MTN Electronics: LEDs - Batteries - Lights - Chargers - Hosts - Drivers - Components - 1-Stop-US Source
8370 posts / 0 new
Cousin Elmer
JasonWW wrote:
… Hmmm, no Atiny85.
My wild guess is an ATtiny1616. Either way I think it’s the component on the bottom which could be nice.
JasonWW
JasonWW's picture
Last seen: 26 min 38 sec ago
Cousin Elmer wrote:
JasonWW wrote:
… Hmmm, no Atiny85.
What is the component on the bottom? I can’t make it out.
Click this to go to signature links.
Cousin Elmer
JasonWW wrote:
Cousin Elmer wrote:
JasonWW wrote:
… Hmmm, no Atiny85.
I can’t make out the writing but it looks like it could be a 20 pin package. The ATtiny1616 data sheet shows a ATtiny1616 20-pin VQFN (on page 15) which is consistent the image.
If that’s the AVR then a attractive feature is “Single pin programming and debugging interface (UPDI)”. That along with the presence of the AVR on the exposed side of the driver is a pretty big deal.
Of course it’s a guess for now… [EDIT] a guess that’s probably wrong… There are 20 pin versions of the ATtiny25/45/85.
moderator007
moderator007's picture
Last seen: 4 hours 42 min ago
Mine says
A645
T25
20MUFB
A8PBYA
Maybe a tiny25-20mu
Cousin Elmer
moderator007 wrote:
Mine says A645 T25 20MUFB A8PBYA Maybe a tiny25-20mu
I think that makes sense. It’s good to have something concrete. Thanks.
The_Driver
The_Driver's picture
Last seen: 4 hours 19 min ago
So, who has tried the boost driver? What are your thoughts?
contactcr
Last seen: 9 min 19 sec ago
They seem to work well. The moon is a bit brighter than most FET+1’s at about 5lm I think? guppydrv is nice but ill prob buy the next one with Bistro if it becomes available just to have a consistent UI. The host I used is a Jaxman mini C8 w/ 50.2 so turbo basically steps down instantly. The other modes look pretty consistent though.
Very much looking forward to higher powered 20-22mm versions.
nkresho
nkresho's picture
Last seen: 1 day 4 hours ago
I’m running one in both an m1 and a c8 with OP reflector. Each has a 50.2 in it.
I changed out the tailswitch springs on both lights with firmer ones, because a slight bump to the tail was enough to change modes on them. They have a brass button soldered on.
I am super happy with both lights. They drop down pretty quickly, but gradually when in turbo. You barely see it, but after 20-30 seconds it’s much less bright. They don’t get terribly hot though.
I think I got around 2200-2500lm between the two. Don’t have my notes handy. A bit more from the M1, as it’s a 5000k and the c8 is 4000k. Each was with a VTC5a.
Got a s3 host and a f13 ready to go as soon as the 17mm are back in stock and the 22s are listed.
contactcr
If you have a way to measure the relative output can you try to disable the thermal protection on the C8 and see if it holds a steady turbo with a fully charged battery? I want to test this but i’m afraid to try it on my tiny host w/ just a pill. Doesn’t have to be long, as long as you feel comfortable just curious if turbo is ever constant.
Fate0n3
Last seen: 2 days 5 hours ago
Was wondering if you be stocking the Noctigon Meteor M43 again?
nkresho
nkresho's picture
Sure. I had it on the default temp settings, originally. Haven’t messed with much of the ui actually.
My meter doesn’t log, but I can take readings at intervals to see what it does over time.
Meaning to fully test these lights anyway.
Batteries on the charger, I’ll post back here when I’m done, hopefully tonight, possibly tomorrow.
contactcr
I bumped mine up to like 185c and it still drops like a rock. Guess my host is not suited for this. I think my 50.2 4k 80cri peaks around 2050 lumens but only for a few seconds. Hoping your c8 soaks more heat and can be constant for longer. Maybe put it at 185 or 200c instead of disable at first
nkresho
nkresho's picture
Here we are:
Both with fully charged VTC5a
This is the 4000k 50.2. Sphere multi for this color temp is 0.194641099 (ending battery voltage at 150 seconds was 4.01v)
View post on imgur.com
and
This is the 5000k 50.2. Sphere multi for this color temp is 0.200202433 (ending battery voltage at 150 seconds was 3.99v)
Time scales are the same. 10 second intervals from 0 to 150 seconds. For some reason the second graph lost that data.
And for reference: i’m using a maukka-light calibrated, 17” spherical, BaSO4 coated, integrating sphere with a drmeter 1330b
contactcr
Looks like the C8 holding relatively steady turbo for 60-70s vs 10s shows that it is adjusting correctly. Now i’m curious if adding some type of heat sink to the coil on the underside would make any meaningful difference. Maybe no point testing such a thing until it bumps up to the 20-22mm size.
Skylight
Skylight's picture
Last seen: 1 hour 12 min ago
Would MTN Electronics ship small items with low value in an envelope to Europe? If you do not need many things the shipping costs more than the products themself!
ToyKeeper
ToyKeeper's picture
Last seen: 9 hours 28 min ago
Unfortunately, US shipping overseas is pretty expensive… and there’s nothing RMM can do about it.
Gebe
Last seen: 17 hours 45 min ago
Hi Richard,
As an aside, I’ve been one of your customers for awhile now and you folks have been great with reasonable prices and fast shipping.
I was wondering though when I ordered a couple of 26350 cells, one of them was leaking, (another gent here had a leaking cell also). I know you folks get super busy and I can appreciate that but I emailed you folks about it and received silence. You folks are usually very good at answering emails.
I didn’t ask for a refund or exchange, (I actually should have), but was just alerting you to the fact that your inventory of 26350 cells may contain some faulty examples.
Anyway and like I said, I’ve been very satisfied with many orders I’ve placed with you and just wanted to make you aware of this.
Agro
Agro's picture
Last seen: 2 hours 21 min ago
Team up with someone outside of US to cover international shipping?
DavidEF
DavidEF's picture
Last seen: 3 days 14 hours ago
But then the team member outside the US needs to get a cut, right? I think as good as Richard is, people who are not in the US are just better off not buying from the US as long as our shipping is so high. Or at least, they should weigh for themselves whether it is worth a little extra cost to buy from Richard. Certainly, for some people, it is worth it. Wink
- The YKK Philosophy
Skylight
Skylight's picture
Yes, it is definitely worth the cost even if shipping to Europe. I like the driver DIY kits and the pre-programmed MCUs. I just thought if envelope shipping inside the USA is possible it might be available also for Europe?! MTN Electronics does a good job shipping overseas. All the components are packed well and the items contained are all listed neatly on the outside of the package. It even arrives in less than a month. You just have to need more than only one driver so that the shipping cost is at least equal to the items cost.
Agro
Agro's picture
There are unique parts not available or hard to get elsewhere.
There are flashlight shops which could just add Richard’s stuff to the inventory. That’s a small cost for them. I believe may be able to set up their cut in a way that makes such arrangement beneficial to all – themselves, RMM, non-US buyers.
DavidEF
DavidEF's picture
Crown Thumbs Up
Gunga
Gunga's picture
Quick question. Can the 20mm mtn-ddm driver be filed down to 18-19mm and still work well?
Cereal_killer
Cereal_killer's picture
Last seen: 3 weeks 6 days ago
I have one filed down to 18.4mm, works fine.
Gunga
Gunga's picture
Awesome! Thanks!
vestureofblood
vestureofblood's picture
Last seen: 1 day 19 hours ago
For anyone who is wondering Smile
In Him (Jesus Christ) was life; and the life was the light of men. And the light shineth in darkness; and the darkness comprehended it not.
http://asflashlights.com/ Everyday Carry Flashlights, plus Upgrades for Maglite.
KawiBoy1428
KawiBoy1428's picture
Last seen: 8 hours 36 min ago
Great News! Congratulations Richard and Lisa on your new baby girl! Thumbs Up
KB1428 “Live Life WOT
gchart
gchart's picture
Last seen: 1 hour 53 min ago
That’s awesome. Congrats Richard & Lisa! Children are such a blessing.
moderator007
That’s good news. Congratulations Richard and Lisa, wish you all and your daughter the best.
djmcconn
djmcconn's picture
Last seen: 14 hours 15 min ago
Oh wow congratulations!!!!!!!!!!!!!!!!!!!!!!!
