Review: Black Diamond Storm Headlamp
OK, this isn't exactly budget but it's not the most expensive either. At some place like REI it would be around $49 but you can get it a bit cheaper online.
I'm not a fan of overpriced lights (which is why I'm here) :) I'm a bit pickier with headlamps than with flashlights however. Or rather I think budget flashlights are better than many budget headlamps. Also I guess something strapped to my head needs to be a little nicer than something I hold in my hand :)
The Storm has a high of 100 lumens and a low of 4 lumens on the spot beam. This is a Cree XP-E. The brightness is infinitely adjustable via ramping.
There is also a flood mode using two SMT emitters. This has a high of 25 lumens and a low of 4 lumens. This is controlled by ramping as well. There is a red LED and well as a strobe. You get to the red LED mode without having to go to a white light mode first. There is mode memory for the red LED as well.
Both the red LED mode and the white LED modes have strobe. This is triggered only if you click the single button 3 times rapidly when the light is off.
Since many people will use this in a backpack for hiking/camping it has a lockout mode. You press and hold the button for 6 seconds and now pressing the button will not turn on the headlamp (accidentally while in your pack).
The flood mode is very pleasing as it is extremely wide angle . There are two flood emitters. One on each side of the headlamp so the beam angle is greater than your peripheral vision. When outside at night this makes you forget you even have the light turned on. It just seems like the moon must be full that night. As you move around you don't see the edge of the beam since it is so wide and since it diffuses naturally. It just seems like the light must be coming from above.
Red mode is triggered by holding the button in for 3 seconds so you can turn this mode on in the dark in your tent without having to worry about accidentally triggering a white light and messing up your night adapted vision.
It runs on 4 AAA batteries but is similar in size to 3 AAA headlamps as one battery is tucked under another.
The Storm is waterproof (rather than just water resistant) and is current regulated as well for the first 25% of battery capacity. After that it falls out of regulation for a longer run time. It also can run on lithium AAA's which makes the headlamp even lighter (also good for cold weather operation). Unlike most lights of this type and size it actually has a small metal heatsink.
I've seen some question the need for a strobe in a headlamp. I'm no big fan of strobe in flashlights particularly if they aren't hidden. It's not a bad thing to have in a headlamp in my opinion although certainly not a deal breaker for me if one doesn't have it.
If you are hiking and get lost/injured you can hang the headlamp with strobe on nearby to help rescuers locate you. I've actually used one along a deserted beach (3 miles of beach) to locate my campsite which was off the beach up in the woods. We hiked with one headlamp on and left one in strobe mode directly in front of where we had to leave the beach to pick up the trail back to the woods and to our tent.
Some bicyclists have used the headlamp in red strobe mode on the rear of their bikes as an aid to help cars see them.
I more or less still consider the Storm to be budget given all of the features incorporated into this one headlamp. You can hike with it, change to flood mode and put it on low and use it in your tent and around camp. Since I have it already I've used it around the house for things I would have just done before without adequate light.
I have to cut my cat's nails every now and then. This is one of those things best done quickly and efficiently :) I can do it without task lighting but now I see it goes so much more smoothly with adequate lighting. I've ended up cutting the grass a little later than I normally would be able to since I can now just finish up with the headlamp. I've also gone on more night hikes and when rock climbing I don't have to rush so much to either get off of the rock or out of the woods and back to the car before dark.
I've had flashlights around (and I've used headlamps for specific purposes in the past...mountain climbing) but recently I've just found them more useful than flashlights in many cases because I usually need to use my hands and flashlights don't make that easy. Changing a tire at night is so much easier with a headlamp. I guess the difference is that now headlamps are so much brighter, smaller and nicer than in the not too distant past.
If you want another quality headlamp that is more budget then the Princeton Tec EOS can be had new if you search around online for $30 and it is regulated, waterproof and has 3 brightness levels along with strobe and a high of 70 lumens.
These are the two best deals regarding headlamps that I know of. If you don't hike/climb and mainly use a headlamp around the house/yard maybe these do cost more than you would consider budget but if you're out in the mountains at night I think these are budget as in a good value for the money.
good review. thanks!
i think i'll be picking one of these up for night fishing. the red LED should be good for riggin/retying without losing my night vision. hopefully, the waterproofness holds up to the surf and rain.
my wife works at REI so i can save some $$$!
excellent review gcbryan , I have the EOS paid $100 au for it a few years back and that was discounted SurprisedI had to travel 100km to buy it the next town to save $50 , thats right $150 for EOS in my local store ..bloody rouges ..its still goin strong had heaps a work good headlamp and worth the $100 yeah I was ripped off but thats australia for ya . so if you can the eos for $30 I say snap it up thats a bargain
You cut your cat's nails??? Sorry off-topic... but you cut your cat's nails???
It's an indoor cat. You've never heard of the concept of clipping a pets nails? If you haven't and you have an indoor cat I would imagine your furniture has to be replaced often :)
I never thought I needed a headlamp but I find myself using one of these 2 all of the time in fact more than any other light I have. First option.
http://www.dealextreme.com/p/high-power-ultra-bright-3-mode-led-headlamp-3-aaa-52698
In true BLF fashion this headlamp can be had for $13 add a 20mm XML for $10 dollars and five minutes of soldering and you have a 400 lumen budget light that blows away anything I have strapped to my head. Weakness is the 3aaa batteries gives lousy run time but makes it a very light weight package.
This new light just appeared on deal extreme and it appears to be the P-60 mod drop in light. That is right take it apart and a P-60 drop in fits I have an older version a little aluminum foil to wrap the drop in all that is needed and the sky is the limit for lumens. Again 3aaa is the weakness but it makes for a lightweight headlamp.
http://www.dealextreme.com/p/cree-3-mode-white-led-headlamp-3-x-aaa-100925
Simply discard the reflector and the piece to the left of it and this $10 light takes any P-60 drop in I am sure you have a spare one kicking around.
I'm not a big fan of the battery in the back, wires, and over the head strap style of headlamp but if they were going this way you'd think it would at least use AA's rather than 3AAA's.
Yeah, it shouldn't be difficult to make a new holster for AA'S anyway.
I bought this one instead that might match your criteria:
http://www.buyincoins.com/details/3-mode-zoom-aa-14500-headlight-torch-light-headlamp-9-product-3043.html
I have not received it yet so I cannot tell you how good it is, but theorically will not have problems with heat as it is entirely made of aluminium, so replacing the led to an XM-L with the existing driver should not be a problem.
1 AA will give roughly the same runtime as 3 AAA's, and a 14500 just a bit more, so this would be again the weakest link.
I will probably add a third strap over my head, because unless headlamps are too light, keeping them in place while walking will not be easy, and it will probably move a bit, or I might try to tight it too much to my head which would be uncomfortable, a third strap should prevent it.
Here you can see the headlamp assembly in case you like it:
(It is in russian from a DX review)
Cutting a cat's nails is not an odd thing but my two cats would never hold still for it. It's all we can do to get them shaved once every couple of years, they freak out so bad.
Foy
The P60 drop in light is long overdue for an 18650 conversion. I am just trying to find a cheap $10 dollar headlamp that takes an 18650 so I can use the battery holder.
When I was married we had an indoor cat but we could never cut his nails. I got divorced and my girlfriend came over and picked up the cat and cut his nails with no problem...I couldn't believe it!
She showed me how and I was able to do it. This was with a 16 year old cat by the way. I now have a newer cat and from the beginning I cut his nails even when he was too young to need it. He got used to it from the beginning and doesn't particularly mind it. It's an art however!
It's an interesting project (and nice pictures by the way). They are always looking for a P60 drop-in headlamp over in the Headlamp forum at CPF. You should go over there and direct them over here. :)
It always seemed a little large for me and I don't need more lumens but people use headlamps for many different purposes and I'm sure there's a lot of interest in this.
I'm just glad to see more people talking about headlamps over here :)
I have 3 posts over there that include pain, scorn and ridicule. They can come over hear if they want a $10 dollar headlamp. Can you imagine, I have not seen the budget headlamp section. That thread would get buried quicker than a Hi Max battery review by OLD4570.
Haha...yeah, no budget headlamp section but the Headlamp Forum is much friendlier than the LED Forum which is the worst over there. Actually, most of the others are much better (and the moderators seem to leave the other forums alone more).
I know people who clip their cats nails. One of mine has to be sedated to take his temperature so clipping of the nails would be impossible. Last time I took him to the vet they asked if he was feral. He trashed the whole surgery when a thermometer was stuck up his rear end. He does weigh 8 kilo's and is so strong he can't be held down. I tried welding gloves and still came away bleeding.
My other cat was the same way. I couldn't take him out of the cat carrier until we were in the examining room and the door was closed. He would go nuts and I couldn't hold him or help the vet. The vet wore gloves and used a towel and there was a lot of cat hair flying.
Yet, that same cat who hadn't had his nails cut for 16 years let my girlfriend do it in my living room without a problem. If they are calm and don't feel threatened or held down it's amazing what they will let you do.
Even with my current cat I don't really hold him down forcefully. I just hold him and rub his head, talk to him, move calmly and hold him just firmly enough to cut the nails. If he starts to move I let him move around a bit and just pet his head again.
You have to sit down on the floor and hold him in your arms with him on his back as you might cradle a baby. It's hard to explain. I'm sure a family member could clip your cats nails. It's all in the technique.
Cats just don't like surprises and don't like not being in control :)
"Feral? no. but I do have 20 laser pointers at home..."
I have a very low power red laser (bought 15 years ago) and my cats go absolutely nuts chasing that thing. They will slam over lamps, rip down curtains and actually hurt themselves skidding into walls trying to take a corner at mach 1. Can't do it very often - too much carnage.
Foy
This post is almost 6 months old I kind of doubt he is going to post any pictures if he hasn't all ready, but nice try.
Haha…picture added. No beamshot however. If I was trying to sell this headlamp I’d do that as well :slight_smile:
