Just another Copper Smoothie scratch build It's Done, with beam shots
57 posts / 0 new
Old-Lumens
Old-Lumens's picture
Last seen: 3 years 3 months ago
Probably thinking about a 2nd. Annual BLF scratch made contest, has made me decide to do another copper light. I haven't done one in a while.
csm1a
Sometimes I think the most fun builds are ones that I have made out of Copper pipe and fittings. Of course, they are usually the most trouble as well. This one will be no exception to the rule.
It staredt out as some 1" and 3/4" copper fittings and some 1" copper pipe, with a P60 drop in and an XM-L of some flavor. The "head" is a 1" copper coupling and a P60 reflector is too small to fit tight, so I have to use something to shim the diameter of the pipe. A 28mm lens fits right in a 1" coupling, but it has to be held in and the list goes on. Nothing really fits well and it all has to be shimmed and coaxed to fit.
csm1b
I wanted the brass base that holds the led and driver, to be tight to the ID of the 1" coupling. That resulted in a bunch of cutting and soldering. In the mess shown in the photos above and below, are pieces of 1" coupling and some pieces of copper sheet, to make the OD tight in the ID of the head. Of course, there's a lot of fitting and trial and error to get the OD just right and it might not look pretty, but I have a ways to go in finishing it up.
csm1c
csm1d
The 28mm lens is in place and it can't be taken out without desoldering it. The ring holding it in was another thin piece of 1" coupling that was split and sized to fit inside the head and hold the lens in.
csm1e
The inside shows some copper sheet that makes the diameter for the reflector to sit in and it is against the bottom of the lens, so the lens is sandwiched in. The reflector will go up in and touch the lens from underneath.
I still have not decided if I want a 18350 shorty or an 18650 light. If it is an 18350, I will probably keep the amp draw around 1.5 amps and if it's an 18650, I will go with 2.8 amps. I am also leaning towards a momentary side switch, so the light only comes on when you are holding the switch. It might not be appealing, but it would be different. I just don't know yet.
01-28-14
csm2a
This is the tali section. It's just a two piece light. The tail cap and the body are one piece.
csm2b
The spring is soldered into the tail cap. The assembly consists of a 3/4" pipe, 3/4" coupling and a 3/4" end cap, with copper pieces soldered on the outside, to make it fit into the 1" head.
csm2d
It will take a single 18350 cell.
csm2c
The large diameter of the body, fits into the head and I will be making slots in the head and pins in the body to fit. It will be the same as several other copper lights, where 1/8" brass pins locate into "L" shaped slots, so the parts can mate and a slight twist locks them together.
csm2e
I will be using a momentary SMD switch and a DrJones driver. I have made the switch hole and I am showing where the switch will go, in the photo below.
csm2f
A little at a time. I might have it done this week, if all goes well.
 01-29-14
sc1a
So, I worked on cutting myself first, to get that out of the way and then I worked on finishing the pill. 3.04A DrJones driver.
sc1b
SMD switch is in place. Everything works by the way.
sc1c
XM-L of some flavor on a 16mm Noctigon.  The End!        So, I thought, Hey, I'm really getting it done. Might be through tonight.
You know what that means.....   SO I shoved the pill in the head. Goes in smooth, till the reflector gets into the front end, where it goes into the stepped down area, where the reflector will be centered and tight. Ok, I planned for that. Tap, Tap, Tap, just a little at a time. Looks good, getting very close, but it needs to go just a hair more, to fit up tight to the lens........  Tap, Crack!Surprised   Kinda figured didn't you.Tongue Out
What happens when you crack a lens that you can't remove, because you soldered the bezel in place?   I usually turn the air blue, till I can't see the damage any more.Yell
Anyhow, it really was a good thing. I should have never gone with a fixed lens, because Murphy is always watching and waiting. Bad part was that in order to knock out the pill, I had to ruin the reflector. Good thing I have One More..... Oh, I shouldn'thavesaidthatwhileMurphyislistening....
When I fix it all, the lens will be held in with some Epoxy, so when it breaks again, I can just heat up the head a little and dig out the epoxy.
sc1d
So, I spent the rest of the evening getting the body/head joint drilled and filed the slots for the brass pins to fit into. Still needs fine finishing, but maybe Thursday or Friday night.
sc1e
1or
Added an "O" Ring groove
01-30-14
cop1a
Brass pins are soldered in from the inside
cop1b
Fits together well and it's done.
copd1
copd2
copd3
That's it. Except for beam shots.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Edited by: Old-Lumens on 01/31/2014 - 01:56
Old-Lumens
copb1
HIGH
copb2
MID/LOW   It seems to have both a green and blue tint at the same time. This one is probably about 7000k, but I'm not about to tear it apart now. It is the way it is.........
copb3
copb4
copb5
edeekeos
edeekeos's picture
Last seen: 10 months 4 weeks ago
Oh man, this is gonna be GOOOD!
MRsDNF
MRsDNF's picture
Last seen: 20 hours 10 min ago
Without me saying, you know I’m lost already. Looks interesting.
Ouchyfoot
Ouchyfoot's picture
Last seen: 3 weeks 1 day ago
Justin. Don’t you wish the flashlight industry and the plumbing industry would come to an agreement and synchronize the sizing of their parts?
Rufusbduck
Rufusbduck's picture
Last seen: 1 year 2 weeks ago
Steve, the recipe call for 3 shots of tequila and 4 lime cubes not 3 cups of tequila and 4 beers. Heaven help us, you’re not following, you’re leading the way. Looking forward to another copper classic. Nice bezel!
Scott
Old-Lumens
Ouchyfoot wrote:
Justin. Don't you wish the flashlight industry and the plumbing industry would come to an agreement and synchronize the sizing of their parts?
Yep, but the bad part would be the inconsistent and bogus lumens ratings on all copper pipe and fittings!
davidad
Freezing your old butt off yet Old?
DB Custom
DB Custom's picture
Last seen: 6 days 22 hours ago
That looks really sweet, smooth as a whistle, gonna be a nice light for sure.
I vote for the 18350 for whatever that’s worth. A nice little pocket light with a recessed momentary. Yeah, that’s the ticket! Wink
wetland
Last seen: 6 years 2 weeks ago
Class is in session H) Looking forward to the learning experience. Subscribed
DayLighter
DayLighter's picture
Last seen: 2 years 10 months ago
As always.. I can’t wait to see the finished product.
But whatever it is, I’m pretty sure it’s going to be an amazing stuff coming from Old-lumens factory Big Smile
The only way to do a great work is to love what you do.
DB Custom
DB Custom's picture
Look up Brownell’s online, get yourself a checkering file, cut handmade knurling in the copper body. Smile
Old-Lumens
DBCstm wrote:
Look up Brownell's on line, get yourself a checkering file, cut handmade knurling in the copper body. :)
Tell you what, I will send it over for you to checker/knurl after I get finished with it.
Actually, I already tried that once. It didn't come out well at all. It's much nicer doing checkering on wood. I don't think I still have all the checkering tools. I believe I gave them to someone else.
Old-Lumens
It's cold enough. Still better than August heat.
FlashPilot
FlashPilot's picture
Last seen: 16 hours 56 min ago
As with all your threads… subscribed. :bigsmile:
DB Custom
DB Custom's picture
I wonder if a sleeve could be utilized, slip a carbon fiber tube over the smooth body…
Just wondering, that’s all! No thanks on the checkering, last time I tried that my Glock 23 went full auto! EEK!
Old-Lumens
01-28-14   Updated the OP
Rufusbduck
While the master works the apprentices watch.
Scott
MRsDNF
MRsDNF's picture
I wish that l was smart enough to be an apprentice to the master and his apprentice. I love both of your works.
Your light is coming along amazingly creatively OL.
Old-Lumens
Other way around is more like it. Those fins you do are the best thing since sliced bread.
DB Custom
DB Custom's picture
Love how you think up the solutions to the standard problems. All comes together so easily…well for us it appears to anyway! Well done, this should really be a nice looking light. Maybe you should collaborate with Scott and get it some custom made copper cooling fins? Jam for the sliced bread…
Tom E
Tom E's picture
Last seen: 18 min 50 sec ago
+1 - loving this so far...
TexasLumens
TexasLumens's picture
I, as always, stand amazed at what you can do!! Surprised
Anxious to see the finished light!!
Dan.
Texas Lumens Website… http://www.texaslumens.com
WE LIVE IN THE LAND OF THE FREE ONLY BECAUSE OF THE BRAVE!
noboneshotdog
Last seen: 8 hours 13 min ago
Your a SICK man OL, and I love it!!!!
Thier ain’t no bones in a hot dog. F. York
Rufusbduck
Where do you get those cool little switches? And do they make one with the button on the side?
Scott
TexasLumens
+1 and the cover Please!!  Tongue Out
Dan.
MRsDNF
MRsDNF's picture
Dan.
The best and cheapest place to get cool switches from is to place switches in the fridge for about two hours. For really cool switches they go in the freezer for about the same amount of time.
DB Custom
DB Custom's picture
Wise Guy huh, Why I oughta…
Rufusbduck
Do they ship them in freezer packs or do you have take dorky ones and chill them yourself?
Pardon the interruption, OL. We’re dealing with a wiseroo here.
Scott
TexasLumens
MRsDNF wrote:
Dan.
I think our Aussie friend has stood on his head ...AGAIN.... just a little too long! Tongue Out
Dan.
Old-Lumens
01-29-14 Updated the OP.
