Oshpark Projects
1765 posts / 0 new
comfychair
comfychair's picture
Last seen: 3 years 8 months ago
Also there's nothing higher than 10uF in 0805 & X7R. 15 & 22uF 0805s only exist in JB, X5R, & X6S.
Rufusbduck
Rufusbduck's picture
Last seen: 10 months 1 week ago
Is there any difference in the firmware between working and non working drivers?
Scott
WarHawk-AVG
WarHawk-AVG's picture
comfychair wrote:
But why does it work when you stick the same FET onto a 105C, using all the 105C’s original parts? Is it possible the original cap isn’t 10uF? There’s nothing different about the new PCB, I’ve checked everything until I’m crosseyed.
Take a break, attack it from a different direction in a bit man
Rufusbduck
At some point for me it comes down to a fresh look after a good nights sleep. Or a big hammer and then a good nights sleep and fresh parts in the morning.
Scott
comfychair
Nope, exact same build of luxdrv I used on the Nanjg-092 boards, same batch file with the same fuses and everything.
Microa
Last seen: 21 hours 36 min ago
Try to add a cap directly to the Vcc of the MCU ( pin 8 ) and see if this can help.
comfychair
It works properly with STAR v1.1 clicky version. luxdrv still didn't work even with a second 10uF in parallel.
I really have no clue what is going on.
And, I certainly know the value of a strategically-wielded hammer...
http://75.65.123.78/specialtool.jpg
WarHawk-AVG
Does STAR_mom V1.0 work on it?
is the PWM compile different from STAR V1.1 than luxdrv?
Microa
To-morrow will be a better day.
Rufusbduck
If the code is not an issue then is it possible for it to be corrupted during the flashing process? What I mean is, Is the flashing process foolproof. If the hardware is right and the traces are right and the soldering is right then where else can you look? Could it be a faulty mcu even?
Scott
WarHawk-AVG
If it works with one, but not the other, it’s not the hardware
And when flashing, it writes, then reads, to verify…if there is a problem it will tell you
Mattaus
Mattaus's picture
Could it be a layout issue? I mean everything is connected correctly, but perhaps the comparatively longer traces (given the size of the board) required to get everything on the PCB are screwing something up?
comfychair
I have even done an A-B-A test, luxdrv (no worky), STAR v1.1 (worky), back to luxdrv (no worky again). I re-reflashed an older Nanjg-092 driver that's been running the same build of luxdrv, and it still worked just the same as it did before. So, that build of luxdrv works on the 105C board+FET, but not on the new board.
dave_
Last seen: 10 months 3 days ago
I just browsed over the the last pages, so I didn’t get all details, but: is it right that that reset pin on the attiny is floating?
If yes, please try tying it to vcc with a 4.7k …10k resistor. That can easily cause such strange behaviour.
Mattaus
Mattaus's picture
dave_ wrote:
I just browsed over the the last pages, so I didn't get all details, but: is it right that that reset pin on the attiny is floating? If yes, please try tying it to vcc with a 4.7k ...10k resistor. That can easily cause such strange behaviour.
The thing is every board I have ever created with an ATINY chip (13 or 25 for me) has been setup exactly the same way. I have never experienced any of the problems that are being described here. Not saying it's right or wrong, just saying it's weird that Dale/Comfy are having issues. Happy to pass my BRD files onto anyone who wants to double check my work; it's entirely possible that I've made some stupid mistake.
- Matt
WarHawk-AVG
I will say this, on my joule thief build the .brd file I uploaded to OSHPark I got from alxsmith, some of the traces just went away, he was using an older version of eagle, but he fixed it with the latest..I think you said you were running 6.5.0 right?
dave_
Sure, no doubt it might run forever without any problems that way. Wink
Thing is, the reset input is not designed or supposed to be left floating. It can change it’s potential through coupled-in noise through parasitic capacitance or inductance on the board, esp. in high current switching environments like those drivers. Even some dirt or flux residue can cause troubles. That’s why one should tie it to a potential like vcc (but with a high enough pullup resistor that the programmer still can pull it down. )
I would strongly suggest to implement that in future designs, even if it is not the problem in this case.
It very well could be the problem (that random blinking stuff could be resets), a workaround costs a few cents at best, so I would say it is worth a try. If you can exclude it from the list of possible causes, it was worth the 5min work I think. Smile
RMM
RMM's picture
This may be a long shot but have you tried checking the board for shorts?  At this point I may also try measuring resistance of traces vs. the 105C.  I think that dave_ may also be onto something.
Mountain Electronics : batteries, Noctigon, and much more! What's new?
DrJones
DrJones's picture
I have never needed an external pull-up on the reset pin, the internal pull-up sufficed. However, in noisy circuits, an external pull-up (typically 10k, maybe even only 4.7k, but not less than that) is often recommended, because the internal one is quite weak (~50k). My guess is that the FET switches much quicker than the AMC7135, which indeed implies more noise. It might help to check the reset pin with an oscilloscope.
A resistor between MCU and gate is also often recommended.
I'm not into DD, so haven't tried.
dave_
Well, 50k actually would be a lot better than what I recalled, but could still be to high in this situation. I’d give it a try.
comfychair
Would comparing the code that works to the code that doesn't help to nail down what the issue is? I don't understand it well enough to know what the differences translate into in actual use...
http://75.65.123.78/fw/luxdrv02.txt (doesn't change modes reliably)
http://75.65.123.78/fw/starv1.1clicky.txt (works fine)
http://75.65.123.78/fw/minimoandFFK-6mode.txt (works, but very noisy)
http://75.65.123.78/fw/starv1.0momentary.txt (quiet)
I'm using fuses 0x75/0xff when flashing all of them.
comfychair
Also, for a temporary test, I can use a plain jumper wire from Vcc to RST instead of a resistor, right? Just don't try to program it with that in place (it would block the clip anyway)...
comfychair
Here's a mouseover of the 17DD showing what's underneath
The diode could be rotated about 30* CCW to free up a bunch of space for fatter traces in & out. Also looks possible to pop in a via near the RST pin and add a resistor on the spring side of the board, if it turns out that's needed.
Mattaus
Mattaus's picture
That's actually a very good point. Every FET based circuit I've ever worked on prior to this (so um...one lol) has had a 100ohm resistor between the MCU and FET gate. I think the reason I skipped it here was because the original SRK board never used one either, and I was lead to believe it work fine? That being said I know what it's there for so I should have included one regardless.
10k pull up on the reset pin to VCC will now be included on all my boards by default.
When I get the time to update some of these boards (and some sort of testing prior would be good) I will update the OSHPark projects.
Anyone who has ordered any of my boards and is experiencing problems, can you please PM me?
- Matt
comfychair
The JB driver with the single 2SK4212 FET didn't use a resistor to the gate, and worked fine with any of the right firmware versions and before any mods using the stock unknown MCU and also after the piggyback 105C was added... it still works without the resistor on the new 46mm version, the only issue with that one is the noise from certain versions of firmware. Lack of a resistor shouldn't affect the smaller board if it doesn't also affect the larger one, I would guess.
comfychair
17DD shows no change with RST jumpered to Vcc, still erratic mode switching with the luxdrv code.
texaspyro
Is there a pull-down resistor on the FET gate? Without one the FET could come on between the time the processor is powered up and it initializes the state of the output pins. Try something around 1K to 10K from the FET gate to ground.
comfychair
None of the other boards have needed a pulldown on the gate using the same components.
I've tried jumpering various stuff at random: from B+ to the diode, and from the diode to MCU's Vdd, neither made any difference. But I then moved the jumper to go straight from Vdd pin to B+, bypassing the diode, and it now changes mode like it should, doesn't do that weird random strobe/morse code crap, doesn't change 2 modes when it should only do 1, etc. The diode isn't on backwards, could it just be a bad diode? I doubt it, since the battmon mode in luxdrv gives the correct number of blinks that matches the input voltage.
texaspyro
Try the pull-down…
RMM
RMM's picture
Maybe not a bad diode, but it is a different diode, right?  (than the one you use on the 105C)
