3 and 5 mode 9 amp driver on KD for SST 90
Wow anybody want a sick driver this looks like the one wow 9 amps really!
http://kaidomain.com/ProductDetails.aspx?ProductID=11408
Comments ideas anybody?
My SST-90 driven hard is pulling 15A from the cells. 9A is rather more sensible.
I really want to see an SSR-360 driven hard but it'd be a bit tough on any sensibly sized power supply - and it is a quad-die. 4 SST-90 dies on one board. The heatsink would probably have to weigh as much as I do. And 40A capable batteries tend to either be too heavy to carry or have runtimes measured in seconds.
I had no idea, it's 26mm so how big is the host and what do you use for batteries?
Mags usually - with the die mounted on a pound of pure copper. Power - I use 4 high-amp Tenergy NiMH Cs in a 3D. 20 minutes at 1500ish lumens.
http://flashlightnews.net/forum/index.php?topic=2332.0
If you want long runtime on these you need active cooling and gigantic LiPo packs.
OK cool this makes sense now I thought they were all direct drive maybe I can finally do something with one of the many maglights I have kicking around now thanks Don.
Could you use one of these and a laptop power supply to run 3 or 4 XML in series?
I was actually trying to stuff 3 18650s with 3 NANJG 105 drivers and 3 XMLs into a maglite with 3 switches for a 9 mode light but this driver gives me a bunch of new options.
