what is the easiest way to discharge single 18650 Li-ion cells?
9 posts / 0 new
Hot Brass
I have a few single near full 18650 Li-ions that I would like to discharge(run down) for storage and be able to monitor the voltage with my DVM,so obviously installing inside the light and turning on won’t work. Can I rig up something using a battery holder and maybe hooking up a bare bulb in between the + and -?. I want to be able to monitor the voltage as it’s running down. Something easier? Thanks,HB
LowLumen
Last seen: 1 day 7 hours ago
A 10 Ohm 10 watt power resistor would drain at about 400mA rate.
V/R=I
4V / 10ohm = .4 Amps.
comfychair
comfychair's picture
Last seen: 2 years 1 week ago
Monitoring the voltage while it's running against a load won't tell you much, you need to know the open circuit resting voltage, so just run them in a light and remove to check the voltage every 10 minutes or so. After 1 or 2 you'll have an idea how long it takes to drop how much voltage, so you won't have to stop to check as often.
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 3 weeks 2 days ago
WarHawk-AVG
Hot Brass
Thanks to all who responded! That battery University link is great! HB
hank
hank's picture
Last seen: 6 hours 20 min ago
Followup question from the Poll (left sidebar) “how do you store your batteries?”
http://budgetlightforum.com/node/54889/results
Which favorably viewed chargers have the “lithium battery storage” function?
When I have cells to store, I’ve been running cells down, then charging them at the 3.2v/LiFePO3 setting (Xtar VP2 charger) and figuring that’s about right for storage voltage.
But it gets tedious that way.
flydiver
Last seen: 12 hours 40 min ago
3.2v is on the low side if shooting for50%.
I don’t know of anything but hobby chargers that have storage function. It would be great if one did.
RobertB
RobertB's picture
Last seen: 3 hours 38 min ago
Seems like it would be a simple addition to have a “storage” function on something like an opus charger, that would discharge or charge to 3.6v.
