testing two of KD's new Nichia 219b leds (4500K'92CRI' and 5500K)
140 posts / 0 new
djozz
djozz's picture
Last seen: 9 hours 57 min ago
I am still confused about which 219B is which, Illumination Supply had supposedly the best tint and bin of the new Nichia219B 4500K 92CRI, but Kaidomain also showed up with some new Nichia 219B's, with mistakes in the type nrs.  IS was directly sold out, I ordered the KD one, and also a 5500K (non-highCRI) one. These are my tests. The subjects (the first two are the same led type):
In the description further in this post I just stick to the type nr. of Kaidomain, I will update if I know anything for sure.
This new 219B looks a bit different from the 219A I was used to, the most important difference (apart from performance of course) is that it has a more shallow dome (most of the Nichia 119 and 219 leds have this shallower dome also), actually it is more comparable to a XP-G2 now. You can see that reflected in the emitting angle, it went up from 110 degrees to 120degrees. (left old, right new):
As usual I test output and voltage at various currents with the leds on 16mm Sinkpads mounted on a aluminium block, with a reflector on the led, not extemely accurate, but good for a general idea .I think at least I can compare results well to my earlier results with other leds. I ran out of Sinkpads so these are second hand and quite dirty, I guess they still work alright:
These new Nichia's test very well, but, as I can not measure it, I can not guarantee that the colour temperature and CRI of the leds, as given by the Kaidomain site, are correct (as I understood, Kaidomain is notorious for wrong descriptions). However, as far as I can guess by eye (I have seen a lot of led tints), the high CRI one could really be high CRI (nice tint and colour reproduction), although the tint is a tiny bit cooler than the 'old' Nichia 219A 92CRI, when compared directly (if I mount it in a flashlight one of these days, I can see it better). For real answers on tint and CRI maybe we should ask texaspyro for some thorough colour testing of this led on his fancy equipment?
In the 'high CRI' graph I compare the 92CRI 219b to the old 92CRI 219A (measurements from some time ago) because that is the most interesting comparison. In the 'cool white' graph I compare the 5500K 219b to the XP-G2 R5 0D-tint (measurements from some time ago) because that would be its closest competitor. Here they are:
If this led is the real thing (4500K and 92CRI), it performs way better than the old 219 in every aspect: considerably higher output at any current (up to 3.4A not that far from a cool white XP-G2 actually), it reaches maximum at a higher current, and the voltage is way lower, lower even than the xp-g2.
The Nichia 219 5500K compared to Cree XP-G2:
Also this is impressive, up to 3.2A its output is a bit over the XP-G2 R5, but at a lower voltage Smile . Up to 3.4A the Nichia is more efficient than the Cree, and current regulation in a single Li-ion flashlight will be easier. The XP-G2 is still lord and master at the higher currents, so for the extreme flashlight builds it will be around for a while.
But does the Nichia dedome? I had a go some time ago on a 219A 92CRI led and that dedome worked ok, but a shiny thin layer of silicone was leftover on the die. Well, this time it went no different. I heated the 5500K 219b board up on my heatblock 'till the solder melted, took the board off, pushed it down with a piece of cardboard, cut the dome in from the side with a scalpel and popped the dome slowly off. Same stiff silicone as the other 219 I dedomed, much stiffer than Cree. Some silicone was left on the die, tried to remove some of it with a scalpel, but not everything came off. So this Nichia does not dedome as neat as the Cree dies (perhaps the gasoline methos works a bit better??), but the dedome was done and the led still works. First a comparison of the die size with a dedomed xp-g2 (the Nichia die is bigger, not promising for throw..), and then the die at 10mA, the tint has turned a bit greenish  :Sp .
Photoshopped:
Next is build it in a C8 pill at 3A for a real life test. Hang on, that may take a week, I'm busy and tired...
And I guess after confirmation of the CRI (how? Sad ), it is also time to rebuild my 1x18650 Nichia 219 high CRI triple for some more than doubling the output....
Edited by: djozz on 09/14/2014 - 07:47
MRsDNF
MRsDNF's picture
Last seen: 7 hours 1 min ago
Thanks again djozz. How did you like the tint?
djozz
djozz's picture
Thanks again MRsDNF  for the quick reply (to all my threads actually Smile )
I liked the tint of the '4500K 92CRI' one very much, very neutral white without the 'rosy' tint that the 219 is famous for. I have not payed much attention to the 5500K led tint yet. I dedomed one (so that one is destroyed for tint asessment), I will have a look at the other one soon.
Omega_17
Last seen: 10 hours 20 min ago
So this were true ! Impressive ! Maybe one day Nichia will make a bigger LED to compete against XM-L ?
KD also sell triple Nichia! This is Cheap ! This should be the ultimate high quality flood light . Love
OscarM
Last seen: 2 years 1 month ago
Interesting! Thanks once again for your curiosity djozz!
I’d like to see a mod with the triple nichia board, will old-lumens do one soon perhaps?
Chloe
Chloe's picture
Last seen: 3 years 4 months ago
Thanks for the graphs! ^^
phantom23
phantom23's picture
Last seen: 3 days 17 hours ago
Thanks for your wotk. Is there any chance for some beamshots? Quick mount with any free reflector, pointed at some colorful object so everyone could judge is it really high CRI.
RaceR86
RaceR86's picture
Last seen: 3 years 9 months ago
WOW..  If the Nichia 219B really is 92 CRI then its a HUGE step forward.
Being able to easily get 500+ high cri NW lumens out of a single cell light...  Me likey!
The 5500K Nichia looks really good on paper too!
This also open up new extreme possibilities with those 20mm triple TIR optics.. J)
Love
Thanks djozz! Looking forward to hear more about your subjective thoughts when you get the time.. Smile
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
moderator007
moderator007's picture
Last seen: 3 hours 59 min ago
Looks like I may be replacing a few old Nichia’s in some of my lights.
Thanks for sharing your work here Djozz, much appreciated. Wink
led4power
led4power's picture
Last seen: 16 hours 19 min ago
Nicha chip is obviously bigger than 2mm^2.Could someone calculate exact die size from pic? It looks like 3mm^2 at least.
djozz
djozz's picture
I took out my trusty ruler, the surface area of the Nichia219b die from the picture measures 1.3 times the XP-G2 die. so with the same output, throw should be 23% less.
ChibiM
ChibiM's picture
Last seen: 13 min 44 sec ago
Thanks Djozz for the tests!!! Highly appreciated!
Now I'm looking forward to hear more about the CRI.......
djozz
djozz's picture
I devoted quite some time in finding out how to reproduce tints and CRI on the internet, and although it is possible to show differences between leds, it is just not what is happening in real life. I had a discussion with RaceR about the usefulness of an as good as possible representation of led tints on colour charts and photo's, and although despite the quite disappointing results I still thought it was worth the effort, RaceR thought not. But it gives an idea how hopeless it is, especially if you want to demonstrate CRI with pictures, high CRI leds look nearly as good as any neutral led in such a picture while in real life it is so much nicer...
djozz
djozz's picture
Omega_17 wrote:
So this were true ! Impressive ! Maybe one day Nichia will make a bigger LED to compete against XM-L ? KD also sell "triple Nichia ":http://www.kaidomain.com/product/Details.S022933! This is Cheap ! This should be the ultimate high quality flood light . :love:
Mind that the triple that KD is selling is the with old type 219A, great emitter up till now, but with this new option I would not want it anymore. Great price though Smile
jmpaul320
jmpaul320's picture
Last seen: 23 hours 13 min ago
lower forward voltage, and more lumen!
WIN
Would you mind keeping the wrong flashlight?
Best wish, May
Tmart service team
Soumil wrote:
PLEASE HELP ME GEARBEsT! IM LITERALLY CRYING!
RaceR86
RaceR86's picture
You must have misunderstood me. I personally found the charts very interesting. Smile I was the last one posting in that thread too..
I just did not think that using the same white balance for emitters in the 7000K and 3000K gives the best comparison when comparing various and completely different emitters ability to render colors (CRI).
If the white balance is correct for two different tints (basically white should be proper white) it will be easier to compare their ability to render colors correctly. Especially if you have a benchmark (100 CRI picture) where the WB is correct too (again, proper white).
If you want to get some sort of visual point of view, then the approach with a fixed daylight setting is "ok". Im saying "ok" because there is no great way capture tints like the eyes perceives and adapts to various tints. For a CRI comparison, id say correct WB on all pictures is easily the best way. But there as still challenges......
At the end of the day, it would not be easy to distinguish a 92 CRI and a 80 CRI emitter with certainty anyway. So your subjective thoughts would be good enough for me. You have lots of experience with various emitters and tints. The best way is always to personally experience tints in real life and in various environments anyway. Smile
djozz
djozz's picture
Thanks for explaining RaceR86, in the end this all means: tint photography can be useful, but only bleakly reflects what we see in real life..
comfychair
comfychair's picture
Last seen: 3 years 7 months ago
And even if you manage to get a picture that accurately reflects what you see in real life, it may look completely different on somebody else's monitor. There's likely a bigger difference between two different monitors than between two similar LEDs.
Hikelite
Last seen: 21 hours 16 min ago
That is huge variable indeed, different panels (TN, various IPS), personal settings (brightness, Kevin of the monitor), browsers often times do not display colors well. Most monitors are bad anyway even if you can say "I see rich colors"
comfychair
My pictures, with my camera and as displayed by my monitor, only look 'right' with the white balance on the fluorescent setting. They may look like harsh blue-purple utter crap on everybody else's monitors, who knows. Using the daylight setting on the camera gives something that looks like it's from the 1940s.
Pulsar13
Pulsar13's picture
Last seen: 7 months 2 weeks ago
Djozz, how well do you feel the emitter maintains its CRI level throughout increasing current?
I have several 119s and 219s and I just somehow feel the higher the current, the less pleasant the tint becomes.
ImA4Wheelr
Last seen: 2 weeks 2 days ago
Great info as always.  Thank you for the testing djozz. Smile
mattthemuppet
Last seen: 3 weeks 3 days ago
thanks for the review djozz, that’s a huge help. More output and lower Vf are huge improvements. I wonder how the 92CRI 219B would compare output wise to an XP-G2 R3 3C or 4B? I was thinking about one of those with an XM-L2 T6 3C for a new bike light, but if I can get higher CRI with the same output (throw is not such a big deal) then the 219B looks like a good alternative.
djozz
djozz's picture
Disappointment!
I put the '92CRI' 219b in a AA-host with a BLF-mini driver (it runs at 1.3A on a Li-ion) to compare it to other lights, a ssUFc3 with a 'old'219Ahigh CRI Nichia also on a BLF-mini driver, a sk68 clone with a Osram Oslon SSL80 4000K 96 CRI led, and my old Xeno03 modded with XP-G2 3C (5000K).
(left to right: Xeno with Xpg2 3C, AA-host with KD's 219B, sk68 with 96 CRI Oslon, UF with old 92CRI Nichia 219A)
I did some thorough comparing by eye, and I am afraid that I am not convinced that this led is 92CRI. It sure is a nice tint, but it does not have the warm yellow and red that the 'old' Nichia 219A 92CRI and the Oslon SSL80 96CRI show. In fact, it is very much like the XP-G2 3C (5000K) that is in my Xeno03 at the moment, a tiny bit less yellow, and a tiny bit more red, so it might be a 80CRI 5000K led.
I tried to capture the comparison in a photo of some colourful objects, but although I could easily see the difference by eye, it does not show on the picture.
I do give you a beamshot comparing KD's 219b on the left, and the old 219A on the right, not because the tints that show are exactly what I see by eye, but because it does show that the tints are quite different.(you see some PWM on the left beamshot because the light was on medium mode)
So what should i say? The tint comparisons I just did are not scientific enough to proof that this led is not 92CRI, although I can not imagine how you can make a 92CRI led with visibly less red, and paler yellow in it than the other highCRI leds I compared it with.
So sorry, all my subjective senses say that this not the 92CRI one  :_(
THE_dAY
Last seen: 2 days 4 hours ago
Appreciate all the great info djozz!
How does this 219B render skin color, is it closer to your XPG2 3C or more like the 219A?
Thanks
moderator007
I was almost ready to pull the trigger on a few of these, thanks for updating and letting us know about the tint Djozz. Wink
djozz
djozz's picture
THE_dAY wrote:
Appreciate all the great info djozz! How does this 219B render skin color, is it closer to your XPG2 3C or more like the 219A? Thanks
That was a tough question, I just tried that out, those are subtle differences you are talking about! The only reason I can answer this is because the three lights these leds are in can be set to a very similar output and have a very similar beam pattern. And the answer is that it is closer to the XPG2 3C. (When CRI is going down -at least caucasian- skin appears less natural and more towards 'dead body'. These leds still all have nice tints, and do not quite make you look dead, but slightly less natural than the 92CRI one: yes Smile
(off to bed now, sleepy!)
skyrider1
I was also about to jump on these and build up a triple. Looks like we will have to wait for IS to restock them.
The non-high-cri nichia though still seems very promising as it provides about the same/more lumens at a lower Vf than the xp-g2. I guess there would be less throw but it should still throw decent. I don’t know nichias very well but do they have something in the 5A tint region?
RaceR86
RaceR86's picture
Its really though to compare these things.
I have two examples where emitters with good or high CRI were a bit disappointing.
XM-L2 7D3 (90+ CRI), from IS.  Just too yellow for me. Subjectively I found the 7A3 (80+ CRI), from Convoy Aliexpress guy. It had way more red and rendered colors better. I just liked the tint better. The balance between yellow and red where better, making it more "white" in a warm sense..
The XM-L2 6A1 (80+ CRI), from IOS. Is the most pink emitter I have ever seen. It lacked to much yellow IMO. and a 75 CRI emitter would visually be better for me.
So I would say that you can get emitters that have good or high CRI, but visually don't render colors like you prefer them do too.
Many of the emitters thats got a bit extra on the  red side are great for tint mixing with other emitters though. The reason why I like the tint from MT-G2s and my tint mixed Supfire M6 is because the beams are both quite white looking within their temperature (K) range. Despite both being around 70 CRI.
My point is, if the tint is "right" you can get away with lower CRI and still perceive the beam to be comparable or even better than a light with better CRI in normal use. At least that is how I perceive it.
I thank you for your subjective thoughts djozz. Im not a fan of KD, so im sitting quite nicely up on the fence for some more time.... I like the typical NW Nichia 219A and the cheap WW 119 because of their ability to render red nicely too, the emitters you got does not same to have this "trademark" that I consider typical for the Nichias Im using.. So, like you say, sounds a bit disappointing, in terms of tint..
djozz
djozz's picture
Apart from tint differences that you can prefer or not, what the 90+ CRI emitters that i have seen sofar all have in common is that they show blue as real blue and not purple-ish, and at the same time show yellow and red as really bright and vivid as well, not pale. Non-90+CRI emitters can be really nice and pleasant, but fail in one or the other. This KD Nichia shows blue as real blue but clearly is not as good as the other two 90+CRI leds in the red/yellow area.
kralyevski
kralyevski's picture
Last seen: 3 weeks 4 days ago
i think that main problem in this situation is the sensor of a digital camera, if you have custom white balance setting on your camera in which you take control shot of white card (or any other object that you know is white) the camera automatically compensates and the two pictures taken with high CRI and regular non high CRI LED will eventually look the same, on the other hand if you use same white balance setting for both LEDs ,again it will not represent the real life experience…i guess the best way is to take picture with custom white balance set on bright sunny daylight and then wait for the night but keep the same settings and take pictures of the same scenery in the night with different LEDs (at least in this way the differences will be shown but again i’m not sure about accuracy with real life experience…i have the cameras but i still haven’t decided which nichia 219 should i get (sportac triple dropin or IS bare LED’s if they are available again or to try some of KD…) EDIT: i will take djozz’s word and pass the KD 219 as it is not the high CRI
“the easiest way to become a MILLIONAIRE is: first you become a BILLIONAIRE than you start to be flashaholic”
