Tritium Instead Of Lanyards
22 posts / 0 new
CRX
CRX's picture
Last seen: 4 min 34 sec ago
Using flashlight lanyard spaces for tritium inserts
Edited by: CRX on 05/06/2017 - 11:47
jacktheclipper
jacktheclipper's picture
Last seen: 1 day 21 hours ago
Nice !
TSellers
TSellers's picture
I placed trit’s into the tailcap of our Tank keychain lights much the same, but have never thought about those lanyard holes, great idea. How did you set that up, I assume you masked the bottom of the hole with tape to create a well, filled it with UV glue, added the trit, and then removed the tape when the glue had set?
Regards, TS
CRX
CRX's picture
Yeah, that’s a fairly spot on way to explain the technique i used except the vials were put in place first.
TSellers
TSellers's picture
Great thanks. I’ve got a new tub of small trit’s here that I was looking for homes for, now I’ve got some options.
Regards, TS
jondotcom
Last seen: 5 years 10 months ago
Just installed the green ones yesterday after having the slotted pistons for a few years.
lionheart_2281
lionheart_2281's picture
Last seen: 2 days 11 hours ago
I wish you had a better camera
Helios-
Helios-'s picture
Last seen: 4 months 4 days ago
You have a tub of trits?
If there are any you just can’t find homes for, just let me know. I’ll be happy to provide a very loving happy home! Can’t have them get left out in the cold.
Counterfeit 18650s, 2,<a href=“http://
Essexman
Last seen: 22 hours 46 min ago
Nice work CRX.
A couple of Qs if you don’t mind.
Where do you buy your Tritium from?
Which UV glue have you used, looks really clear!
How did you set the UV glue?
My best so far was 4 small trits in a SWM finned head for my daughter, pink Tritium
I also made some Tritium eyes for lanyard skulls
I used Loctite glass repair glue and sunlight (it was the Summer!) glue set solid in ten minute bright sunlight.
CRX
CRX's picture
Thanks Essexman, i like those beads and the SWM looks cool too. I have the v10r Ti+ but i don’t dare attempt to drill the fins out like that.
I usually get the vials from ebay, haven’t bought any for a while but sometimes you get some good deals for small batches if you keep a lookout for them. Other than that the small ones cost £3-£5 new.
This is the glue i’ve used http://www.ebay.co.uk/itm/280891697467?_trksid=p2055119.m1438.l2649&ssPa...
I don’t think it’s the best stuff TBH but i like it because it doesn’t set absolutely rock solid so it can be removed with sharp implements later on if required. You also need to polish it up once it’s set to get it crystal clear.
Tip for anyone reading this – don’t use epoxy resin.
Since we only see the sun for about 7 days a year in Scotland i converted an Aurora SH-034 into a 3 mode UV light.
I don’t know the nm of the UV but it seems quite powerful and sets the glue in about 1 second flat, i think the emitter originally came from a p60 that i bought a while ago.
jondotcom
Most use Norland clear uv adhesive, but you certainly could use clear epoxy if you know the potential downsides.
1)
Epoxy will yellow over time, but most flashlights in my case have low uv exposure. It would not be a good idea if you store your flashlights outside in the sun :bigsmile: Also consider the lifespan of trits (10 years is the suggested life on mine).
2)Epoxy is a 2-part product (norland is not), and stirring method can cause bubbles. My last two actuall came out nearly perfect and with no visible bubbles, but the piston I purchased where norland was used actually does have visible flaws.
CRX
CRX's picture
I’ve found that using epoxy makes the vials appear smaller in size compared to the UV glue.
It can and does discolour over time.
You’re right in saying there can be problems with bubbles incurred during the mixing of epoxy, a real PITA sometimes.
Norland 61 is good but pricey and harder to remove.
The glue i linked is cheap and like i said, can be removed easier for trit replacement in 10 or so years.
Thanks for your input Smile
NightCrawl
Last seen: 4 years 4 days ago
How exactly did you get them so smooth with the surface? For example the Maratac Cu 123? Just add a lot of glue and then squeeze out the excess with tape?
Anyways, they look really cool. Smile
CRX
CRX's picture
Thanks, I didn’t use tape on that one, it was a bit more awkward.
You need to try to get just the right amount of glue in there then move the light around a bit until the viscous glue is where you want it and then quickly put the UV light on to set it in place.
After that it can be polished up, with a soft cloth and lighter fluid.
How much polishing depends on how good you were at setting the glue in the first place Wink
There was a lot of trial & error trying out different techniques and materials.
I used clear epoxy to begin with but wasn’t happy with the results.
NightCrawl
So.. I need a UV light then. Big Smile
Thanks for the explanation. Smile
jondotcom
Yeah I just compared the norland piston to the ones I did with epoxy and the epoxy is definitely not as clear.
When I compare the “jhanko professional one” I purchased where norland was used, the clarity is better and brighter in the daylight (you can see the reflective surface at the bottom of the bore around the trit better). On that one they also polished the surface flush with the piston, too, so it’s just a better overall install. From what I understand, UV optical glues may self-level better as well.
No, just sunlight.
TSellers
TSellers's picture
We don’t have much UV this time of year, and taking it outside to cure at -30C is not pleasant. So, I had read that the best nm for curing is around 254, which is where the UV Water Sterilizing devices like the Steri Pen is at. Having quite a few Steri Pens at my disposal, I decided to try one. They have a safety device, two probes on each side, when you immerse the pen in water, the conductivity tells the pen it is OK to switch on. That means you cannot sterilze really soft water unless you drop a pinch of salt into it. So after I had my UV glue in place, I jumpered the two probes and turned the pen on and laid it over the glue. However I forgot that the pen also times itself to auto shut off when it has done 1l of water. That’s about 45-seconds to 1 minute. I discovered that’s not long enough to cure the UV glue from Fasttech that I’m using. So, as long as your are prepared to return to the Steri Pen at least 20 times or more, eventually the glue will set. If you don’t have a strong source outdoors, I guess it’s a matter of Needs Must.
CRX, that’s interesting that you found a light that will sure that glue, I’ve been on the lookout for an affordable emitter that would do it for a long time. If you can figure out what emitter it is, and even what wavelength, that would be great.
Regards, TS
Cowboysnavy
Last seen: 5 years 9 months ago
I use CA glue and it works just fine for me
CRX
CRX's picture
I had a look around in the spare parts store and found the old UV drop-in reflector which still had the label on it, apparently it’s the Solarforce LC-UV LED module 3v-6v, wavelength: 380 – 450nm according to specs.
TSellers
TSellers's picture
Thanks for that. Now that we know that that wavelength apparently works for curing that glue, time to go back and look at the few emitters that Fasttech had, and finally we may be able to build an inexpensive light for doing this. Being that drop-in was Solarforce, I suspect it wasn’t cheap originally.
Regards, TS
Essexman
I was thinking about the UV curing today. I wonder if one of these would do it?
http://www.banggood.com/Wholesale-Portable-9W-UV-Gel-Nail-Art-Curing-Dry...
TSellers
TSellers's picture
Good find, at least for you as I think your mains is 220V?
I recall looking at something similar a year ago and I cannot remember why I did not try it. It might be that at the time I was under the impression you needed something around 254nm, but now we know from crx the higher wavelengths seem to work. I’d bet this would work for you, although with that UV Glue from FT I get the impression you’d have to cycle it a few times. I wonder if those flourescent style tube bulbs would make a difference over using just LED’s?
Edit: I had a closer look at Banggood’s offerings. I see that one problem may be you have to fit the items you’re curing into this device, plus the limitations of that timer. So it made me wonder about maybe some of the other items they have that may work better:
This device allows you to turn the timer off, is 36W so might be a lot faster, used the cheap $2.00 bulbs, but most importantly, allows you to slide the bottom out and place it over the item you’re curing.
This one also seems to be the same thing, it does not show it but looks like you can also slide the bottom out and that switch on it also makes it look like you can toggle the timer off:
Edit: Found more of the same on ALi Express and eBay, and you can turn the timer off, and you can slide the bottom tray out:
Or for less money, maybe one of these Flashlights?
- 12 LED BlackLight Ultra Violet UV Flashlight
- 21 LED Aluminum Alloy Ultra Violet LED Flashlight 3xAAA
- 385-400nm 9 x UV LED Ultra Violet Flashlight 9 x UV LED Ultra Violet Flashlight
Stumbled across another interesting Wiki regarding treatments for skin conditions. For example, it appears they may use similar wavelengths for treating psoriasis:
Quote:
Psoriasis[edit]
In psoriasis, UVB phototherapy has been shown to be effective.10 A feature of psoriasis is localized inflammation mediated by the immune system.11 Ultraviolet radiation is known to suppress the immune system and reduce inflammatory responses. Light therapy for skin conditions like psoriasis usually use NB-UVB (311 nm wavelength) though may use UV-A (315–400 nm wavelength) or UV-B (280–315 nm wavelength) light waves. UV-A, combined with psoralen, a drug taken orally, is known as PUVA treatment. In UVB Phototherapy the exposure time is very short (seconds to minutes depending on intensity of lamps). The time is controlled with a timer that turns off the lamps after the treatment time ends.
Regards, TS
