Oshpark Projects
1771 posts / 0 new
Rufusbduck
Rufusbduck's picture
Last seen: 1 year 4 months ago
Oshpark Projects
Put your Oshpark driver projects in this thread and I will organize them here in the op.
I would like to put all of the relevant Oshpark projects here as it can take some doing to locate them otherwise but will refrain from snatching them without the approval of their creators. Posting a link here will be considered as tacit approval and I will endeavor to keep this op updated.
This thread is for the listing of open sourced DIY projects that are listed on Oshpark not for pirating existing work. I’ll do my best to prevent that sort of abuse but will need your cooperation, thanks.
I’ll include stencil info where available.
Stencils:
Triple Cree XP for 20mm
Noctogon boards by Helios.
Cree XM and XP solder paste stencil by Helios.
3 x XP Cree(+1) 32 mm Noctogon by Helios.
Cree solder paste stencil for MTG, XRE, XML, XPG/Nichia by Texaspyro along with
Directions for ordering from Oshstencils.com. These instructions can be used to acquire a stencil for any of the projects listed below. Not the case at this time but hopefully it will be soon.
How to use a solder paste stencil
How to apply solder paste without a stencil
Mtnelectronics has some of these as boards or mod kits on his PCB’s – Mod Kits page. And will soon have more. if you buy them along with other items you will end up ahead of the Oshpark prices.
List of available boards:
BLF 17DD
BLF 20DD
7135 SRK
BLF SRK FET V2 – 46 mm by Rich.
Origin post #1560 with parts list
Mtn Electronics mod kits
Buck drivers
Knucklehead V3.0 Buck Le driver by Mattaus NO LONGER AVAILABLE
Digikey shopping cart
Coil craft inductor
Origin post with explanation
Discussion thread
The viability of this driver is still in doubt so only order for testing
Buck/Boost drivers
Meld v1 by tterev3
Link to discussion thread
Link to origin post
Meld v2 by tterev3
Meld v2 daughter board
Meld LED board
Meld LED board v2
Meld XP LED board
Link to origin post
Shopping cart
see also This post for shopping cart info.
7135 based drivers:
Dual pwm out drivers
Moonlight special V2 7 × 7135 +1 Driver works with dual pwm out firmware for lower/consistent moon mode. By Mattaus, RMM, Wight, Warhawk, etc.
Moonlight special V3 7 × 7135 +1 driver. As above but updated by RMM. Origin post #1584 with detailed info.
17mmA17PZL v013 by wight. See the Discussion thread for more detailed info.
Post 1447 introduction
CK’s linear drivers and boards
Quark EDC triple v05 for red xpe moonlight, Nichia medium modes, XP turbo.
BLF 15dd_v3.1
BLF 17dd_v3.1
BLF20dd_v3.1
10*7135V1.0
6V-LED TK35 clone driver thing FET +1 or 11 × 7135 +1 36 mm(can be filed to 32mm) for TK35 or Magliteby wight. UNTESTED Origin thread
10F32 Breakout Board
PIC QFN16 Breakout Board
At tiny 13A breakout programming board for flashing the at tiny 13A off the driver -by WarHawk-AVG*
Tested*
Attiny 13A mmu breakout board with USBAsp pinouts labeled. See post 1504
Single sided amc7135 test board v010 (LEDs on top) for testing individual chips -by WarHawk-AVG and wight.
TESTED+
Discussion thread
2 sided amc 7135 test board v012 (LEDs on bottom) for testing individual chips -by WarHawk-AVG and wight
untested
Discussion thread
BLF Teeny 10 1 × 7135 and contact pad only by Warhawk. Not Tested but really?
Tiny10 10.5 mm linear driver pcb by Mattaus and friends.
Tiny12 12 mm linear driver pcb by Mattaus and friends.
BLF SK68 linear driver pcb by Warhawk-AVG TESTED File has cream layers for stencils.
Link to origin thread
BLF17 Linear Z Zener mod & x. 7135 driver w/lvp and reverse polarity protection. Tested?
20 mm nanjg 105C compatible 8 × 7135 driver by Texaspyro.
p. WarHawks Tweak changes D1 to standard Nanjg diode and adds pads for off time cap
Link To Thread
20 mm Zener Mod Linear Led driver 12 × 7135 driver by Mattaus.
22 mm nanjg 105C 16 × 7135 nanjg component driver for F13 flashlights by wight.
Discussion thread
BLF SRK FET V2 – 46 mm updated version by RMM.
Link to intro post#1560
46 mm 7135 Driver V1.1 32 × 7135 46 mm linear SRK driver by Mattaus, Comfychair, Warhawk-AVG.
BLF SRK XP-G2 3 channel driver by Mattaus w/ mod by WarHawk-AVG.
tivo532 Zilog-7135 Driver
Link To Thread for tivo532’s Zilog controlled 7135 driver.
BLF_15dd_PIC_v2.1 direct drive 15mm driver uses PIC mcu. By Cereal Killer. Discussion thread
16mm 12 × 7135 slave board by Mattaus. For stacking on 17 mm linear drivers.
Link to origin post
19mm 16 × 7135 slave board by Mattaus. For stacking on 20 mm linear drivers.
Link to origin post
FET based drivers: These were generated in part through pm’s but the ongoing development for the next four boards is in this one. Links to parent threads will be added as soon as I remember them.
Roche F6, X3 DD driver with battery status LEDs. By Helios
MTN-10DD 10mm linear DD FET driver uses Attiny mmu and LFPAK 33 FET. Use the mmu breakout board above for programming before soldering to driver board. By RMM
MTN-12DD same as MTN-10DD but 12mm board. By RMM
The BLFTiny10DD, BLFTiny12DD, and BLF15DD all use the same irlm2502 FET for it’s small size but otherwise are similar to the larger DD drivers which use the vishay 70N 02 FET. The 10DD AND 12DD are too small to have a center positive spring pad and require a separate contact plate.
BLFTiny10DD Version 1.0 by Mattaus/WarHawk-AVG has relocated cap for stable modes. Digikey shopping cart includes off time cap(1microfarad) so delete this if you are staying with on time memory(standard105C firmware).
Discussion thread
BLFTiny12DD Version 1.0 Digikey shopping cart includes off time cap(1microfarad) so delete this if you are staying with on time memory(standard105C firmware).
Discussion thread
BLF15DD Version 1.0 replaces gate resistor with relocated cap for stable operation and includes off time cap pads. Digikey shopping cart includes off time cap(1microfarad) so delete this if you are staying with on time memory(standard105C firmware).
The following larger FET boards were developed using the Vishay 70N02 FET which is apparently available but no longer in production. The “similar single FET” has been tested and now works with the new location for the input capacitor.
BLF17DD Version 1.0 driver by Mattaus, Comfychair, and Warhawk-AVGg.
Digikey shopping cart and
Vishay 70N02 10 pcs(EBay) or
Similar single FET from Digikey compiled by Comfychair.
Discussion thread
BLF 17DD Zener Rev2 ( changed diode from SOD-323 to SOD-123 and relocated star2) by Mattaus.
Discussion thread
BLF20DD Version 1.0 noanjg MOSFET driver by Mattaus.
BLF22DD Version 1.0 from the 20DD by Mattaus and enlarged by WarHawk-AVG. Untested in this size.
SRK nanjg MOSFET Direct drive w/MOSFET, controlled w/at tiny 13A. Pcb design by Mattaus, Comfychair, and Warhawk-AVG
Digikey cart preloaded with parts compiled by Comfychair and
Vishay 70N02 10pcs(EBay) or
Similar single FET from Digikey.
Discussion thread
17mm A17DD-SO8 v24 single sided direct drive by wight. Discussion thread
Mouser cart
20mm A20DD-SO8 v24 single sided direct drive by wight. Discussion thread
Mouser cart
LD-1 Expander Board by Led4power. For using base driver with multiple parallel LEDs to prevent overheat of FET. Also for running at higher than 5A stock current. Info thread
Contact Boards by HarleyQuin, Discussion Thread
22mm Contact Board HQ v1
24mm Contact Board HQ v1
26mm Contact Board HQ v1
Driver contact spacer rings
22mm hybrid contact board for 20/17mm driver .
BLF 26mm contact plate by wight/WarHawk-AVG. caution centers of some of these are not being properly milled out.
26mm contact plate for 20mm driver 18mm hole w/1mm overlap by wight. caution centers of some of these are not being properly milled out.
26/24/22mm contact plate v14 with Dremel mandrel filing support(hole in center for mandrel screw). By wight. caution centers of some of these are not being properly milled out.
Untested
Link to thread
26mm contact plate for 17mm driver 16mm hole w/.5mm overlap.
26 mm contact plate by Cereal Killer.
Non driver projects:
Scaru’s 20 mm triple XML Board
Scaru’s 20 mm 7xXML Board
CREE XB-H 16 mm by Helios. Link to request by antoninodattola.
16mm Luxeon T emitter pcb by antoninodattola. Tested
Switches
17mm High current lighted tail cap mini omten switch pcb with direct to switch bypass vias by pilotdog68.
20 mm tail switch with led by pilotdog68.
17 mm slotted switch pcb for lighted tail cap fits mini omten by Helios.
20 mm slotted switch pcb for lighted tail cap fits omten 1217 by Helios.
17mm board for Omten TS 1273G1 12mm switch by Helios
Shutter switch board two stage switch board by wight. See posts 1506-1509
12.2 mm tact switch button board V2 with untented vias by Helios
Battery Carriers
4 x AA Carrier Top Plate with masked vias by Helios untested
4 X AA Carrier Bottom Plate with masked vias by Helios untested
4 X AA Carrier Top Plate with exposed vias by Helios tested, could use locator holes for non conductive center rod See post 1155
4 X AA Carrier Bottom Plate with exposed vias by Helios tested, could use locator holes for non conductive center rod See post 1155
BLF 3 x AA series top plate by Mattaus TESTED by DJOZZ
BLF 3 x AA series bottom plate by Mattaus TESTED by DJOZZ
DJOZZ Battery Contact.
Link to build thread by Djozz.
Scott
Edited by: Rufusbduck on 11/17/2015 - 15:20
texaspyro
Last seen: 1 year 1 week ago
20mm Nanjg 105C driver: http://oshpark.com/shared_projects/rgATF36k
XPG/XML/XRE/MTG solder paste stencil (download the .BRD file and send to OSHSTENCILS.COM): http://oshpark.com/shared_projects/dw8NYoED
Sirius9
Sirius9's picture
Last seen: 2 weeks 2 days ago
Good idea this thread Smile
Mattaus
Mattaus's picture
Last seen: 2 years 4 months ago
Duplicated information.
Rufusbduck
Sorry Matt, I just used the Oshpark titles.
Scott
Mattaus
Mattaus's picture
Oh no worries I didn't see your edit. Your post is better Smile
MRsDNF
MRsDNF's picture
Last seen: 14 hours 54 min ago
Maybe?
djozz
djozz's picture
Last seen: 56 min 17 sec ago
Hey, there's a 15mm driver too, very interesting, what's the story?
What I think that I see is no minus-ring on the battery-side (same as the 17mm and 20mm version), and no space on the board for the FET (that makes sense because it would never fit).
ImA4Wheelr
Tivo532 has a couple:
Thread - DIYDriver AMC7135(PWM) and DMG6968U(Direct Drive)
OSH Park Project - DD
Thread - DIY Driver Nanjg Style/AMC7135 using Z8F082A MCU
OSH Park Project - 7135
DB Custom
DB Custom's picture
Last seen: 4 days 7 hours ago
Nice work Guys, Thank You very much for sharing!
Mattaus
Mattaus's picture
Different FET on the 15mm board. I need to update the descriptions a bit better. I rushed putting them up this morning.
Lack of GND ring on the reverse sides is a cock up. Will be corrected later as well.
texaspyro
Also diodes are probably not BAT54’s… those are in a 3-pin package. I usually use BAT54’s since a) I have a few thousand of them b) if you buy the right version, you don’t put them in backwards c) they are easier to hand solder than some of those tiny buggers. In a pinch, you can usually slip a 2 pin diode onto the BAT54 footprint…
antoninodattola
Last seen: 1 year 3 months ago
Hello Mattaus!
congratulations for your PCB!
What do you use to draw them?
I'm downloading Kicad, to try to play a little!
What do you advise me to start?
thank you!
djozz
djozz's picture
I see, I looked up that little FET (0.37 euro at a local website, I bet it can be had cheaper), it has an internal resistance of 0.045 ohm, that would give a voltage drop of 0.1V at 2A (if I remember Ohm's law well Wink ).
Mattaus
Mattaus's picture
antoninodattola wrote:
Hello Mattaus!
thank you!
Use CADSoft Eagle. Its free. Any tutorial will have you on your way very quickly and then its just a matter of practice, practice, practice.
Rufusbduck
Thread – DIYDriver AMC7135 and DMG6968U
OSH Park Project – DD
Thread – DIY Driver Nanjg Style/AMC7135 using Z8F082A MCU
OSH Park Project – 7135
I’ll put them up if it’s ok with TiVo. Don’t want anyone left out but also don’t want to step on any toes.
Scott
Rufusbduck
Sorry Matt, I was rushing a bit this morning myself and didn’t look them over before copying the links from Oshpark. I’ll mark them in the op as not ready for prime time until they are.
Scott
Mattaus
Mattaus's picture
OK I've changed the 15, 17 and 20 Direct Drive drivers. You'll need new links though. They are all under my OSHPark profile.
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 1 month 1 week ago
The diodes on the FET boards are the stock off the Nanjg boards, I had to special order the ones you have on your 20mm I built TexasPyro…but it worked like a charm though
(DIY’ers can’t be choosers Wink )
It was my fault the 17mm board got pushed…we hadn’t reviewed it…my apologies to you Mattaus. I already ordered 3x of em…so that is my penance for rushing you.
JonnyC
JonnyC's picture
So that last SRK board with the FET looks rather awesome.  I just can't keep up with all that is going on in the world of drivers.  I'll just wait until RMM stocks them Smile
Rufusbduck
New links in place.
Scott
WarHawk-AVG
Make sure you mention his uses a Zilog MCU not an ATtiny13A
It has 8k flash, but needs a special programmer…but I tell you, his turbo my using those FETS! WHOAH!
WarHawk-AVG
And for a little driver porn…forgive my photo ability…I only have a cell phone camera
Nangj 105C 32*7135 SRK driver
This one was done on a skillet on my stove
TexasPyro 20mm Nangj 105C
This one was done with a hot air rework station (in about 20 minutes)
JonnyC
JonnyC's picture
You got one already?  Wow, that was fast...and I'm jealous Smile
ImA4Wheelr
Darn, I think I ordered before you changed.  Do you know if I have to request a cancellation from OSH Park?  Hoping they know to use your latest version.
EDIT:  I created Support Tickets asking them to substitute the changed designs for my orders.  If that doesn't work, I imagine I might be able to rig a ground connection on the boards.
WarHawk-AVG
Shoot em an email BEFORE it goes to production
Rufusbduck
ImA4Wheelr wrote:
Mattaus wrote:
OK I’ve changed the 15, 17 and 20 Direct Drive drivers. You’ll need new links though. They are all under my OSHPark profile.
Which ones did you order? You might be able to add a couple pieces of wire near the edge to act as a ground ring.
Scott
ImA4Wheelr
All 3.  The 15, 17, and 20.  I created support tickets for them.  If that doesn't work your wire idea will probably make them functional.  Thanks for the suggestion.
Rufusbduck
I’ve sent TiVo a pm with an invitation as he is offline now and this thread may be well down the pages before he comes back. Any other Oshpark flashlight projects that people can think of should get mentioned as well.
Scott
Microa
Last seen: 12 hours 44 min ago
The BAT54WS is in SOD-323 package. The BAT54/A/C/S are in SOT23 package.
Tom E
Tom E's picture
Last seen: 7 hours 11 min ago
Rufusbduck wrote:
I've sent TiVo a pm with an invitation as he is offline now and this thread may be well down the pages before he comes back. Any other Oshpark flashlight projects that people can think of should get mentioned as well.
I would definitely hold off with the FET based design. It's not working well with more than one FET (accommodates up to 4), and he's still working on a solution. The fix will probably be a design change.
