Can anyone identify this 18650 please?
Hi All…
I’ve been busy dismantling laptop batteries and I’ve found some cells which I can’t identify.
They’re 18650 unprotected with a translucent red wrapper and are printed HCVFIH5 with 082532 printed underneath, slightly (1mm) raised positive pip with six vent holes and a white plastic ring loosely held on by the wrapper.
I’ve tried Google with no luck.
I’d just like to know out of academic interest if they’re a known brand or cheap knock offs. They came from a non-original Dell C6xx battery.
Cheers
Malc
PS SWMBO has suggested I put up a shelf for my collection!
Do they have anything stamped into the plastic (not printed) ?
Red Sanyo UR18650 2000mAh:
https://www.google.com/search?q=sanyo+UR18650&tbm=isch
If they are Sanyo UR18650EX, Ohaya has a thread: High risk Laptop Battery Pack deal?
No… nothing stamped into the plastic.
Try hard, is no easy to see…
Thanks for the thread link,
Out of the Dell battery pack (possibly a replacement) that I took apart to get these cells, both read zero V so I recycled them at our local store - didn’t even dream of trying to charge them. The other 6 out of the pack read 3.75V or so. These seem to have have charged OK on my I4 V2, I just have to dig around in the shed to get my decent test gear out then check them properly.
The other pack I took apart was original Dell with 8 Panasonic cells, same thing 2 bad and 6 good.
Cheers
Malc
Thanks… I tried really hard with a magnifier and couldn’t find anything. I could be my tired old eyes!
Try with a light in front of the battery, use the reflection… Like this
Hello,
Can you help my find the model and specs for this batteries from old laptops?
One is Red 18650 Sanyo with green ring and the other is Sony US17670GR.
Thanks!
green ring=2400mah.
sony cells have a gx code for capacity. like g8
Thanks!
And what about Sony US17670GR?
Nothing like gx on my battery.
All I have is:
JH4FK17 073665 J35A C 5 4K5
JH4FK17 073688 J35A C 6 4K5
JH4FK17 046130 J35A C 4 4F4
JH4FK17 057804 J35A C 3 410
JH4FK17 073594 J35A C 6 4K5
JH4FK17 073593 J35A C 5 4K5
x= unknown.
i guess you will have to test them to see what is left of their capacity.
they are quite old.
Tested them, and all are around 1.800 mAh, witch is pretty good i think! :smiley:
