hi would anyone no where i can find a steady 3 amp driver on a 17mm board if possable
Good luck with that, I would really like to know the answer to this question as well, the closest thing I have found was to do this mod here.
There is some more relevant info here as well.
Oh and welcome to BLF a lot of great info is to be found here.
Thank u.... i hope i can find one :)
If you know how to solder these are really good they are NANJG 105C drivers I got some a couple weeks ago they put out 2.8 amps on high and you can configure them as to how a many modes you want. They are really close to 3 amps there is a way to mod these above 2.8 amps by stacking chips in the link I added above.
http://kaidomain.com/ProductDetails.aspx?ProductId=11088
Shiningbeam also sells them with the wires attached and the mode selection set to 3mode high medium and low this saves a lot of time since it is very difficult to solder on these small boards plus you will get them in 2 or 3 days in Ohio.
http://www.shiningbeam.com/servlet/the-132/3-dsh-Mode-Regulated-Circuit-Board/Detail
ill go with the Shiningbeam driver so i dont have to wait 3 weeks thanks again for the great help and links
Cheaper but only one mode:
