I don't have a driver for it, but the only one I know of that would run it reliably is the HBFlex, which is $40... This is just for mock-up, if I do it it'll be in a nicer SRK as host, and a cool white array instead of the warm (3500k) shown, and those reflectors are beat-up leftovers, I have new ones to use once the dimensions are all figured out.
How long would it take to get hot enough to vent the cells? :evil:
I'm sure they don't do the actual claimed lumens, but I can tell you they put out more than enough for lighting an entire room. I used one for a gooseneck work lamp and it's too bright to the point of being painful. I had to swap it out for a 50W with a dimmable driver.
Should only take around 6 amps worst case, of course it'll have to be converted from 4P to 4S. HBFlex won't run at less than 7v input anyway.
edit: that's at startup with fresh cells, if you could manage to somehow run it long enough to drain the batteries at 3v/cell it should only draw about 8.5A.
But I don't have a M6... I do have a SRK with a 1/4" thick aluminum plate pressed in and already at the right height for this setup to drop right in. :bigsmile:
Bridgelux RS is surely nice but 50.8mm square, this needs to fit in a 48mm round hole. How much of the corners can be chopped off before it's unusable? (and $55 vs. $8 is a bit ridiculous, especially for something that's basically nothing but a party trick)
Looks hilarious, I think that’s all the reason you need to do this!
I have the cool white version of that led and the same reflector on order from dx, haven’t been able to find anything to drive it yet. Thought it was jut a novelty really
Since you’re running budget build here, running generic LED, use cheap driver. Here’s a $2 generic boost driver (LM2577 equivalent) - runs 30W. Huge range of voltage - so easy to configure.
Fitting it in, well, your problem :). Should be no issue if your host is SRK size or equivalent.
