Review: TrustFire F15-T6
91 posts / 0 new
agedbriar
Last seen: 9 months 2 weeks ago
3.5A? I hope mine comes more conservative. My electricity bills have been high enough.
JohnnyMac
JohnnyMac's picture
Last seen: 2 years 1 month ago
Interesting...Manafont no longer sells this torch. Sad
agedbriar
JohnnyMac
JohnnyMac's picture
agedbriar wrote:
Seems to be replaced by this one (with smooth reflector):
http://www.manafont.com/product_info.php/lumapower-mrv-xml-t6-3mode-memory-led-flashlight-118650-p-7246
I wonder if it's driven as strongly as the TrustFire. Would be a shame if it was a step down in performance.
agedbriar
Agreed.
My TrustFire F15 should arrive any day now. I hope it won't be one from the Returns shelf.
rizaoztop
Last seen: 6 months 1 day ago
i ordered 10 days ago, what you mean by returns shelf? ones returned due to customer complaints-defected etc?
agedbriar
Yes, that's what I meant, but in reality I believe Manafont to be above such practices.
JohnnyMac
JohnnyMac's picture
I sure hope you get a good example, Boris. I am thrilled with mine. BTW, the hotspot from one meter is roughly 3.5 inches. Sorry it took me so long to get that for you. I forgot all about it.
Johnny
agedbriar
Still on time, thank you Johnny Laughing
s1mp13m4n
s1mp13m4n's picture
Last seen: 10 months 2 weeks ago
I see that Manafont sells the P7 version of this light.  Is that good or bad?  I am considering this light if I can find one.  Smile
Lights seen from the blind side
trooplewis
trooplewis's picture
Last seen: 4 months 18 hours ago
Get the XM-L version.
Rats, finally sold my 2010 509hp Mustang...now I can buy more lights!
Sold the red one too! Now guess what I drive, doing my penance for 500 hp commuters...
http://dreammustang.com/
http://i884.photobucket.com/albums/ac47/Ha
agedbriar
So far my only real miss has been a P7 light with a 27mm wide reflector and 1400mA from battery.
It's like having a 60W bulb dangling from heaven out there in the open. Boring as boring could be.
agedbriar
So I received my F15 today, with one minute nick on the bezel edge as the only visual defect. The huge amount of crud from machining on the rear threads wouldn't be worth mentioning if they at least didn't apply lubricant over it, making it stick.
The replacement C8 SMO reflector I got from Manafont fits perfectly. It's 0.3mm shorter than the original OP, but focuses correctly, without any rings or other artifacts. The bezel ring screws down tight as it should. The beam pattern is nice.
This light was obviously designed with a flat (springless) driver bottom in mind. The tailcap plunger and plunger guide protrude so deep into the battery tube that upon screwing the tailcap over the battery you can feel the plunger spring being tortured. Therefore, I removed the stiff front spring and now all is well.
Depending on battery (mine are all protected), the High current starts somewhere between 3.5 and 3.9A and settles to about 2.9A after a minute. A freshly charged Soshine 2800 tripped at that current surge, making me think for a moment that I had already blown the poor thing.
The working Low mode draws 340mA, so the brightness difference between modes is substantial indeed, unlike with many other lights, where switching between some brightness levels is hardly worth the tap. High is simply impressive.
jacktheclipper
jacktheclipper's picture
Last seen: 7 hours 44 min ago
I have already had to add some solder to the pill on mine , as well as grinding about 1/4 " off the brass piston in the tail cap . Aside from the tint shift I have gotten all too used to with XMLs , and the Psycho Strobe ,  this light was worth what I paid  .
agenthex
agenthex's picture
Last seen: 6 years 2 months ago
The new non-Trustfire version comes with the smooth reflector. I actually wanted an OP, so unlike the other members here, I'm going to find an OP reflector separately somewhere to replace the stock one. Big Smile
Reading this makes you smarter: http://lesswrong.com/
agedbriar
For me, F15 with the replacement C8 SMO reflector is within the right flood for walks.
Anyway, you can order from Manafont an Ultrafire C8 OP reflector, the sister to the C8 SMO that I bought, although the fit in this new combination has not been verified yet.
This is it:
http://www.manafont.com/product_info.php/416mm-aluminum-op-reflector-for-ultrafire-c8-p-6091
BTW, my C8 SMO spare looks perfect on whitewall as well. Seems we are dealing with some wide tolerances here.
Andi
Andi's picture
Last seen: 1 year 1 month ago
THIS OP reflector is better quality, as the original Wink
agenthex
agenthex's picture
Andi, you mean better than the MF one? They look the same to me?
Bob, thanks very much for the offer. I'd take it but don't want to inconvenience you over apparently 4 buck part.
Andi
Andi's picture
r
The left one is the orig. KD C8 (with not really good centered LED), right one is mine with the C8 P7 reflector.
It´s a little bit smoother and hole is bigger (better for playing with focus).
Manafont reflector i mean, it´s the same as the orig. KD C8 OP reflector Wink
agenthex
agenthex's picture
Thanks.  I hope these new MRV (nonTF) have well centered reflector like your F15. The OP will help but even the slight offset on my MF xml dropin w/ SMO drives me crazy, because white walls is all we have to hunt around here. Big Smile
viktori
viktori's picture
Last seen: 3 years 4 months ago
Just for completeness sake, did Foy publish the shootout/comparison somewhere?
This is my flashlight collection.
jacktheclipper
E1320 modded Foy's F-15 ( as he did mine ) and I would also like to know how they now compare .
shoot out
  Shoot Out
 SHOOT OUT !
( this is me chanting )
Edit : I want a mouseover , because Mouseovers Rock
jamesearljonesi...
jamesearljonesisascab's picture
Last seen: 2 days 7 hours ago
I just replaced my led with a t5 from led dna and the v2 kd 3a driver. getting 2.8amps on samsung cells. now if only i can find a replacement tail cap. anyone?
03/04/16
8 lives left
jacktheclipper
I thought I had a tailcap issue with mine and requested and was sent a replacement . However , the fault was a bad driver connection and I never used the extra tailcap .It didn't fit anyway , the threads didn't line up somehow . I'll bet that the guts are the same , though .
Is it the switch you need or the actual tailcap itself ?
jamesearljonesi...
Thanks, i am in need of the whole assembly as it was donated to the stlV2 i sold. who did you contact? Thanks Jack!
03/04/16
8 lives left
jacktheclipper
Manafont ?
They made me send them a picture of the light and the original shipping envelope ...
jamesearljonesi...
Manafont ?
i just checked and MF does'nt hhave them anymore. do you have the cap with internals ? maybe itll fit on mine.
Please lmk
Thanks!
03/04/16
8 lives left
Foy
Foy's picture
Last seen: 4 years 9 months ago
I never did the thrower shootout.  My bad because there was a lot of interest.  Like Jack said, E put a 5-mode/3.5 amp/no-blinky in our F15s.  After I put an SMO in mine, it dethroned the 980L by a nose as my brightest single emitter light.
I've been thinking of doing a round-up of a dozen or so of my better lights and although I do have some screamers, my collection of uberlights can't hope to compare to some of the big spenders around here.
Some lights I do have that I'd like to see compared are:  (not necessarily dedicated throwers)
DRY
Sky Ray
C88 ala E1320
MPP 1 and 2
Skyline 1
M8
M6
980L
F15 ala E1320
P60/3-mode UF XM-L
and . . . one I bet you've not heard of (yet) . . .
Xtar TZ58.
I received today, what appears to be a pre-production sample . . . very odd and quite exciting . . .
Foy
No referral links and nothing embedded . . . ever.
                      &nbsp
viktori
viktori's picture
\o/
So what's the holdup? Smile
Just kidding, we all have our problems and obligations.
I'm looking forward to such a comparison!
That driver, was it custom made, or is there a link for that?
Foy
Foy's picture
E1320 gets them from somewhere.  I think he programs them to whatever maximum amps we ask for . . . not sure.  All I do know is it's awesome.  E knows.
Foy
                      &nbsp
