more). I'd do a single cell, but the results would be less significant.
4. For now, I'm only looking for lithium cells. Maybe I'll do NiMH later. (I'd do primaries too, you just won't get them back. Tongue)
Once tested, I will post the results and graphs so we could more accurately compare different brands/sizes.
All tests are done with a West Mountain Radio CBA II that I've used extensively and gotten pretty well dialed in (I have the "pro" sofware which allows you to calibrate volts/amps so that it matches my DMM).
If you are interested, post here or PM me. Also, I'd love to hear requests of cells that the members would like to see tested. Thanks in advance. Smile
mitro
Title: ★★★★
I'll upload an example here
Here's an example:
mitro's Trusfire "Flames" 18650 #1 (click thumbnail to see full-size image)
0.5 Amps - 2538 mAh
1.5 Amps - 2464 mAh
3.0 Amps - 2386 mAh
Not sure exactly how I want to format everything, but I'm sure it will evolve over time.
mitro
Title: ★★★★
Anybody? Well here's one of
Anybody? I can also easily combine old results with new tests so that we can see how different cells compare.
Well here's one of mine again:
mitro's Sanyo 2600 18650's #1 & #2
Received/Age: 06/11 (new)
Source: hkequipment
3 Amps
#1: 2441mAh
#2: 2455mAh
(to be updated with new tests later)
oldbobk
Last seen: 4 hours 51 min ago
Title: ★★★★
maybe if you gave us some
maybe if you gave us some idea of what specific batteries you wanted to test. I'm a noob at this, so all my batteries are nearly-new batteries that old4570 deemed good. as such, my stuff is real generic.
        Bob K
mitro
Title: ★★★★
I want to test whatever
I want to test whatever anybody is using. I'd just like to get an idea of how popular cells stack up against each other in identical tests and how they perform at currents that are often demanded of them.
mitro
Title: ★★★★
Here's an interesting one.
Here's an interesting one. Two pairs of Trustfire "flame" 14500s bought a month and a half apart discharged @ 1.5 amps
mitro's Trustfire"flame" 14500s #1-4
They're clearly different cells. Not a bad thing in THIS case, but it illustrates that you never really know... until you test. Smile
mitro
Title: ★★★★
The discussion of protection
The discussion of protection circuits made me want to see at what voltage I could get it to kick in So I grabbed a Trustfire 18650 blue label "2500" that has been put in my recycle pile and decided to move the test cutoff voltage lower to see where it would cut off. Here's the graph:
Trustfire 18650 blue label "2500" #2
Discharge rate: 3A
3A is too much for this ol' girl. Smile It managed almost 1700 mAh, but hit about 40 degrees C doing it.
The low voltage protection kicked in at 2.05v (±0.05v). I'm not entirely sure what it thinks its protecting at that low of a voltage.Smile
fishinfool
fishinfool's picture
Last seen: 45 min 6 sec ago
Title: ★★★★★
Thanks for all of your hard
Thanks for all of your hard work mitro.
__________________
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion cell going bad."
mitro
Title: ★★★★
fishinfool wrote:Thanks for
Thank you! Sorry, I missed this when you posted it. I've been working too hard. Smile
mitro
Title: ★★★★
AW 2900 18650
mitro's AW "2900" 18650s (Panasonic NCR18650 based)
Number of cells: 3
Purchased: 9/4/2010
Link
Usage: Some cells used more than others. Typically in single cell lights running 1 to 3 Amps on high. Kept topped off most of the time.
Protection: It took a 10A discharge to trip over current. I have not tested the low voltage protection.
All tests were done within the last month.
0.5 Amps
#1: 2878 mAh
#2: 2827 mAh
#3: (Error made in calibration - need re-test)
1.5 Amps
#1: 2735 mAh
#2: 2710 mAh
#3: 2702 mAh
3.0 Amps
#1: 2685 mAh
#2: 2690 mAh
#3: 2676 mAh
5.0 Amps
#1: 2719 mAh
#2: 2705 mAh
#3: 2703 mAh
At 5A the cells heat up to about 40 degrees C by the end of the discharge. I assume the increase in capacity at a greater load is a result of this.
All discharge rates for #1
MF UF test:
3.356 Amps
Using my Manafont Ultrafire T6 XM-L 3-mode P60 dropin in an L2i body I tested the max current the battery would deliver.
AW 2900 #1 vs. Sanyo 2600 #2 @ 3.0 Amps
AW: 2685 mAh
Sanyo: 2455 mAh
Here's an interesting way to look at the comparison of the two cells:
Watt hours to 2.8v (when discharged @ 3A)
Sanyo: 8.732Wh
AW: 8.800Wh
Thats a 0.78% increase in power to 2.8v by going from the 2600 to the 2900.  There's more to it, and at lower discharge rates it would be greater, but mAh doesn't tell the whole story.
mitro
Title: ★★★★
 brted's IMR 10440
 brted's Bestinone.net IMR 10440 #1 & #2 (rated 350mAh)
Thanks for loaning me your cells, Ted!
Number of cells: 2
Purchased: 5/2011
0.5 Amps
#1: 314 mAh
#2: 325 mAh
1.0 Amps
#1: 174 mAh
#2: 150 mAh
1.5 Amps
#1: 77 mAh
#2: 88 mAh
The cells just barely warm during the 1.5A test.
MF UF test:
NOT TESTED
Bestinone.net IMR 10440 vs. AW ICR 10440 @ 1.5 Amps
The AW does  123mAh @ 1.5A (to 2.5v) but, none of the cells handle the load very well. I'm certain that if there is such a thing as an IMR 10440... this ain't it. Smile Better news to come...
mitro
Title: ★★★★
brted's Bestinone.net IMR 14500#1 & #2 (rated 600mAh)
Number of cells: 2
Purchased: 5/2011
0.5 Amps
#1: 722 mAh
#2: 748 mAh
1.5 Amps
#1: 699 mAh
#2: 709 mAh
3.0 Amps
#1: 544 mAh
#2: 548 mAh
MF UF test:
4.028 Amps Smile
Bestinone.net IMR 14500 vs. AW IMR 14500 @ 3.0 Amps
The AW does  609mAh @ 3.0A (to 2.5v). Why is every comparison to an AW? Well.. that's what I mostly have and as much as I'd like to find the same performance for less bucks, I haven't had much luck. These generic IMR 14500s are stacking up quite nicely against the AWs though. And how about 4 Amps when hooked to the Manafont dropin?!? I'd be more than happy to own a bunch of these.
mitro
Title: ★★★★
brted's Bestinone.net IMR 18650 #1 & #2 (rated 1500mAh)
Number of cells: 2
Purchased: 5/2011
0.5 Amps
#1: 1416 mAh
#2: 1427 mAh
1.5 Amps
#1: 1372 mAh
#2: 1372 mAh
3.0 Amps
#1: I lost the graph! Sorry!
#2: 1336 mAh
5.0 Amps
#1: 1319 mAh
#2: 1291 mAh
MF UF test:
3.946 Amps
Bestinone.net IMR 18650 vs. AW IMR 18650 @ 3.0 Amps
The AW does  1370mAh @ 3.0A (to 2.5v). Here i am with the AW again. Smile You have to remember that this is my best run of 6 between two AW IMR cells against a single run of one cell. I'm calling the generic the winner. Why? It has the flatter graph. That extra voltage of the AW's top-end in something like a 980L is only going to heat it up even more. I'm definitely impressed with these and I need to do some more tests (higher and lower amps) on my AWs to compare more thoroughly.
bushytails
Last seen: 39 weeks 6 days ago
Title: ★★
Looking at your numbers, you
Looking at your numbers, you might want to double-check the calibration...  They're too good!
From the tests I've seen other people do, chinese batteries rarely/never have over their rated capacity, but you got 2538 from a 2400 battery, and 748 from a 600...  Unless chinese batteries have suddenly become a much better buy than people thought, something's fishy there.  Smile
I could live without some of my batteries, but I'm completely broke right now (well, not COMPLETELY...  but I have $20 to live on for the next week...) - if you wanted to pay shipping, I could send you four ultrafire 3000mah 18650s, two trustfire 2500mah blue (a couple years old, but only 20 cycles or so), one trustfire 2500mah grey unprotected (sorry, only one - others are soldered into a laptop pack), two really funky (protection supposedly on the positive instead of negative end, and put on at a 15 degree slant on one of them!) no-brand 2200mah ones, two trustfire grey protected 10440s, two trustfire flame 16340s, and two no-brand 16340s.  I could also send a pair of 14500 and a pair of 18650 flames, but you already have those, so probably wouldn't add anything, and the 18650s would be the ones I'd be using while the others were absent.  Hrmm, I also have some (... 200) 1350mah 18650s, that are ~10 years old but have 0 cycles on them, if you wanted to test a couple for a lark...
--Bushytails
brted
brted's picture
Last seen: 22 min 27 sec ago
Title: ★★★★★
It's great to see these
It's great to see these results. Thanks for putting your equipment to good use and doing all the work to run the tests and publish the results. I wasn't able to test them at high currents and I'm amazed to see them hold up. I knew the 14500's were pretty good, but I didn't expect as much from the 18650's. Even though the 18650's are short of their 1500mAh nominal capacity, they still do pretty well under high loads.
I knew the 10440's were pretty pointless, so no surprise there. Even a LCR 10440 doesn't have much capacity and LMR's are always going to be less. Reminds me of the quote someone has over at CPF about Maglite solitaire's: I've seen matches burn brighter and longer.
Great job!
mitro
Title: ★★★★
bushytails wrote:Looking at
EDIT: Nevermind.
mitro
Title: ★★★★
brted wrote:It's great to see
Great job!
Thanks again for letting me put them through their paces. Its a bummer that the 10440s were such dogs but the 14500s and even the 18650s made up for it. The AW 18650 come in under their rated capacity by more than the generics (1600 vs. 1500) So they definitely hold their own.
mitro
Title: ★★★★
Callie's Kustoms 3100mAh 18650
mitro's Callie's Kustoms 18650 #1 & #2 (rated 3100mAh - Panasonic NCR18650A based)
Number of cells: 2
Purchased: 6/2011
0.6 Amps (changed from the usual 0.5A to see if the cell was accurately rated over 3000mAh - also see comments a the bottom of the post)
#1: 3100 mAh
#2: 3094 mAh
(not corrected for measurement error - actual capacity closer to 3045 mAh)
1.5 Amps
#1: 2940 mAh
#2: 2943 mAh
3.0 Amps
#1: 2901 mAh (was undercharged a little - need to re-do)
#2: 2949 mAh
5.0 Amps
Run #1
#1: 2920 mAh
#2: 2939 mAh
Run #2
#1: 2934 mAh
#2: 2959 mAh
These were the first tests run, so it looks like the cells were waking up. Smile
MF UF test:
3.781 Amps
The max current drawn from the cell using the Manafont Ultrafire T6 P60 drop-in in a L2p host.
Low voltage cut-off
2.44v (±0.02v)
The cells were charged up a little (from  fully depleted) and then discharged @ 3A until the protection was tripped.
Callie's Kustoms 3100mAh 18650 vs. AW 2900 18650 and others
coming soon
Comments:
My 0.5/0.6A measurements are coming up a little high. This is something I already know how to fix but it will make comparison to past tests difficult. I'm more concerned with comparing with the cells I've already tested than trying to match other's results. 1.5 Amp and 3.0 Amp results should be pretty close while 5 Amp results may be a little low.
EDIT: For example, the 0.6A tests here are actually drawing 0.59A. the test for #1 lasted 5.166 hours. that means that the result is 51.66 mAh high, so #1 should be 3048 mAh.
sb56637
sb56637's picture
Last seen: 1 hour 54 min ago
Title: ==Administrator==
Looking great Mitro! Thanks a
Looking great Mitro! Thanks a lot for sharing this data with us.
Sticky'd as a reference post.
__________________
mitro
Title: ★★★★
Thank you!
Thank you!
mitro
Title: ★★★★
Bestinone.net 18350s
Nothing new here. This is copied from brted's Generic IMR thread
Here's the 18350s at 3 Amps: (click thumbnail for graph)
 I tested both cells 3 times. I'm not real thrilled with the way #2 is lagging behind and just the consistency in general. Still... they perform acceptably. I just wish I had some of the Ultrafire 18350s to compare them to. The #2 cell is getting more capacity with each run, but I wish I knew what I did to get 915mAh out of #1. Smile Here they are compared to the AW IMR 18350s:
 I took the middle run from each of the generics and here is a single (only) run a pair of the AW IMRs. I like the curve of the AWs a lot better. That would give you higher current reading from the MF UF dropin or the like. The generics look like they're running out of wind at 3A and I bet there would be a big drop in capacity at 5A. But I don't think I'm going to try 5A. They are already getting warm at 3A. I'm doing 1.5A tests now, but I figured that 3A would be most relevant.
 I'm going to try them both with the Manafont Ultrafire dropin and get some readings just to compare further.
EDIT: ok... done Smile
(MAX from turn-on - tested with my Vichy VC99 with leads from my hobby charger)
AW - 4.325 amps
Generic - 3.506 amps
As long as they hold up, I think they are a good buy. I wish I had a larger sample size, but its safe to say that if your light will hold them, they're going to do better than ANY 16340.
mitro
Title: ★★★★
I've added the ability to
I've added the ability to monitor the amperage with my DMM inline with the tester. So I can verify the current draw of the CBA along with the cell voltage (which I'd already been doing). The bad news is that it threw my calibrations all off. So now I have to do partial tests to dial in the voltage correction factor AND the amperage correction factor. Even without calibrating the amperage, it looks like my results are AT WORST accurate within 5%. This should knock it down below 2% for a worst case scenario. Not really sure its worth it now, but I can't easily go back.
Long story short... I had what I thought was a good idea but its going to take even more time and a second DMM to not gain much over my previous setup. This is nothing new nor suprising for me and my endeavors. Smile
2100
Last seen: 1 day 10 hours ago
Title: ★★★★★
Mitro, so you are saying that
Mitro, so you are saying that your tests are all accurate to within 5% at worst?
I'd already be very happy it they were 10% worst case.  I have 3 pairs of generic IMRs coming my way that didn't cost much (18350, 18500 and 14500s), thank you very much for the nice info!  Sealed
mitro
Title: ★★★★
2100 wrote:Mitro, so you are
My measurements are within 5% of being accurate. There's still other factors to consider. Number one being variations in charging (which I do my best to minimize, but are impossible to eliminate.
I'd bet my house that I can get the Ah and Wh within 10%. Typically on a 0.5A I could be off 10 or 15 mA per hour of testing. That's 50-75maH on a 2500maH cell so 2-3%. Shorter tests have less error. My worst test is a 5A, at a possible 50mA per hour of testing (its actually more accurate at only 1% of the discharge current), but it would take a mighty large cell to make that significant since most 5A tests last a fraction of an hour.
It looks like I took a step backwards with my new hook up. Where I used to be able to plug in a pre-tested correction factor for voltage at a given amperage, I have to calibrate every single cell I test at every amperage I plan on testing. I think I'll be going back to the old way. Adding the DMM in line just added uncertainty and more connections.
EDIT: I may have to get a pair of those 18500s for some shorty Skyray action.
mitro
Title: ★★★★
I'm actually to the point
I'm actually to the point where I think too much import is put in the cells we are using. Here's an interesting (or at least I think so) comparison.
This is part of a graph of a constant 3A discharge. Its also using watt-hours instead of amp-hours. The Trustfire (flame - bought from Manafont) puts out 88% of the power of the Panasonic based 3100 when going down to 3.0v. At 3.25 only the Sanyo is out ahead of the pack.
From what I've tested the NANJG 8x7135 driver ACTUALLY cut out above 3V. I'm not sure if its the resistance of the host or what, but I can't get LiFePO4 cells to run on this driver on high at all. These cells have VERY little voltage sag so I know its certainly above 3.0v battery voltage.
A little bit of a tangent, but I just have observed that specifically with the 8x7135 drivers you are wasting a lot of capacity.
Now in the dressed up direct drive lights like the 980L, I think these higher capacity/lower voltage cells are a better choice.
DasFriek
Last seen: 11 weeks 2 days ago
Title: ★★★
Hi mitro, I hope you dont
Hi mitro, I hope you dont mind i borrow your graphs from time to time as comparisons when i post a test i did with my cells. I ALWAYS say its your graph and work that made it and give you credit. I figured as long as i did that you wouldn't mind. But if you do mind pls tell me and ill stop.
I know its to late now, But can you start doing graphs that include "Time" as a factor so i can see when 3.3v is reach at say 30 minutes? I like graphs like that for lights that shut off at 3v and also i always stop my tests at 3v as i dont see any real world use to test a cell down too 2.5v like many people do to try and say a cell does reach its "Stated" capacity.
If it cant do it at 3v its shouldn't be counted below that.  Now i see you do sometimes use 2.8v and 2.5v and thats your choice, But i guess if its a single cell light with direct drive it could have some extra run time giving it some meaning. Thats just my opinion and is no big deal as the real reason is of including the "Time" axis is.
BTW thats for all your hard work and stress on your cells also, I use a Hyperion 720i which is so easy to use. But its a time consuming job since you dont want to walk away from cells being discharged at 5A and try and do something outside. So a Thank you for your work from someone who knows how much it takes to do all this. Let alone the expense.
mitro
Title: ★★★★
I have no problem with you
I have no problem with you using the graphs! That's what there for. Smile
I CAN do graphs with voltage over time and I'd be happy to do one if there's a specific one you'd like to see, but to do it for every test would add quite a bit of work.
You can get a pretty good idea just by looking at the graphs for amp hours. Just look at the approximate amp hours at the target voltage and divide by the test amps (and multiply by 60 if you want minutes).
OR you can just ask me and I can look it up in the data.
DasFriek
Title: ★★★
If there is a specific one id
If there is a specific one id like to see ill ask, Thanks.
Math makes my head hurt :)
mitro
Title: ★★★★
Callie's Kustoms High
Callie's Kustoms High Discharge 18650 #1 (rated 2250mAh - Panasonic CGR18650CH)
Number of cells: 1
Cell Graph:
Capacities discharged to 3.0v:
  • 0.5A: 2310 mAh
  • 1.5A: 2182 mAh
  • 3.0A: 2192 mAh
  • 5.0A: 2095 mAh
  •  10A: 1862 mAh
MF UF test:
4.652 Amps
Low voltage cut-off
N/A
Callie's Kustoms High discharge 18650 vs. others
3A:
  • AW IMR
  • Bestinone.net
  • Sanyo 2600
  • Callie's Kustoms 3100
  • Trustfire Flames 2400
  • Callie's Kustoms HD 2250
Comments:
This is one heck of a cell. You aren't going to come close to its capacity in any other IMR 18650. It destroys the AWs I have and the Bestinone.net cells I tested. It doesn't quite have the capacity of today's LiCo cells, but it holds voltage higher than just about all of them. The only competition are the Sanyo 2600s I have and there's nothing intrinsically safe about them.
They do get plenty hot during a 10A discharge, so I wouldn't use them at that rate, but so do my AWs (Which I actually haven't completed a full discharge @ 10A due to them getting so hot)
The 4.6A draw I got from the MF/UF test is the highest I've ever seen, it even beats an IMR 26650.
xxllmm4
Last seen: 3 weeks 6 days ago
Title: ★★★
(No subject)
Thanks for testing them! I knew they where good but wow! How do you think they feel about them over at CPF? Wink
mitro
Title: ★★★★
xxllmm4 wrote:Thanks for
I'm not sure, but I can't come up with a reason to buy AWs over these. The AWs i have are now almost 2 years old, but even when they were new they didn't live up to what I expected from them (neither did the 16340 or 26500 IMR for that matter). These Panasonics are in a whole 'nother league, so I don't think it should take much convincing over there. They like to spend money. Smile
I'm going to charge and discharge this one like I would any other IMR and see how it is after some use (and likely abuse).
Milestar
Last seen: 38 weeks 6 days ago
Title:
Some buddies here recommended
Some buddies here recommended Mitro to be a condidate to review our new updated WP2 charger, and I have sent a message and waiting for confirmation, can I have the honor?
Miles
mitro
Title: ★★★★
I didn't see your post until
I didn't see your post until now, Miles. But we've already talked in PMs, so its all good. Smile
mitro
Title: ★★★★
CK HD vs. AW IMR
Here is a Callie's Kustoms HD 18650 vs. my 1+ year old AW IMRs. I actually thought they were older than that. Is this a fair comparison? You decide.
I keep reading words like "reliability", "durability" and "long-term" when talking about reasons to buy AWs. So it stands to reason that the AW should be able to hold is own after a year or so. These 9 runs were all done TODAY (8/23/11).
The Cells
AW IMR 18650 #1 & #2
Purchased: From Lighthound 6/18/2010
Usage: Not much. Occasionally would fill in for a LiCo in a 1.4A light and rarely run a ROP Hi. Most of the time they have been stored. Some of that time was fully charged just sitting on the shelf and the rest of the time was stored @ 3.8v in the fridge.The cells have never sat after being discharged and I followed charging guidelines specified by AW, but almost always charged them at or above 1C.
Callie's Kustoms High-Discharge 18650 #1
Purchased: Was given to test by Jordon @ CK - 8/8/2011
Usage: Limited testing. Now I'm starting to use them the way I would any IMR (discharging to 2.5v and charging at 1C+)
Facing off at 3 Amps discharged to 2.5v:
AW IMR #1: 1272 mAh
AW IMR #2: 1338 mAh
CK HD   #1: 2227 mAh (2180 mAh to 3.0v)
(I forgot to put the temp sensor on until the very end)
OK.... how about 5 Amps (to 2.5v):
AW IMR #1: 1219 mAh
AW IMR #2: 1294 mAh
CK HD   #1: 2201 mAh (2127 mAh to 3.0v)
Time to put it all on the line - 10 Amps! (to 2.5v)
AW IMR #1: 81 mAh
AW IMR #2: 103 mAh
CK HD   #1: 2209 mAh (1967 mAh to 3.0v)
I'd call that a K.O.
If anybody would like to test my cells to verify my results, I'd be happy to send them to you, just please don't return the AWs. Smile Likewise, I'd love to test some new AW IMR18650s if anybody wanted to loan them to me. (Unless you are AW, in which case I'm keeping them for repayment of all the underperforming IMRs I've spent hundreds of dollars on.)
Maybe a new pair would hold their voltage better than the CK, but I think that would be tough. There's no guarantee that they are even the same cells underneath. (I know what a CK HD is. Tongue) Even then, they're going to lose in the capacity department by a wide margin.
The only other areas of concern are longevity and safety. My pair of AWs may last forever and not lose any any more capacity, but they don't have enough to begin with. The main concern with the Panasonics is the "unknown" level of safety. Until somebody shows me what it takes to make both cells explode, and that there is a difference, I'm going to treat both the same.
xxllmm4
Title: ★★★
Yikes! Honestly I'm
Yikes! Honestly I'm pretty surprised. I would think the AW's would have the clear advantage at high discharge rates. Honestly I cant help but think the AW cell is damaged to do that poorly at 10A ??
"The main concern with the Panasonics is the "unknown" level of safety. Until somebody shows me what it takes to make both cells explode, and that there is a difference, I'm going to treat both the same."
I'm completely on board with you on this! In fact we are going to be changing some wording on our website so people really understand no battery is safe. I mean really... when I was a child I had it pounded into me about battery not being safe. I think its better to error on the side of safety rather than catch your self on fire or get burnt up with acid.
mitro
Title: ★★★★
xxllmm4 wrote:Yikes! Honestly
I agree, but these cells have never been abused. No dead shorts, no overdischarges. no resting after depleted, and the only times they were depleted was for tests. Also, they readily charge to 4.2v and hold their charge. They also has a relatively normal curve under a decent load (5A).
My only guess could be that regularly charging the cells at higher rates (2C), while within specs according to AW, result in degradation. However, I looked at a graph from a test I did 10 months ago and the curve (another 5A graph) was nearly identical to the ones done today.
BTW, the Panasonic is GAINING capacity. Smile 2200 mAh @ 10A is unbelievable.
old4570
Last seen: 10 hours 48 min ago
Title: ★★★★★
Wow
Very nice mitro , though the demand for a 10A test , I think was a bit of a [ hmmmmm ] unreasonable demand , and I thought it insanely funny when posted on CPF ...
But the fact that the two IMR;s fell on there face and the Panasonic performed well , kind of speaks volumes ...
Now when I see the Enemy post [ yes I think enemy ] , a AW review , must remember to demand a 10A discharge ...
But the whole thread unfortunately deteriorated , with some very silly [ Stupid !!! - who am i kidding ] comments and demands  ...
Thanks mitro ...
__________________
old4570.com
2100
Title: ★★★★★
Think you forgot to charge
Think you forgot to charge the AWs for 10A.
CheapThrills
CheapThrills's picture
Last seen: 9 hours 55 min ago
Title: ★★★★★
Thanks for tests mitro, very
Thanks for tests mitro, very interesting - very entertaining! Smile
Ok, AW´s are old BUT I think you have kept them in better shape than a big deal of users would ever keep.
They seem to perform well on two lower current tests but omg with that last one...
I would have bet my money EVEN on 1yr old AW´s, seriously I´ve had the image of better performance on ridiculous amps...
Panasonic is really gearing up in battery race. Do I remember correctly Panasonic owning Sanyo?
So, they have the NiMh covered pretty damn good I´d say, with Eneloops. Now this. Whew... Shock
mitro
Title: ★★★★
Thank you... and thanks for
Thanks mitro ...
Thank you... and thanks for all the testing you've done.
I did the 10A discharge on the cell because Panasonic says it can. I had already done it once for my initial tests, but its gotten stronger since then. I'm not here to sell CK cells. Jordon was nice enough to give me one to test and if the results were poor, they'd be in the above graphs. I like cells that perform up to, or beyond, expectations. I think we all do. Smile
mitro
Title: ★★★★
2100 wrote:Think you forgot
LOL It looks like that, but I assure you, they were charged to 4.2v.
EDIT: I think I may need to do a 7 or 8 amp discharge to fill in the gap to see where it goes south.
2100
Title: ★★★★★
mitro wrote:2100
mitro wrote:
LOL it looks like that, but I assure you, they were charged to 4.2v
Those guys would cry foul, but i guess if BLFers would want to counter AW, better do another 4.2V discharge @ 10A, and then after that 5A to show that it has not been damaged.  "PROVE BEYOND REASONABLE DOUBT".
It's not a damaged cell, the 1A and 5A mAh results confirm that.
Anyway I am charging HKE's NCR18650A, but i can only do 1A.  (ouch)
mitro
Title: ★★★★
I'm not here to prove
I'm not here to prove anything. If anybody wants my AWs to test they can have them. BUT... they have to test the CK HD too. Smile
old4570
Title: ★★★★★
Well
I think enough people have IMR's , but not everyone has the equipment to test @ 10A , and I think some of the CPF posters were counting on that , almost like a crutch .
I havent checked yet , but I saw mention of getting banned ???   I'll have to check that out ...
Seriously , thank you mitro ,
__________________
old4570.com
mitro
Title: ★★★★
I think I should test the CK
I think I should test the CK @15A Smile
I ran them all at 7.5A today. Everyone have their harnesses fastened? OK... hang on!
WWWWWWHHHHHHEEEEEEEEEEE!!!!! I've never been on a discharge graph rollercoaster before. Smile I assume thatis not good. No... I KNOW that is not good. At 7.5A the AWs are on the edge of having useful capacity, but the temperature of them is getting so high that any cracks/nicks in the wrapper are getting bigger because the wrap is shrinking. So the AWs still work... just not well.
scheven_architect
Last seen: 12 min 16 sec ago
Title: ★★★★
appreciate your effort! Keep
appreciate your effort! Keep it up Cool
__________________
xxllmm4
Title: ★★★
Ok but if you blow it up i'm
Ok but if you blow it up i'm not sending a replacement LOL
brted
brted's picture
Title: ★★★★★
Wow, that's a crazy discharge
Wow, that's a crazy discharge graph. Maybe the battery got a second wind. So at 10A, the test lasts about 12 minutes or so? (for the CK's, looks like the AW's won't make a minute).
mitro
Title: ★★★★
Here you go Ted:Jordon: If I
Here you go Ted (the graph shows voltage/minutes):
Jordon: If I blow myself up and I'm NOT dead... my wife would most likely kill me for being stupid. If I did manage to survive both, then I'd happily buy a couple. LOL
2100
Title: ★★★★★
For kicks, you should try the
For kicks, you should try the BIO IMR 18350 for "comparison".  Like i said, i think they might be better than AW IMR.   IMR 18350 gets around 900mAh, how about 2700mA (3C) and 3600mA (4C) Be careful.    Coz i am going to see if 3 x 18350 works in DD in my SR3800, but will be very careful about the cells temperature. So far the 18500s work with nearly 4 amps and cell temperature is quite ok.  The 18500 have only about 100mAh more capacity than the 18350.
mitro
Title: ★★★★
2100 wrote:For kicks, you
I'll test the BIO @ 4A  and maybe carefully try 5A as well (3A is already done above). I still have to put the spring back on my Skyray or I'd just try it myself (I have 4 BIO IMR 18350s now).
Comment viewing options
Select your preferred way to display the comments and click "Save settings" to activate your changes.
