Starry Light SA-22
154 posts / 0 new
phsinvent
phsinvent's picture
Last seen: 11 months 1 week ago
I was able to compare it to a Roche f8 with nanjg 2800 ma driver when I got home. The starry light is a little more starry. I would estimate it at about 2800-2850ma.
Bort
Bort's picture
Last seen: 1 month 4 weeks ago
Does it stay at full brightness till the batteries run low or will it kick down in a few minutes like other lights?
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
Rusty Joe
Rusty Joe's picture
Last seen: 1 month 1 week ago
Got mine today too, but it’s stuck in the apt office. I was asleep. Sad
Eat Once a Day - Lose Weight - Feel Great!
www.omad.info
phsinvent
phsinvent's picture
Nope. It stays on high until the bitter end. It’s not that sophisticated, but to your liking. I like almost everything about it. Bright as hell, equivalent to a 2800ma nanjg driver. I have accepted the pa66 nylon body.
But I don’t admire it when I look at it because of the black head and charcoal body. It looks like they had a large stock of jet black reflector heads and slapped a plastic body to it.
HBomb
HBomb's picture
Last seen: 2 years 10 months ago
maybe take some sharpie to the body? or maybe the boiling RIT dye thingy would work. Thanks for the impressions of it.
phsinvent
phsinvent's picture
The nylon body most likely will not accept any coloring. There is most likely glass fibers for structural integrity and they don’t absorb dye very well. Very similar material to the plastic body ar15’s that are called carbon 15 or carbonfiber. I work with firearms coatings at work on a daily basis. I’m tempted to scuff the head anodizing and fire a ceramic matching black charcoal finish at 300-400 degrees F. And be done with my griping
Bort
Bort's picture
Whats the battery life on high?
phsinvent
phsinvent's picture
I would prefer to run duracell ion core stay charged aa rechargeable made in japan relabeled xx eneloops but I only have aa alkaline duracell pros in it right now. I have been running it off and on all night. The light and batteries are still going strong. The last big mystery would be parasitic drain but I have only had the flashlight in my hand for 8 hours now.
ChibiM
ChibiM's picture
Last seen: 10 hours 48 min ago
That's a very long name for a battery Wink
And the latter part of the name is unproven Innocent
Bort
Bort's picture
I had the same thought, proof would be very nice
Rusty Joe
Rusty Joe's picture
Love this light! This could be THE budget light of 2014!
If you’re on the fence, get off it and just get one! At this price, you can’t go wrong!
Output is sensational. The grip and body feel is fabulous. Only thing I don’t like is threading on the top. It’s hard and feels like it’s mis-threading (when in fact it corrects itself the tighter you screw downward). Beyond that, the PWM is just about not noticeable unless facing a fan or running water. I don’t notice it at all. The modes are nicely spaced and super-useful. Mode memory is a delight, as is the button response (requires very little pressure). The beam and tint are beautiful. Has good distance, even though it’s not a thrower. I just opened it up and have been playing for some 20 minutes, but I LOVE this light! Can’t put it down!
GET IT!
www.omad.info
89 300ce
Last seen: 4 years 6 months ago
Are there any coupons for this light?
mfpmax
mfpmax's picture
Last seen: 3 years 6 months ago
I saw this light but wanted modes similar to the Jetbeam/Fenix ones. Also Terralux has one that is basically a recolored version of the Jetbeam called the Colorado now.
Wilson
Wilson's picture
Last seen: 2 years 9 months ago
I compared this light to my Jetbeam PA40.
It’s a little shorter.
The diameter and depth of the reflector look about the same.
Those protruding walls measure 0.060 inches thick. I don’t think they will survive a 2 meter drop, but I haven’t tried it.
Please excuse my attempt at a beamshot. 2.8 aperture at 1/60 second. Light was 72 inches from the wall.
Summary:
This light is lots of fun and well worth the price point. The holster is gorgeous. The low of 150 lumens is somewhat akin to a SK68, so not too bad. It fits well enough in the pocket for a trip to the task, but I wouldn’t want to EDC it in my pocket.
Bottom line – buy it.
Inquire…Choose…Proceed
kst
Hey, what is the mode sequence on this light, Low-Mid-High or H-M-L ?
wight
Last seen: 1 week 5 days ago
That reminds me! Time to hit those potential-duraloop-xx cells with 5A discharges, which is the most I can do. I figure if they are around 1.1v by the time they’ve given up 1Ah that’s a good sign. The packages are marked “Made in Japan,” so that’s not in dispute. It’s too bad I don’t have any logging yet, comparing curves might help.
I guess I’d better take it over to the Rechargeable Batteries subforum a little later tonight once I’ve generated a measurement or two. EDIT: here’s the thread
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
phsinvent
phsinvent's picture
They are labeled 2400 mah but they test out between 2500-2575mah. They weigh the same. And so far hold voltage
DPRoberts
Last seen: 1 day 5 hours ago
Based on the previous comments, I expected the color mismatch between the body and the head to be much worse. At least in this shot, it doesn’t look that bad.
I was afraid that this starry night would look more like the Colorado:
Now THAT is a color mismatch. I don’t care how good the light is, that just looks bad.
ChibiM
ChibiM's picture
DPRoberts wrote:
Wilson wrote:
I compared this light to my Jetbeam PA40. It's a little shorter. !{height:364px; width:274px}http://www.brightlightmodules.com/BLF/server/php/files/ue5vrfk05mrm2kk7t...!
Based on the previous comments, I expected the color mismatch between the body and the head to be much worse. At least in this shot, it doesn't look that bad.
I was afraid that this starry night would look more like the Colorado: !http://images1.opticsplanet.com/365-240-ffffff/opplanet-terralux-colorad...! Now THAT is a color mismatch. I don't care how good the light is, that just looks bad.
What light is that?
mfpmax
mfpmax's picture
ChibiM wrote:
What light is that?
Terralux Colorado
Rusty Joe
Rusty Joe's picture
Has anyone else had SERIOUS trouble getting the light screwed in? I noticed it kept screwing and screwing, but never really attached when I got mine. It works great when you press down and turn it once, but you can easily thread it the wrong way and the light will not work. But you can never screw it down properly (all the way and in such a way as to get it to stay – you can always pull or wiggle the head right off, which means the o-rings don’t make a difference and can’t protect the light from moisture).
Anyone else noticed this? First time I played with it, I noticed this design was the worst-threaded light in the history of lights. Tried to demo it for a buddy tonight and found out how bad this design really is. He totally lost interest in it because of this. It just will NOT screw on properly. I’m amazed it stays at all.
www.omad.info
tjhabak
Not really any problems on mine. It is a little tough to get started, easy to cross-thread, but once mine is started it screws down tight.
Old-Lumens
Old-Lumens's picture
Last seen: 2 years 11 months ago
Rusty Joe wrote:
Has anyone else had SERIOUS trouble getting the light screwed in? I noticed it kept screwing and screwing, but never really attached when I got mine. It works great when you press down and turn it once, but you can easily thread it the wrong way and the light will not work. But you can never screw it down properly (all the way and in such a way as to get it to stay - you can always pull or wiggle the head right off, which means the o-rings don't make a difference and can't protect the light from moisture). Anyone else noticed this? First time I played with it, I noticed this design was the worst-threaded light in the history of lights. Tried to demo it for a buddy tonight and found out how bad this design really is. He totally lost interest in it because of this. It just will NOT screw on properly. I'm amazed it stays at all.
Plastic body - made in China. The reason I will not buy one. Don't care what type of plastic it is, if it was molded in China. The specs will be off and the min/max dimensional ranges will be too big. OD of threads too small to hold well in the Aluminum head on some and too tight to screw in well on others. Not good, but expected when a process is out of control. Some will be great and some will be no good. My prediction, LOL.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
jmpaul320
jmpaul320's picture
Last seen: 1 day 6 hours ago
Old-Lumens wrote:
Rusty Joe wrote:
Has anyone else had SERIOUS trouble getting the light screwed in? I noticed it kept screwing and screwing, but never really attached when I got mine. It works great when you press down and turn it once, but you can easily thread it the wrong way and the light will not work. But you can never screw it down properly (all the way and in such a way as to get it to stay – you can always pull or wiggle the head right off, which means the o-rings don’t make a difference and can’t protect the light from moisture). Anyone else noticed this? First time I played with it, I noticed this design was the worst-threaded light in the history of lights. Tried to demo it for a buddy tonight and found out how bad this design really is. He totally lost interest in it because of this. It just will NOT screw on properly. I’m amazed it stays at all.
Plastic body – made in China. The reason I will not buy one. Don’t care what type of plastic it is, if it was molded in China. The specs will be off and the min/max dimensional ranges will be too big. OD of threads too small to hold well in the Aluminum head on some and too tight to screw in well on others. Not good, but expected when a process is out of control. Some will be great and some will be no good. My prediction, LOL.
wisdom to live by from OL Smile
Would you mind keeping the wrong flashlight?
Best wish, May
Tmart service team
Soumil wrote:
PLEASE HELP ME GEARBEsT! IM LITERALLY CRYING!
bikenber73
bikenber73's picture
Last seen: 4 hours 34 min ago
I had to put mine together, the tiny driver/pill retaining ring was unscrewed on mine. I had to get an ice pick and stick it way down in there between the head and the pill and screw the ring into the head. The bezel ring also was loose.
Rusty Joe
Rusty Joe's picture
Just noticed there is also some dirt that got into the reflector. Well, this sucks.
www.omad.info
vēer
vēer's picture
Last seen: 1 month 5 days ago
Will you guys contact your sellers?
If so, let us know how they handle this and what their answer is regarding whole batch of theirs!
Streamer
Streamer's picture
Wow....I was getting pumped up over this light...sure sorry to hear it has flaws out the gate.
Rusty Joe
Rusty Joe's picture
UPDATE
It was the retaining ring; it wasn’t screwed in on mine either! I took a paperclip and screwed it down at work (not quite all the way, but enough to get the job done) and it threaded right on! It’s now screwing on and sealing properly. If you’re having trouble, be sure and check that.
www.omad.info
leaftye
Bort wrote:
Pulsar wrote:
what size driver? may be able to swap a qlite into it if pwm bugs you
I also wonder about hte driver, if it is easy to replace i bet there are good buck drivers out there I hope someone does a full review, it would answer a lot of questions
+1
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
