Engineer Lii-260(LiitoKala) the smartest li-ion charger in a world?
69 posts / 0 new
luminarium iaculator
luminarium iaculator's picture
Last seen: 1 day 1 hour ago
Hello guys,
Don’t consider this as review because someone more experienced has to yet review that charger.
My verdict is that this is very good charger.
I am playing with this charger for whole week now and I will only bring + & – sides of this charger.
PLUS:
- Battery voltage detection
- Battery internal resistance detection called mR (I guess this should be mΩ?)
- Battery capacity detector
- Battery charging/discharging time
- Dual completely independent charging channels
- Dual independent displays
- Real time data reading (display instantly shows how charger charging/discharging) progression
- It can simultaneously charge in one channel while discharging in other
- Heat dissipation from charger is excellent.
- You can chose 0,5A-1A charging/discharging current selection
- Easy to use
- Very nice blue led display
- Very safe… You can go to sleep if no sign of stormy weather.
MINUS:
- Display does not give 100% accuracy in readings(more like 90% of accuracy) so readings from this charger should be considered as approximately readings which are still good for one cheap charger.
- It doesn’t fully charge battery to 4,2V (4,15-4,18)
- It discharges battery only to 3,0V
How does charging work? Very simple… So you put battery in and it will automatically start in a charge mode. 500 mah will blink for few seconds on display… In blink mode you can press “mode“switch which will turn on 1000mah charging current mode. If you don’t touch anything it will start charging in default 500mah mode.
It is very safe… When charging process is over it will write “FULL”,“charge end” on display and it will instantly terminate charging process leaving you all relevant data on display.
After I tested it several times leaving batteries for more than 2 days on the charger I can say that I completely thrust to this charger and I can finally go to sleep… When charging process is finished charger will instantly cool down.
However charging it is not perfect… Charger can not charge to 4,2V… (It will show you 4,2 on displays but multimeter will say something like 4,17 or less if you are charging ultracrappyfire brands)
Battery internal resistance, voltage detection, charging time, charging current, mah readings while charging/discharging This is all showed on 2 completely independent displays at real time, and you can reach any data in any time while charging/discharging without any fear you will mess something.
How does discharging/capacity testing works? Very simple… Once you fully charged your battery(4,2V) put it in desired channel and wait few seconds… When 500mah charge blinking display appears press and hold mode button for 3-4 seconds, and then it will go to “discharge 500mah blinking mode” in which with one more click you can turn to 1000mah discharge mode.
It will start discharging in selected current mode, and it will give you real time readings. The most interesting part here is when it discharges battery it will instantly start charging process again. What that means? That means that you can put freshly charged battery in and charger will discharge/test cell capacity and it will automatically charge it. So put your 18650 battery in discharge mode and go to sleep and in the morning you will have freshly charged battery with tested capacity.
Well discharging is also not perfect since it discharges battery only to 3V(most batteries can be discharged to 2,5V 2,75V)
For example I got this readings:
new Panasonic NCR18650PF 2900 mah: -2750 mah, 35 mR internal resistance
used Sanyo UR18650FM 2600mah: – 2290 mah, 46 mR internal resistance
I hate crappy fires but I did test so…
Blue Ultrafire 18650 rated at 2600mah: 720mah, 157 mR internal resistance
Red Ultrafire rated at 3800mah: 740mah, 150mR internal resistance
(discharging – charging was very fast with this cells and that is prof how crappy they are)
As you can see this are not perfect readings but they are very good approx readings(just add 10% and panasonic really has 2900 mah, and used sanyo around 2500 mah)
So is this smartest charger on the market? It seems like it is… But someone should seriously test it.
Edited by: luminarium iaculator on 03/20/2014 - 13:06
djozz
djozz's picture
Last seen: 1 hour 15 min ago
That seems a nice charger. Thanks for the test. You do not mention where you bought it, and what it costs?
I bought it at ebay for promotional price of 22$. But now seller raised price to 28,5$.
http://www.ebay.com/itm/151242501125?ssPageName=STRK:MEWNX:IT&_trksid=p3...
It all started with a guy that showed up on BLF offering cool charger http://budgetlightforum.com/node/28769 but he(his boss Smile ) is very complicated in doing some serious business.
But I got same thing for much less money than he offered, and I am very happy with this unit although It has some minor disadvantages... But not  that bad considering that with mentioned disadvantages it  could actually prolong battery life?
phsinvent
phsinvent's picture
Last seen: 1 year 9 months ago
Interesting. Are their any other chargers with a similar price that can detect capacity?
tatasal
Last seen: 3 min 48 sec ago
I have two ‘good’ chargers. The iCharger 106B+ and the Pila IBC. In my experience from both of them, the terminal voltage of 4.20V (or the the failure of the charger to charge to 4.20V) is actually dependent on the cell. I have tried charging various brand-new Panasonic, AW, Sony, LG, Samsung and Sanyo cells and while the the iCharger terminate at exactly 4.20V, the holding voltage of the specific cell determines whether that cell holds 4.20V when taken off the charger. Seldom do I see a cell hold a 4.20V, or least for a few minutes actually. (side note: almost all Pila IBC does not terminate at 4.20V, always on the low 4.14 to 4.19V)
phsinvent
there are no charger(except hobby chargers) that has functions like this one (at least for now). It is unique...
tatasal
Pila are considered as premium chargers so I am glad to hear that they also have low termination...
I think this lii-260 charger is real champion, real progression in charger world. Hope plenty of charger manufacturers will follow this idea "all in one charger".
But there is always place for improvement...
Thing that could make Lii-260 charger as a perfect choice would be added option for changing termination voltage from 4,35 & 4,2V. I think they can do that if they want... So dear China engineers if you will ever watch this thread made one and you'll be the king, and of course don't let your fellow citizens copy your patent Wink
 Update: I tested one more brand new blue ultrafire 2600 mah Smile battery for friend and got following results:
675 mah capacity(add +10% and results are 742mah), but incredible well internal resistance of 54mR(this is very strange because last one mR measured on crappy fires were 150, maybe 16340 is fitted inside this tested 18650 battery?),
penumbra
penumbra's picture
good….but i want first one review from the BLF legendary charcher tester member HKJ
i have time ago buy the soshine sc h2…. crappy charger.
leaftye
It's not quite an all in one charger since it doesn't charge nimh chargers.  This one does though.
http://lygte-info.dk/review/Review%20Charger%20Opus%20BT-C3100%20UK.html
I believe the Nitecore D4 will do all that too.
It's a decent value though.
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
HKJ
HKJ's picture
Last seen: 13 hours 40 min ago
penumbra wrote:
good....but i want first one review from the BLF legendary charcher tester member HKJ
My review is nearly done, but I had an accident and need a new unit to finish the review. It is on order, but it will be a couple of weeks.
In the meantime I will test/review a couple of Soshine chargers, a simple Xtar charge may also be included.
leaftye
HKJ, you don't have a Nitecore D4 in the pipeline do you?
HKJ
HKJ's picture
No, nobody has send me one.
I might look for one myself later on.
_the_
_the_'s picture
Last seen: 1 month 5 days ago
Liitokala (Exocoetus volitans):
The name of this charger makes me smile, every time I see it. Smile
[Liitokala is the Finnish name for the above pictured flying fish - literal translation would be "GlidingFish"]
Anyways, thanks for the review! The charger looks very nice. I'm seriously considering to buy one..
=the=
garrybunk
garrybunk's picture
Last seen: 2 days 10 hours ago
Hmm . . . seems nice!  Nice and simple!  Keeping an eye on this one.
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding Forum
NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
hank
hank's picture
Last seen: 16 hours 31 min ago
I want to know things like how the spacing and soldering of the components looks inside, as well.
brad
brad's picture
HLK are any of the new chargers capable of charging D batteries?
I just bought 12 Tenergy Ds and don’t have a charger that will charge them.
HKJ
HKJ's picture
brad wrote:
HLK are any of the new chargers capable of charging D batteries? I just bought 12 Tenergy Ds and don't have a charger that will charge them.
I do not have any D capable charges in queue for review (One of the  Soshine does C cell, it is not perfect, but useable).
The only working D cell charger I remember to have tested is the BT-C2000.
If I wanted to buy a D cell charger that could charge many cells, I would look for a Maha C808M, but it is a bit on the expensive side (I have never tested it, but my general experience from using Maha is good).
It would be very nice if it could charge all possible batteries + 4,35 to 4,2 V selection and of course for less than 20$ if possible Smile
penumbra wrote:
good....but i want first one review from the BLF legendary charcher tester member HKJ i have time ago buy the soshine sc h2.... crappy charger.
Me also... I am waiting for pro review of this little charger. But even now I trust him and for first time I am leaving charger unattended Smile and it is doing everything what I need...
I just say "liito kala charge!" And he charges, and then I say "liito kala measure capacity!" And he does all that while I am gone on beer Wink
Ejected Filament
Ejected Filament's picture
Last seen: 2 years 3 months ago
I have that problem too!
HKJ
HKJ's picture
That is much more dangerous than playing with LiIon batteries Smile
Well it is good for nerves but bad for body especially for belly Smile
And sometimes doctors recommends warm beer for kidney stones(seriously I am not kidding here)
HKJ
HKJ's picture
Well it is good for nerves but bad for body especially for belly :)
When you move around and depending on how you move around it can also be very bad for other parts of the body, especially after a large dose.
And the next morning can be bad for the head and stomach Smile.
But if you can handle it responsible, the risk is minimal (Like LiIon)Smile
Exactly good beer is like good li-ion battery Smile
Ejected Filament
I might need to clarify something lost in translation. “Gone on beer” could be interpreted in English, Australian English anyway, as well and truly drunk. While I assume the meaning you intended was simply free of concern over the battery charging and having a beer?
But I agree with all of it. Except the charger, I have no idea until I see a review with charts and stuff. No hints yet HJK?
And you said you had an accident while testing it, what kind of accident?
HKJ
HKJ's picture
I might need to clarify something lost in translation. "Gone on beer" could be interpreted in English, Australian English anyway, as well and truly drunk. While I assume the meaning you intended was simply free of concern over the battery charging and having a beer? But I agree with all of it.
I understood it without any amount specification, i.e. it could be 1 beer or 20 beers.
It looks good until now.
I simulated a battery with too high voltage, when checking the voltage readout (At least I believe that was the reason). The discharge function is gone and I believe that this problem might have spoiled the resistance measurement.
Ejected Filament
Ooops!
I might need to clarify something lost in translation. "Gone on beer" could be interpreted in English, Australian English anyway, as well and truly drunk. While I assume the meaning you intended was simply free of concern over the battery charging and having a beer? But I agree with all of it. Except the charger, I have no idea until I see a review with charts and stuff. No hints yet HJK? And you said you had an accident while testing it, what kind of accident?
I am not into English language since it is not my mother tongue :). But I have thought about that as drinking a beer in a bar while Charger does all the rest...
LiitoKala R.I.P... How much high voltage? So he does not have over current protection?
HKJ
HKJ's picture
Ooops!
Exactly. Accidents happens, even if I try to be careful. Luckily the charger was not that expensive, I get much more depressed when I blow something to a couple of 100 dollars (This happens very seldom) .
HKJ
HKJ's picture
Probably around 4.5 volt, when turning the knot on the power supply it is very easy to turn a bit to high. This does not have anything with over current protection to do, but the charger is simply not designed to handle more voltage than a LiIon battery gives.
Poor little fella... I really like him...
HKJ
HKJ's picture
If I had disliked the little fella, I would not have ordered a new one, but only published my current results.
But I believe it is worth doing a good job on him.
TheGloriousTachikoma
Last seen: 4 years 8 months ago
Poor little fella… I really like him…
That is very promising coming from you. Smile
I’m just worried about heat. It claims it can discharge two cells at one amp each, that’s going to generate some heat, yet there’s no fan. For a $25 charger I’m not above buying a small CPU fan and cutting it into the body and circuitry, but it would be nice to see it there.
