MTN Electronics: LEDs - Batteries - Lights - Chargers - Hosts - Drivers - Components - 1-Stop-US Source
8370 posts / 0 new
WaylonJennings
Richard,
What is the lumen output of the D4 and when do you expect the Aspire 18350’s to be available? I want to order a couple Shockli’s and a D4 and it would be great it I could order some of the Aspires at the same time. Thanks
korpzgrinda
korpzgrinda's picture
Last seen: 3 hours 56 min ago
Location: Eastern Woodlands in the Wilderness of North America
Are the D4’s expected to be restocked at some point in the future?
RMM
RMM's picture
Last seen: 3 months 5 days ago
Did you read the product page?
"We will have more stock in just a few days.  Hang tight! "
Mountain Electronics : batteries, Noctigon, and much more! What's new?
RMM
RMM's picture
WaylonJennings wrote:
Richard, What is the lumen output of the D4 and when do you expect the Aspire 18350's to be available? I want to order a couple Shockli's and a D4 and it would be great it I could order some of the Aspires at the same time. Thanks
I do not know the lumen outputs.  I haven't tested them.  They should be the same as any other direct drive quad flashlight --- 3,000+ (for a few seconds, anyways).
Aspire batteries should be here soon.  They have shipped, but as many of you may already know they have rebadged the "1300 mAh" cells to a more realistic "1100 mAh" battery.  It was very kind of them to tell me that after the order had been placed for almost a month and had already shipped.
WaylonJennings
That sounds good. I will place an order as soon as they get in. Are the Shockli 5500mAh batteries a lot thicker than the Liitokala 5000? I know that they are a tight fit in my SD26vn, but I would most likely use them in my U21vn and EC50vn anyway.
Eraursls1984
Last seen: 1 week 3 days ago
Lowtech wrote:
Probably not if they are big.
Unless l6 has changed
Ah, I only knew of the length issue with some batteries. I didn’t realize there is also an issue with some oversized cells. thanks guys.
Lexel
Lexel's picture
Last seen: 1 day 22 hours ago
Is it possible to stock the XHP35 HI E4-3C again?
chooma
Last seen: 2 hours 10 min ago
Just got the D4’s. My first ramping lights, I like them.
The Nichias get extremely hot within seconds the same with the xpl hi the s4 2b is a little better. With the 18350 they are measure 2.5 inches very short, me likes.
dekozn
Last seen: 2 days 23 hours ago
Hey chooma, is the ui ramping only or does it also have presets (low,mid and high)?
Idiot proofing something only creates improved idiots.
hatman
Last seen: 3 weeks 1 day ago
chooma wrote:
Just got the D4’s. My first ramping lights, I like them. The Nichias get extremely hot within seconds the same with the xpl hi the s4 2b is a little better. With the 18350 they are measure 2.5 inches very short, me likes.
Hmmm…… I ordered a Nichia in hopes that it wouldn’t produce as much heat as the xpl hi.
chooma
Only ramping, I cant find any presets.
As it ramps to its highest, it blinks, release button, press and hold to go back down. Been using a 30q and a 18350 purple efest.
dekozn
Thumbs Up thanks for answering. Too bad is doesn’t have presets though, ramping is nice and all but a pain to estimate run time while on the road. I still might get one if it’s easy enough to reprogram the driver and if it gets available for EU customers.
WaylonJennings
I am pretty sure that the light can be programed to allow for different levels instead of ramping.
chooma
Put new purple 18350 efest at 4.20 in the green nichia ran it until I couldnt handle it anymore 33 seconds.
Checked cell voltage at 3.93 cell was warm. Checked it again 7 minutes later and it is now stable at 4.03
Cell is still luke warm 12 mins later.
Anyway cool lights I dig’em.
EasyB
Last seen: 3 hours 12 min ago
The nichia 219C should actually pull the most current and produce the most heat of the three options. Big Smile
About the narsil FW, I think it does have traditional mode groups as well as ramping. See here for a description of the UI: http://budgetlightforum.com/node/55296
DB Custom
DB Custom's picture
Last seen: 5 days 3 hours ago
Yeah, you should be able to re-configure that driver to dang near anything you want, even thermal step down with manual setting. Tom worked very hard to get everything possible in it…
Hell2Pay
Last seen: 4 days 14 hours ago
dekozn,
WJ is correct ….
Tom E Narsil M link
Narsil is configurable …. Don’t what version is in the D4 but there should be some useful info in the manual from this link.
JasonWW
JasonWW's picture
Last seen: 9 hours 40 min ago
Heres a tip to changing settings.
After holding the button down for 8 seconds it goes into menu mode. It will do 2 quick flashes which is only to get your attention, then a single flash and a pause, this is setting 1. Then you can press the button once to switch from ramping to modes and it will blink once.
Then it will do the fast double blink to get your attention then 2 longer blinks. This is setting 2, etc…
So don’t count the first 2 fast blinks, only the slower blink afterwards. The 2 fast is only to get your attention so your ready to count. This is what confused me at first.
You can then let it go through and finish all 7 settings or just hold down the button to exit the menu early.
DB Custom
DB Custom's picture
The cheat sheet, from joechina, on Narsil.
hatman
Is the D4 one of those lights that takes a code book to program?
DB Custom
DB Custom's picture
Only if you don’t like ramping. Wink
OH Crap! (post count!) Facepalm
(Edit: Don’t understand, it said 15,000 with the cheat sheet, how did it go backwards?)
JasonWW
JasonWW's picture
Yes, but once you set it, there’s no need to mess with it.
Just look at the options and decide what you want. Ramping or modes. If modes, how many. Do you want modes to go from low to high or high to low. Do you want moonlight. Do you want memory. It’s not too hard. I love the default ramping mode myself.
Triple click and it blinks out cell voltage.
Quad click to lock out.
The special modes like strobe, sos, bike mode, etc… are double click, pause, double click again. So it’s pretty hard to accidentally go into them.
Narsil is great once you get a feel for it. I want all my lights to have it! Lol.
dekozn
Can someone who has the light confirm this. Just don’t want to get surprised that they changed the firmware somehow.
chooma
Do you mean i can try that trick with the lights i just received?
JasonWW
JasonWW's picture
If the light is using Narsil, then what I said should be true.
There are a few different versions of Narsil, which means the menus might be a little different, but it should be pretty much the same.
Maybe we should wait until we know which version of narsil it’s using before trying the menu stuff.
chooma
I just tried it and I got no blinks.
But those damn nichia really heat up the whole body but more so the head….Love it.
chooma
4 quick clicks gives lockout dont know how to get out of it but i did.
3 quick clicks battery voltage.
I was in a mode that was stuck in low mode would not ramp either way. Dont know how i got there but i got out somehow.
I just did 4 quick clicks waited a few seconds then clicked and held and i had momentary at the highest brightness. Then i did 4 quick and it gave 2 quick blinks and i was back in ramping mode.
Time to recharge….i think the Aspires will be the choice in the 18350 D4.
hatman
How hard do I have to study to get my D4 to just turn on high?
JasonWW
JasonWW's picture
4 quick clicks should lock out as well as unlock it. It will give 4 weak blinks whenever you lock or unlock it.
JasonWW
JasonWW's picture
Do you mean high or the highest “turbo”?
Double click from on or off should do that (turbo).
Or if you turn it off at the highest, one click will turn it back on in that same brightness. So its pretty easy.
I tend to go to highest, then ramp it down just a hair and leave it there. This gives you like 90% brightness, but longer run times and less heat.
If it’s memorized to come on a really high setting and you want to turn it on at a low setting, just turn it on by pressing and holding. This will turn it on in moonlight and begin ramping up. It’s good for when you don’t want to mess up your night vision.
