MTN Electronics: LEDs - Batteries - Lights - Chargers - Hosts - Drivers - Components - 1-Stop-US Source
8370 posts / 0 new
RMM
RMM's picture
Last seen: 3 months 1 day ago
Gj wrote:
So, always starts on white (in group 1)? That's OK, it's on my wish list. (Isn't everything?Money Mouth)
Yep, it always starts on white.  I will make a video to show how the driver works when I get a minute!  Maybe I'll put it in an S3. Cool
Back in stock:
  • 18650-Sized Shrink Tubing
  • Convoy S2 Host
  • Convoy S6 Host
  • Omten 1217 Reverse Clicky Switch
  • Thermally Conductive Silicone Cubes
Mountain Electronics : batteries, Noctigon, and much more! What's new?
RMM
RMM's picture
New:
  • Forward Clicky Switches with Pre-Soldered Spring and PCB - 17mm & 20mm
Back In Stock:
  • A few more Convoy C8 hosts
MRTdiver
MRTdiver's picture
Last seen: 5 years 5 months ago
What lights have reflectors which will fit the MT-G2's?
I was thinking about the Convoy C8 you sell, but I guess I would probably have to drill the reflector hole larger.  Yes?
Did you have to drill your C12 reflector for the huge MT-G2 emitter?
I'm also getting some P7 sized P60 drop-ins.   I expect those to work.
נֵר־לְרַגְלִ֥י דְבָרֶ֑ךָ וְ֝אֹ֗ור לִנְתִיבָתִֽי   (Psa 119:105)
TheGloriousTachikoma
Last seen: 4 years 3 months ago
MRTdiver wrote:
What lights have reflectors which will fit the MT-G2’s?
I’m also getting some P7 sized P60 drop-ins.   I expect those to work.
The MT-G2’s dome barely fits in the Convoy M1’s reflector, which is 9mm, so I think I’d use that as the rule of thumb.
DB Custom
DB Custom's picture
Last seen: 1 day 7 hours ago
In many cases, the centering ring …when removed…leaves the reflector in perfect readiness for the MTG2
RMM
RMM's picture
The Convoy C8 reflector definitely needs to be enlarged for the MT-G2.  The pill is also 16mm vs. 20mm, I used to think that this wouldn't work, but I was shown otherwise by Comfychair (see post #323). You need to grind down the MCPCB and remove some of the solder mask over the trace.  I had to open up the reflector on my XinTD V4 and on my Ultrafire C12 to make the MT-G2 work.  I ground it out at first, now I am using a t-handle reamer which is slower but produces a much nicer finished result.
I haven't looked very closely yet at the M1 reflector, it may work without anything, but I'm not sure yet.  If you order one together with an MT-G2 leave me a note and I'll open it up a bit with my reamer so it will work with the MT-G2.
The Small Sun ZY-T08 doesn't need to be opened up at all to work with the MT-G2.
RMM wrote:
I haven’t looked very closely yet at the M1 reflector, it may work without anything, but I’m not sure yet.
there isn’t room for any kind of centering ring in the M1 reflector, which makes me a little leery as it risks the reflector rubbing against the dome when tightening the bezel down.
DB Custom
DB Custom's picture
TGT, cut the dome off and you won’t have to worry about that! Smile
I sliced one about 1/32” above the die face, then cut off he phosphor that extended beyond the actual dies, works great, somewhat smaller hot spot. Comfy recommened I put silicone grease on the blade to help ease it through the dome, which works quite nicely. I bought a scalpel and blades, but wouldn’t you know I ended up getting 20 blades that are NOT chisel grind! Who woulda thought it’d be difficult to find a chisel ground scalpel blade? Still looking…
I saw someone posted they used a paper clip as a guide, looped it around the dome and pulled against the blade to keep a consistent cut, sliding the blade over the metal clip like a spacer. Sand the paper clip down if it’s too thick. Wink Just don’t pull hard, ya know? Counter the force of the blade.
Yes, this is an MT-G2!
comfychair
comfychair's picture
Last seen: 4 years 3 weeks ago
The dome is 8mm, the 'standard' XML hole is 7mm (corner-to-corner across the square substrate). Some using a nonstandard centering ring have emitter holes of 8mm or 9mm.
MTG2 usually has the best focus when it's farther back from the reflector's inside surface than is typical with other LEDs, so the hole doesn't need to be large enough for the entire square base to fit through.
garrybunk
garrybunk's picture
Last seen: 19 hours 52 min ago
DBCstm wrote:
1
Gorgeous Photo!  Wow!  Think I'm gonna snag a copy of that for wallpaper use if you don't mind.  (Sorry for being off-topic.)
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding Forum
NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
DB Custom
DB Custom's picture
That’s the hybrid reflector in an Solarforce M8. Wish I’d known to be more careful and not cut the surface of the substrate, or at least get em all the same for conformity. Oh well. It works, that’s the main thing! Wink
That one’s downsized to 1600px on the long side, need it bigger?
Haven’t done it like this in a while, hope I’m not messing anything up…
http://www.flickr.com/photos/dbcustom/10964006453/
You should be able to pick from various sizes in flicker, up to 3456px wide.
garrybunk
garrybunk's picture
DBCstm wrote:
That one's downsized to 1600px on the long side, need it bigger? Haven't done it like this in a while, hope I'm not messing anything up... http://www.flickr.com/photos/dbcustom/10964006453/ You should be able to pick from various sizes in flicker, up to 3456px wide.
Thanks!  Nabbed it a little bigger.
-Garry
MRTdiver
MRTdiver's picture
Made another order... seems like back to back purchases.     There's only one Convoy C8 host left Wink
RMM regarding website:  "Switches" and "USB Battery Box" only appear on the Left side pane... so ppl might miss those items assuming that they also appear in the Top drop-down tabs.
There's a couple items that may be hidden to ppl.  If you click the top Components tab you'll find:  storage cases, Zener mod  - but they don't show up in a drop-down list.
Edit:  Not sure which sub category Forward Clicky is under.   I see it under Latest on Homepage (Left pane).  Probably should be with Switches.
re. Protected Sanyo UR14500P:  you say length 53mm.  I measure ~64mm or 2.52'' - checking about 3 cells.   These are long.
Thx
Nice pics DBCstm... I was looking through your Flickr acct.
RMM
RMM's picture
Thanks for the heads up MRT!  I think that sometimes I need a memory expansion for my brain, I can't keep everything straight!  BTW, there are a many more Convoy C8 hosts, etc. on the way.
DB Custom
DB Custom's picture
Mostly all flashlight related on there, lol.
Gj
Gj's picture
Last seen: 1 week 4 days ago
You missed a sales opportunity, Richard. If you use the multi-color LED and driver but swap the green and blue leads, the police strobe becomes Santa strobe. Laughing
drdanke
drdanke's picture
Last seen: 1 year 6 months ago
Any chance of you stocking 380mA AMC7135 chips in the future?
I’m planning a Convoy M1 project using a Noctigon mounted MT-G2, with a zener modded Qlite @ 4.56A with 12× 380mA AMC7135 (4 stacked on the back side), and running 2x AW IMR18350.
Should be good for a few minutes of WOW. I really want to test to see if its usefully any brighter than a similarly overdriven XM-L2 in the same host. Worst case scenario, is I am really looking forward to having that beautiful MT-G2 tint in an almost EDC small package. If the project works out, I might try the same in the smaller M2 host, by modifying the 20mm Noctigon to 16mm.
P.S. I love that a great US dealer like you stocks the Convoy lights. I will definately be buying some M1’s, at least one C8, and hopefully in the future you will stock the M2’s (edit: I just realized the M2 host takes a 20mm driver, which sucks, but I suppose I could still find a way to make it work by making a brass adapter ring). I love that you offer the Zener Mod parts only kit. Makes it a no brainer for me. At least I don’t have to scour Ebay looking for the itty bitty parts, and buy them in bulk myself. I know some people hate soldering, but I love soldering everything myself, not to mention my soldering is always perfect.
DB Custom
DB Custom's picture
Got my latest order in, Thanks! Smile As usual, quick and well packaged. Now if I could only get to the point that “my soldering is always perfect” I’d be in really great shape! Smile
garrybunk
garrybunk's picture
DOH! LG 4.35v batteries are out of stock now! Any idea when you'll have these back in stock?
-Garry
Livinloud
Livinloud's picture
Last seen: 1 year 11 months ago
Any idea when the King Kong’s will be back in stock? Need some 26650 cells soon so not sure if I should wait for yours or keep searching.
LPF Member: Livinloud
Budget flashlight enthusiast turned into lumen freak
MRTdiver
MRTdiver's picture
DBCstm wrote:
Got my latest order in, Thanks! Smile As usual, quick and well packaged. Now if I could only get to the point that "my soldering is always perfect" I'd be in really great shape! :)
I got a C8 coming that you can practice on.  Tongue Out
Looks like many items are out of stock.  We may have over advertised  Smile
RMM in your original post, you said something about serving the BLF community.  You may need to modify that soon. Laughing
RMM
RMM's picture
Here's the deal: I have more King Kong and LG D1 cells in Washington, but am currently away and only brought as many cells as I reasonably thought I would sell.  Turns out I underestimated the demand.  I will be back this weekend and so will the cells.  They should be able to ship this coming Saturday or on Monday the 13th.
I have been getting a lot of new business from Google searches and members on other forums, such as CPF (although I refuse to pay their exorbitant  fee to advertise there, there has been some "behind the scenes" word of mouth, which I greatly appreciate).
DB Custom
DB Custom's picture
…being cheesy! Wink
DB Custom
DB Custom's picture
I’ve got to do some de-populating, and have trouble with that. It’s one thing to solder tiny parts on a pcb, taking tiny parts off is another matter altogether.
I have done some bumps to 105c drivers for a friend, stacking on 6 or 8 drivers in a row between his and mine. I can be doing great, then suddenly have a leg that refuses to accept the solder. How can it be going so well, then turn to fail? Aggravating when it does that! I have decided I need to get some flux…
I must really and truly be sick, I have not modded a light in 5 days. Sad
RMM
RMM's picture
I use a lot of flux, it makes my life easier.  None of that no-clean or water based stuff, good old rosin flux.  I use the MG Chemicals brand which has worked great for me; it is supposed to be non-conductive and non-corrosive, although I do clean it off of the board when I'm finished.  http://www.amazon.com/MG-Chemicals-Corrosive-Conductive-residue/dp/B008U...
$8.45 gets you a near-lifetime supply.  I coat both sets of pins before I add 7135s... in fact I'm in a bad habit of putting a little bit on just about everything but it ensures good solder joints and helps me work faster.
unknown00101
2nd the flux suggestion, works wonders. I use the RadioShack flux and a tooth pick to apply exactly where I want it (pretty well any surface where solder will touch).
Also at the mention of MG Chemicals… DO NOT buy their 63 37 rosin core solder. It will not tin tips for crap. Severely disappointed at its performance. I should have just got more kester at a significantly higher price.
Livinloud
Livinloud's picture
Figured you had some in stock since mtnelectronics on ebay has more than 10 in stock Wink
EDIT: also need some 16340s so Ill have a nice order coming in when the king kongs are back in stock Wink
drdanke
drdanke's picture
Same here. A really good flux makes all the difference in the world. Soldering is impossible without proper flux. I use a paste flux called “Hydro Flo” by AlphaMetals. I’ve been using the same tub of flux for over 10 years. With this flux, I’ve soldered everything from stained glass repairs, SMD, SMD-rework, and reworking and replacing MCU’s. It isn’t considered a “no clean” flux, but it is water soluble, and cleans up really easy with alcohol. Sure, there might be better fluxes out there for electronics, but why change when something works perfect!
RMM
RMM's picture
I have been using the MG Chemicals 63/37 and 60/40 RA  flux and I haven't had any problems keeping the tips tinned, although I do tin new tips with a dedicated tip tinner.
I have some 380 mA 7135s on order.
unknown00101
RMM wrote:
I have been using the MG Chemicals 63/37 and 60/40 RA  flux and I haven’t had any problems keeping the tips tinned, although I do tin new tips with a dedicated tip tinner.
Wierd, this solder right? I never had issues tinning tips with kester, but with this new stuff no matter how many times I clean it via sponge/flux or how much solder wire I push at it it will only tin a few small spots on the plated part of the tip.
