Modding the Small Sun ZY-T20 - MT-Gangnam Style - Done - With Beam Shots
You know I already tore the Small Sun ZY-T20, from this thread.
t201a
Now it's time to do a little innocent Modding MT-Gangnam style.
Now for the Mod...
t201b
The idea is that I have wanted to do a large reflector light with a MT-G2 running at 9+ Amps. I finally decided to go ahead and do one. I have a driver from texaspyro and I figured Why Not? Why take three NANJG drivers and do all that wiring, just do this one. Well, I have been communicating with tp about it and it probably can be done, but there's some give and take there. I have to put in a momentary SMD switch and I have to do the diode/resistor mod. I will loose battery monitoring and low battery cut out, but I can keep the stock tail switch in the circuit, to provide a shut off that will keep from having parasitic drain, so I'm going for it.
t201c
One of the "first problems" is the aluminum heat sink, which I call a led shelf, because it's not really what I think of as a heat sink. I don't believe I want an MT-G2 at 9 amps sitting on this, so I will be cutting out where X marks the spot and using Copper discs in place of that area.
t201d
t201e
But... I think I need much more than that, so here are Six 1" Copper pipe couplings that have been heated to soften them, split apart and flattened with a mallet.
t201f
You can see that I can get two discs out of each coupling, so I will have 12 of them under the modified original led shelf. I should end up with about a 42mm diameter x 15mm thick Copper heat sink, when I cut all those out and solder them together. With the copper star, copper discs in the Aluminum heat sink and the copper below all soldered together, it should provide some real heat sinking.
t201g
The next of the "first problems", is the fact that I have to put in a SMD switch and housing. This hole looks like it would be great for it...
t201h
Well, not quite, as you can see on the inside. It is very close to the driver mount and I have to make it bigger yet, for the switch. I may not be able to do it at all here and it is also 180 degrees away from the top of the light when holding it by the handle, so I would have to solve that issue too. I may have to just blow a new hole into the other side of the head, to make it work. One way or another, it will work.
t201i
The third of the "first problems", is the reflector. It already has a hole big enough to let the dome thru, but I believe I will find that in order to get any kind of a tight spot, I will have to open that hole up so I can sink the reflector down around the led, flush with the star. I will have to set up a testing spot, so I can power the led up and see if I have to lower it.
11-23-13 - I spent 8 hours in the shop and I really don't have a thing to show for it. Sometimes hand work just seems futile, but here is what I accomplished in all that time.
ssg2a
ssg2b
ssg2c
It took the whole day to make the Copper heat sink. 12 layers of the flat plate made out of pipe couplings, all soldered together and made into a round that fits snug into the head. Three Copper discs that go on top for the LED star to sit on. Opened up the original aluminum shelf, so it is now just threads, so the heat sink will screw in like original. I am not going to solder the star to the heat sink. I want to be able to get it off easily when it fries after continued 9 amp use.Tongue Out The heat sink weighs 170 grams or 6 oz. The head, with the heat sink in, weighs 462 grams or 1.03 lbs. Next up will be testing the reflector to the led and figuring out the necessary height, to get the best hot spot, but not tonight, or tomorrow either. With the cold front that has come in, the garage is not much fun to be in and I have to do some honey do's tomorrow, like steam cleaning the carpets.Frown
11-24-13 - It's Cold! I know, it's T shirt weather for yous yankees, but after living down here for many years, it's cold whenever it's below 50 and it's well below that. I don't have a lot for you today. I did hook up the MT-G2 to 4xAlkaline AA batteries and fired it off, so I could sit the reflector on it and see what the beam will be like. I really can't adjust the reflector height, so here's a couple of shots with it sitting as it will in the light.
ssg21a
ssg21b
One shot is at a faster shutter speed than the other, to see the hot spot more clearly. One thing I will say is that the half stippled reflector does seem to really help get rid of the dreaded dark spots in the center of the beam, which I see in every MT-G2.
I also have been debating on what the hell I am going to do with the switch and today I decided that no matter what, I had to fill in the original area that was milled out for the stock charging port. I ended up going with JB Weld and then I can drill/mill out whatever hole I need for the momentary switch. I picked one switch up from Radio Shack today, but I do not know if I will use it or stick with a Rook switch.
ssg1q
Once it dries, I can start smoothing and blending. When I have it all set and the switch hole is done, I will paint the bottom section of the head with the Black VHT paint.
I did the mod for the texaspyro driver today also. Here's a before & after what I did. I think it will work, but time will tell.
tpm1
tpm2
11-27-13
I don't care what anyone else says, It's Cold down here! I'm a wuss after living here for so long. I grew up in harsh winters, with lake effects weather, but after being here for so long, it's cold as heck when it gets to the freezing point here.
Anyway, I have been doing very little, but I have made some progress. If you remember from an earlier photo, I had filled in part of the head with JB Weld and I have gotten the switch problem solved, (I think).
ssh1a
Here's the area after I formed it with files and sandpaper. It came out better than I thought it would. The air holes will be filled before painting.
ssh1b
Then I had to make a hole for the rook switch cover. I started out with the drill press and a couple of dremel bits to make the starter hole, but to make it big enough, I ended up doing the rest of the enlarging and depth, with the head in a vise and using the dremel tool by hand.
ssh1c
Like I said, it came out better than I could have imagined and I was very worried about the JB Weld breaking up during this endeavor, but it held and it will work. I could not make threads, so the cover will be glued in with epoxy when the whole switch assembly is fit into place.
ssct1
I also gave up on the tail cap switch. I figured out that it would be hard to break both of the 2S/2P circuits and besides, the switch is not rated at 10 amps, so it would most likely fail sooner or later. Instead of the switch, I went with a plug of Abalone shell backed by a couple of metal discs and held in by the original retaining ring inside the TC.
sscp1
I am also working on modifying the original driver into the contact plate for the 2S/2P battery configuration. I still have a lot to do, but every little bit gets me closer to the final day.
Here's the last of the photos. It's finished.
ssmt1a
I decided to rework the circuit path of the batteries. I wanted to load from the tail cap. so I made it into the Caveman style. EA8 that is, with the back contact plate that spins in the tail cap and has alignment studs in it. Here I have soldered a brass pin in the center, so the contact plate will fit over it.
ssmt1b
Here's the modified contact plate, with the positive and negative contacts and two guide pins. I drilled the body, for the pins to fit in and align the plate as it is put into place.
ssmt1c
The pill is ready. I had to notch the aluminum ring, to clear the wires and I used AA to keep from having any shorts.
ssmt1d
The upper contact plate and driver are all wired up, ready to close it all up and "go for it".
ssmt1e
The head was painted and the switch is all done. I forgot to fill in the small holes in the JB weld before I painted. Don't know if I will go back and do any more with it, probably not knowing me.
ssmt1f
Finished.
ssmt1g
Beam Shots:
ssbs1
Stopped all the way down to 1/60 of a second, to see the hot spot more clearly. Smooth beam, no little "dots" in the center, like most reflectors have with the MT-G2.
ssbs2
Back at 1 second, it's bright as hell and brighter than any multiple XM-L light I have played with.
ssbs3
Don't move the camera when you take a photo. There is a LOT of spill and it does take away from the center spot. I would imagine the stippled bottom half of the reflector is the reason, but since it got rid of the "holes/dots" in the center spot, I guess I can accept the final overall beam.
ssbs4
ssbs5
There was a lot of fog over the pond, so it blocked out a lot of the beam. The beam isn't blue either, but it looked that way in the camera, probably because of all the light reflected back from the fog.
ssbs6
That's it.
I have not done amp draws yet and I don't know if I can/will. SInce the circuit is 2s/2p I don't know woh I am going to use the meter in the circuit to read the amps. This circuit does not rely on grounding to the light itself. Since the + and - are both at the same end, (up front), there's no way to ground against the case, or at least it wasn't needed to make it work.
EDIT: I read just about 9 amps on the nose with the 20R batteries, so it's doing what it's supposed to do. Good deal. I still like the SST-90 aspheric better. It's impressive, but I would take a King at 9 amps over this any day. Smaller size and larger hot spot.
WOW… that driver… Crazy cool.
Great mod…
Emitter & driver looks cool
Hmmm. Will this be crunchy toasty or a melted pool of metal? Good luck on your mission sir and l await your results with baited breath. My fondness of this led grows every time I use one whether its driven mild or wild. The driver setup you are using, would this run 3 x XML’s in series?
:smiley: :smiley:
Mind if I steal that?
When the solder melts it won’t matter.Tongue Out The driver would drive 3 XML in parallel. It’s made for an SRK.
damn, that’s some amazing work for the materials on hand. I think it’s time to invest in a lathe… :slight_smile:
... keep up the crazy awesome mods... :)
I promised all the lathe guys here that I wouldn’t do that, Sealed.
If I had a place for one, the spare power in the electrical service box and the money, I would have a lathe, but I don't have any of the three.
That is very cool. I’m also a fan of these MT-G2’s. I really didn’t think I would be at first but they are growing on me.
I want to know when these sellers will wake up and start coming out with a for real and just for only MT-G2 driver. I think it's wayyy past time for that. Of course, they will probably make it only pushing 2.75 amps, if it's anything like they do with everything else.Tongue Out
It would be nice if they would. Right now the best driver I have found to run one is the driver in the Lustefire triple. It draws enough amps to pop the protection on two panasonic 3400’s. I have it in a Small Sun ZY-T08 and it rocks. Well over 3,000 lumens at start up.
I contacted Wallbuys to see if they will get some in. I’ll let you know if they do. It has to be filed down to fit but once it’s in it’s perfect. I wish it didn’t have the blinkies but beggars can’t be choosers.
+1
Depending on the light it comes from, stock they seems to do between 7-9 amps. And the current it does on high it will do nicely regulated, at least if you are using three cells.
There are already a bunch of drivers out that there that works quite nicely with an MT-G2..
Old-lumens don't need no stinkin' lathe...he is the original human lathe!
I only have one question: will there be a music video released alongside the review of the completed build?
9 amps?!!?
More photos in the OP
24 chips, should be about 9 amps
Where do I start? Just how much patience do you have? That heatsink itself, wow. The effort involved is incomprehendable to me. What an effort. I may have asked this before, how do you finish it of so its so round and even getting it so flat? Looks like you have found the answer to the shadowy ghosts as well. Good luck with the next stage. This is really amazing work.
I started out with the flat rectangles that were the result of splitting the pipe couplings and flattening them with a hammer and a block of wood. Then I traced out the circles, (2 on each rectangle). I cut them out with a pair of metal shears. First in squares, then cutting the corners and cutting again, till they are octagonal. Then I hammer them all flat again and coat one surface of each one with solder, by heating with a torch. Then I stack them up and use a pair of vise clamps to hold and squeeze, while heating them all together. That squeezes them tight when the solder melts. After cooling, I put the soldered mass into a vise and start smoothing off the octagon with files. Once I am fairly close, I use a dremel bit in my drill press and work it down till it fits. The final edge finish is with a dremel sanding drum in the drill press. It is not a perfect circle, no matter how hard I try, but it's close enough for horseshoes and hand grenades.
I’m stumped for words. A+ for effort and achievement. Thanks for sharing.
