Dereelight DBS V3 XR-E aspheric vs Solarforce Masterpiece Pro-1 XR-E
12 posts / 0 new
2100
Last seen: 1 year 6 months ago
asd
asd
Edited by: 2100 on 06/14/2011 - 07:56
2100
MPP-1 = 2 cell.  (to get the most lumens, spec is 200 lumens for 1 cell, 275 lumens for 2-cell)
DBS aspheric = 1 cell.
Distance = 6m
They measured the DBS aspheric to be about 55-60K. SR90 would be about 100K.
gcbryan
Last seen: 1 month 4 days ago
Do you have the lux measurement for the Solarforce?  How do the two seem to compare as far as throw when you take them out at night?
2100
gcbryan, i do not have the lux/CP measurement for the Solarforce.   Would really love to get one someday, but the Manafont does not seem to be that accurate. (they have more reviews on the same one at DX)  Good ones cost 100+ range doing up to 400K lux.  The Lodestar lightmeter at DX/manafont goes up to only 20K.  Good for LEDs @ 10m, but useless for high powered HIDs.  Unless you do not mind doing longer distance measurements.
But basically most of the well-known lights have known figures.  The Solarforce seems to be in the 50k CP range.  At long distances like 400m on a white building, both are at their limits in a bright cityscape environment. The MPP-1 is somewhat dimmer than the DBS aspheric.  When its a hazy night and you point it upwards at the dark sky to see the beam cutting through the air, the DBS is somewhat brighter as well.
 http://www.candlepowerforums.com/vb/showthread.php?311939-Consolidated-Short-Arc-amp-HID-spotlight-Lux-readings
2100
The cheapest 400K meter that I Can find.
http://www.aliexpress.com/product-fm/459718221-free-shipping-Environment-Test-Meter-Light-Meter-Light-Meters-DT-1309-wholesalers.html
AT least for 50 bucks you can do 50k...not too shabby.   CEM meters are decent Made In China meters, like Uni-T.
SirJohn
SirJohn's picture
Last seen: 6 years 9 months ago
FWIW - Bigchelis at CPF said he measured 48k lux for the Masterpeice Pro 1.
2100
Yep...its about there.  It should be 48K CP.  You can do 1m readings, but let the beam spread a little to do its thing. Big reflectored HIDs do not spread out and do their thing below like 6m.
Example: Lux meter reads 10,000lux @ 10 meter distance, CP=10,000x10x10= 1 Million CP
For the MPP-1, you need to be using at least 2-cells charged up, ie above 8V, to max it out.
50K lux meter would be great. 10m measurements will get you up to 5 million CP.
 If you play short arcs then 400k lux meters is a must or be prepared to run a lot.
The Lightpipe 250 narrow spot 7" reflectored 5mm gap 250W HID MH probably would be hitting at least 6 million CP mark.
Mozo Mega HID, 75W Mod, 6" Reflector, Philips 4300K lamp 1.7 Million cp
2100
Here's the deviation of the CEM DT-1301 amongst other light meters
http://www.candlepowerforums.com/vb/showthread.php?94232-Light-Meter-Benchmark-Testing-%96-CPF-style
gcbryan
Any idea of the lux reading for a Uniquefire HS-802 just as a way of comparison? I have that light.
Don
Don's picture
Last seen: 3 years 3 weeks ago
Mine just drew 30mA on high after I got it to light up at all. With an XM-L and a 3A driver it seems I have not yet measured it. Beamshots here.
http://budgetlightforum.com/node/1539
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
SirJohn
SirJohn's picture
I think Budgeteer pulled 31k on his HS-801 but I should let him confirm that.
gcbryan
Measuring from the battery I get 800mA on a 18650 measuring 3.9v. I just measured another 18650 XR_E R2 light and I got 300 mA. Maybe it's just my measuring equipment that isn't very accurate?
Both are very bright and throw far. I've never been clear as to the connection between amps drawn at the battery and at the emitter.
