I was in a HomeDepot near my work place today, and noticed 2 skids full of these Defiant 200 Lumen 3-Pack lights for an in-store sale of only 12 bucks. i grabbed a pack of them since i seen others going off with arm-fulls of these lights, ( maybe for xmas gifts
They are all aluminum, uses 3 AAA cells, (which came with the batteries included with the lights) i noticed the emitters and they looked like they were XP-G2s, but was not sure until i got them home to inspect them closer with a magnifier.
As suspected, thay are XP-G2 emitters, well centered, and with a very nice almost Neutral-White tint, smooth beam, and 3 modes. ( Hi, low, and strobe)
I did a quick tail-cap amp check on the stock batteries included, and got exactly 1 amp on high, and 0.15 amps on Low. ( should have a good run time on low.)
Cool! I can almost read their specs on the packageā¦what do they list for runtime and throw numbers?
On the package they say 200 Lumenrs, 4 hours run time, ( i dont know if that on high or low or strobe) throw distance of 170 meters.
I just went outside, its a clear night, and the throw distance seems to be atleast 170 meters or more on high so it sounds accurate.
Three FLs in one package. GREAT!
:heart_eyes:
I didn't see these yesterday at my HD. I did see the usual seasonal 2 pack of XB-D (or XP-C, or whatever they are) for $9.88 though.
-Garry
Probably the three pack is CA only, but we have them in two packs in the US. At least Home Depot and/or Brinkman are smart enough to keep putting out these lights. They sell like crazy every year and they are a great light for non-flashaholics. I hope they continue to sell like crazy, so maybe they will be in the HD stores for years to come.
I can't make out the SKU on the package. Is it 1000 765 505?
EDIT: They look different then the 2 packs in the US. The tail cap is flat in the US models and I don't think they have xpg2's. They are also rated at 120 lumens on the package in the US.
Definitely different than the US 2-Pack (which is not an XP-G2 or even XP-G).
-Garry
Maybe its in Canada HomeDepots only ?
SKU is 1000 785 505. Here is the wierd thing thoughā¦ i search for that number on HDsā site, and it came up with Arrow T50 staples for that number.
I found antother number on the back near the UPC code, and a search of that got a ā No results Foundā. Maybe these lights are discontinued.
Did the price end in a ā0āā¦ if so they are discontinued. I checked that SKU online at a dozen stores around here and came up blank. Den been hallucinating flashlights again?
I did find the 2 pack of these today, but no 3 pack. The 2pack was only 120lm. Dunno if theyāre the same or not, but they look almost identical.
1000016969
whats the bar code? thats how most products are on homedepot.com, the āskuā is most likely the model number and not the sku
the price was just 12.00 even, so i guess is a discontinued design.
1000016969
Home Depot got some new stuff
those are a bit different in design, i seen them at the store i was in too. they looked like XP-E emitters in the other ones i seen there.
DenBarrettSAR wrote:
SKU is 1000 785 505. Here is the wierd thing though.. i search for that number on HDsā site, and it came up with Arrow T50 staples for that number.
Thank you. It pulls up as a 60watt bulb when I try the inventory tracker for my store. Searched a little. Doesn't seem available in the US. Nice find.
I bought 2 pack of these lights, my Home Depot only got the ones 2/$10. itās Cree XB-D LED but i like the reflector , itās DD and look like 17mm driver could fit in there and some extra room for more 7135 chips
cut the spring at the tail, and loosen the head a little ,add adapter for 18650ā¦ voilaā¦it became 18650 light
it is now slightly brighter than the original, too bad i canāt figure out how to take the lens off( maybe itās glued?), 28mm fresnel lens fit in there.
