How to indentify flashlight 's battery original or not ?
*This is one new kind of ecig battery charger and it has the following functions :
1: detects the battery internal resistance (standard capacity battery internal resistance 40mR-60mR, standard power battery internal resistance 10mR-30mR)
2: detects the battery capacity and voltage
3:automatic identification and dangerous bad battery cell (shown as NULL)
4 :There are two charging modes : 500mah ,1000mah, Apllying to Li rechargeable different type battery .*
Hi ECbatteryman,
If you can edit your post and move it to the commercial sellers forum it will be allowed to stay there.
Welcome to BLF.
Sorry ! first come to here ! i had moved to here seller spot .is that allowed ? thanks !
Where we can buy this? How much $?
thanks for your interesting ! you can email to me or contact with my skype :michaelawt18 .
can i know your quantity ?
Are you selling this to end customers or only to companies?
How much is the market price?
Have you already sent out some review samples?
both of them will be ok ! nomatter end users or distributors ! we would like to provide this charger to them !
for price ~!! it is up to order quantity !
sure ! we have sent the samples to USA customers already and get orders from usa customers !
If you want to get price pls check you PM ! thanks
I have sent you request for this awesome looking charger...
In fact I always wanted something like this... And I am probably not the only one ?
But this should be send to real pro like HKJ to make some serious testing.
Even if it will have +-5% on mah battery readings it will be acceptable to me...
Found this link on the charger …. :slight_smile:
http://www.aliexpress.com/item/2PCS-LOT-Liitokala-lii-260-18650-26650-Battery-Charger-Detection-of-Lithium-Battery-Capacity-internal-Resistance/1542697005.html
That guy from Ali is waaay to expensive! Who will ever buy that from him
ECbattery man answered me:
for 1-10 pcs price at FOB SHENZHEN USD 26/PC
I asked for sample order and now I am waiting...
*Hi guys !
This morning our company take the meeting and start promoting this charger (Feb 18-April 18,2014)
the following is the promotion price
*_1-20 pcs Price at FOB SHENZHEN USD 24/PC
_*
Also we have the 18350 rechargeable battery 18350 700mah .it has the same high rate cell with AW battery’s cell ! If have interesting contact with me *!
Also if any distributors or dealers have interesting in this charger pls let me know ! For wholesales or dealers price will be much lower !
It is a new intelligent smart charger. It has 7 functions:
1: Dual-channel independent charging
2: Battery capacity detection
3: Battery internal resistance detection
4: Anti-reverses
5: Short circuit protection
6: Overcurrent and zero volt battery activation
7: monitor the battery voltage automatically in a timely manner.
Engineer Lii-260 can fit a variety of different models of the cylindrical rechargeable lithium ion batteries. Widely used in flashlights, electric tools, instruments and other electronic products, batteries. Safe to use, portable, powerful, is your home and travelling a good helper.
First: Feature
a) Two charging current mode (500mA / 1000mA);
b) Batteries of different specifications can be charged simultaneously (18650/26650)
c) Each cell has a separate LCD display charging parameters;
d) Charger mode, different charge current;
e) Discharger mode (first full charge and then discharge), detects the battery capacity;
f) Charger and discharger two modes can be performed simultaneously;
g) Each battery can be charged simultaneously or independently set / volume detection;
h) Multiple display mode, the current (mA) / Capacity (mAh) / Voltage (V) / time (h) / resistance (mR);
i) With a dedicated power adapter.
Second: Button (MODE) description
a) Charger has two buttons, each of them control all the way, simple to use and more convenient;
b) In any case, press and hold the MODE button for 3 seconds to change Charger (charging) mode or Discharge (capacity test) mode. When lights again Pls Press to change current within 8 seconds. Selected current in 8 seconds will be into the working state. In working condition can Press (MODE) key to view the current (mA) / Capacity (mAh) / Voltage (V) / time (h) / resistance (mR).
Third: Run Mode Charge Mode (charging mode)
a) When the charger is working on, Charger’s LCD screen will become full brightness, if the battery is not loaded will show Null, if it is a bad battery in it will show Null too;
b) Put the battery into the charger, the charger will measure the internal resistance of the battery in about 3 seconds. After the system automatically enters the charging current selection mode the "500mA" will flashes 8 seconds. During this period through mode button to select 500mA or 1000 mA current for charging. Systems will lock the charging current in 8 seconds. If within the 8 seconds, did not make the setting. Then the system will automatically choose 500mA current for charging. At this point the current cannot be able to change, want changing the charging current it needs to reset the battery again.
c) Users should pay attention to the batteries’ maximum charging current. If you do not need fast charging. Recommended 500mA charging. This is a safe way also is better to the battery;
d) In charging mode. Press the mode button to switch view rechargeable battery (mAh) / charging time (h) / battery internal resistance (mR) / charge current (mA). After the battery is fully charged, will display “Full”. The last row of small print displays charge End (end of charge);
Fourth: Warning
1: Only charge cylindrical lithium-ion battery; don’t charge other kinds of batteries
2: Do not exceed the recommended charging current. Before use, please refer to the instructions carefully, pay attention to the batteries recommended charging current
3: Do not use other power adapters;
4: Charger may become warm during charging and discharging, be careful not to burn;
5: Finish using, unplug the power;
6: Use in door only
Engineer Lii-260 battery charger
Input voltage
AC 100~240V 50/60HZ or DC 12V
Input power
10W
Output voltage
4.2V ±1% / 1.48V ±1%
Output current
2X(4.2V 500mA),2X(4.2V 1000mA)
Termination Method
intelligent voltage monitoring
Dimensions
132mm × 65mm × 31mm
Weight
156g (without batteries and power cord)
Compatible with: Li-ion: 26650, 22650, 18650, 18350 17670, 18490, 17500, 17335, 16340(RCR123), 14500, 10440
Package including :
1 PC Engineer Lii-260 Charger
1PC charge adapter
1PC car charger
1PCWarranty Card
1PC Manual
Now more people want to get sample to test this charger !
We here thanks for your attentinon on this charger ! but, our company does not approve HK post or Sp post shipping ! We suffer lost on the post shipping .
Our company only approve the express shipping !
Sorry on this !
Are there any retailers who are selling this charger, ie, online Chinese stores that buy from you so we can buy from them?
hi !
i will tell my boss directly and want to get more support on this charger shipping !
Hope to get to more good news on this ! If our boss approve the HK post shipping and SP post i will post it at once !
Thanks again everyone !
at current there are no approved store for this !
sorry !
new photos
This is really awesome looking charger, all in one functions,
You know that I would buy it but talk to your boss for HK registered post. I really doubt he will have loses with this post since 90% of members here on forum doing business with that post without any issues.
I’m waiting too, that he should come up with a reasonable
shipping option with tracking number … :~
Hello Everyone !
Now Our company wants to share the sample cost with customers .If customer paid express &sample cost at first time and this express cost we will return to customer in the customers' next order !
Hope this news can help you !
Thanks
