deal alerts: @ ebay, all flashlights below $5
267 posts / 0 new
cajampa
Last seen: 3 years 7 months ago
Nice build Smile Which reflector & boost driver did you use?
I would like to find as many reflector options as i can, because the XHP’s can have a little ugly beams if you get unlucky with the reflector.
Iraksat
Last seen: 6 months 6 days ago
5-Mode 800mA From FT (SKU: 1127407).The reflector is a leftover from Convoy s2+ project.It’s only 21mm wide (12mm dep) ,fits Ok against the lens.Very nice flood but the reflector opening still blocks some light and the beam is almost square.
cajampa
Ok thanks Smile good to know.
ImA4Wheelr
Last seen: 2 weeks 6 days ago
ImA4Wheelr wrote:
Won one of these 2AA's for $1.33 just to see what it is.  Expecting it to be junk.
Received it.  Yep, it's junk.  All plastic.  The twist zoom feature isn't bad, but the light is dim and slightly purple with no heat sink potential.
Fritz t. Cat
Fritz t. Cat's picture
Thanks for checking it.
Flashlight designers should look at lighthouses and pottery.
这些谁设计的手电筒应该看灯塔,以及在陶器。
apt323
apt323's picture
Last seen: 1 week 3 days ago
keltex78 wrote:
Pregulla wrote:
Not on eBay, but AA twistie for $3.5. Used to be $4.8 at FT earlier in this thread; still $2.99 @ ebay:
http://www.ebay.com/itm/271717233060
Still a great twisty single-AA mod host too. 8)
Did you or anyone post pics of the teardown or anything like that?
Thanks
apt323
apt323's picture
I am in need of something cheap to sit and stare at for a few minutes test out and maybe giveaway to friend or two. How bout something $10 and under? Something that hasn’t already been listed.
Smile
ImA4Wheelr
^ There's a handy thread for that:
deal alerts: @ ebay, all flashlights below $10
keltex78
keltex78's picture
apt323 wrote:
Did you or anyone post pics of the teardown or anything like that? Thanks
Here, courtesy of cajampa...
http://budgetlightforum.com/node/35595?page=2#comment-727068
Keepin’ the “B” in BLF
Don wrote:
It sounds like the XM LEDs won’t really be suitable for flashlight use. Pity…
keltex78
keltex78's picture
This is an interesting light, for $3.99:
http://www.ebay.com/itm/201252959846
"UltraFire" - sure, if you say so.
Side clicky, Single AA, three-mode High/Low/Strobe driver with memory, available in 9 colors.
Has a proper hollow aluminum thread-in pill that takes a 16mm PCB and a smaller (15mm? I didn't have my caliper handy to measure) driver.
Plastic reflector/lens is largish for the light size, so possibly some throw potential. Lens and SMO reflector are pressed in via the front, so not much room for modification there. My sample had some scratches on the ring, and a smudge on the reflector. The opening on the reflector sits perfectly on the ring of an XR-E emitter, so possibly a good mod host for your old XR-Es left over from other lights.
Factory emitter is one of the cheap "plastic dome over a yellow glob" type emitter. Mounted on a 16mm PCB, so it's easy enough to remove/replace.
ChibiM
ChibiM's picture
Last seen: 2 days 12 hours ago
I like the colors!
siata94
siata94's picture
Last seen: 10 hours 17 min ago
Hugsby XP1 currently $4.38 shipped:
http://www.ebay.com/itm/Hugsby-XP-1-1-AAA-CREE-XPE-R3-LED-120LM-Lamp-Clip-Mini-Penlight-Flashlight-Torch-/271843871111?pt=LH_DefaultDomain_0&hash=item3f4b284987
$4.15 shipped for the 2xAAA version XP-2:
http://www.ebay.com/itm/CREE-XPE-R3-LED-1000-Lumen-Lamp-Clip-Mini-Flashlight-Torch-Penlight-AAA-OK-/281670168459?pt=LH_DefaultDomain_0&hash=item4194d9af8b
or 5 XP-2s for $18.37:
http://www.ebay.com/itm/5pcs-CREE-XPE-R3-LED-1000LM-Lamp-Clip-Mini-Flashlight-Torch-Penlight-AAA-OK-/281670168541?pt=LH_DefaultDomain_0&hash=item4194d9afdd
Lancman
Lancman's picture
Last seen: 2 years 2 months ago
I was going to say that I found the XP-1 even cheaper at $3.78 but on closer inspection it doesn’t look quite right.
The switch cap is shiny and the clip is different.
jerm03
Last seen: 2 weeks 3 days ago
LazyJ wrote:
XTAR WK50, I’ve been winning auctions on these from xtarshop on ebay for $8-10. Great 4-mode driver, no disco, handles 14500’s, op reflector, pop a Nichia in it.. perfect.
I got 3 of these, and like them, except they are a little large to carry in my pocket compared to AAA lights. I really like the spacing.
Jerry
ChibiM
ChibiM's picture
`bout this one?
less than $2
its $1.92AUD
not sure USD?
Jubeldum
Jubeldum's picture
Last seen: 3 years 11 months ago
ChibiM wrote:
`bout this one?
less than $2
its $1.92AUD
not sure USD?
I ordered 3 of them for the mother in law (she has dementia and Alzheimers) because she keeps tearing apart and breaking all the lights I give her. Flat Stare
The price has went up from that seller now. Here’s the cheapest price now.
300LM Black Durable LED Flashlight Portable Mini Flashlight Torch with Clip 66
C $3.62
Approximately US $2.88
Found a picture of what led it has.
Pulsar13
Pulsar13's picture
Last seen: 10 months 1 week ago
I just received another one of those S5 copies, this time it’s labelled Vander on one side and OUTDOOR (quite nice actually) on the other. Quite a relief from Ultrafire and CREE.
Also, Vanderbilt graduates can rejoice that their university is popular enough Smile
Here’s the one I bought from: But its price has gone up from $2.89 to $3.66.
http://www.ebay.com/itm/Black-VENDER-CREE-Q5-1200-Lumens18650-LED-Flashlight-Lights-Torch-Free-shipping-/121643002545?pt=LH_DefaultDomain_0&hash=item1c527ceab1
Here’s another link that still lists for $2.95. Should be the same but no guarantee:
http://www.ebay.com/itm/Newest-Vander-CREE-Q5-1200-LM-18650-LED-Flashlight-Torch-3-Modes-black-/281724192679?pt=LH_DefaultDomain_0&hash=item41981207a7
The reason I am linking this is that it is a good host.
1. See the tailcap and its glorious screw-in tail. So much better than pressfit version that’s plaguing 90% of cheap lights.
2. The pill is… SOLID… for those solid-pill enthusiasts in here. Smile
3. The pill is also connected to body through screw-in washer, put this on tight enough and you’ll still have good direct thermal conductivity to body.
4. It’s 3 bucks. Nice host and fresh branding for this price.
The driver and emitter is lame though. Bluish bottom end tint emitter, and cheap 3-mode driver. This is good for harvesting host only, and you have been warned. :bigsmile:
Pregulla
Pregulla's picture
Last seen: 7 months 4 weeks ago
Not ebay, but $3.61 for Hugsby XP-1 is a great price
ImA4Wheelr
^ Shipping only $49.55.
EDIT: Now it says Free Shipping.  Not sure what that was about.
EDIT2: It's free shipping for one unit, $49.55 shipping for 2 units.
TheBo
TheBo's picture
shouldn’t it be XP -E R3? it says Q5
I’m wondering if they started to rip off even the good cheap ones…
Rufusbduck wrote:
Getting discouraged is normal but doesn't finish the job.
Lancman
Lancman's picture
Oh, it’s started all right but that one actually looks genuine. This one on the other hand…. :Sp
L4M4
L4M4's picture
Last seen: 1 month 23 hours ago
It says Q5 because much people (who bought this X2000 zoomie) know LEDs mainly by names like “Cree” and “Q5” – without knowing what it even means.
That’s why a lot of sellers write “Q5” somewhere.
TheBo
TheBo's picture
You are right, I was worried also about the other informations, since here on BLF, someone showed a XP-1 rip-off
btw seems the specs are totally wrong, or maybe are the photos….
Kim Dotcom
Kim Dotcom's picture
Last seen: 1 year 6 months ago
$1.99 (Free Shipping)
http://www.ebay.com/itm/281756374862
This one is kind of a gamble but I just bought one (only two left).
I’m not sure which flashlight is actually being sold since the item pictures show two different flashlights.
Also, the seller of this Vander flashlight accepted my offer of $2.75.
$2.75 – $2.95 (Free Shipping)
http://www.ebay.com/itm/281750725950
Hobbies: Infringing Copyrights ● Laundering Money ● Being Ridiculous
Sirius9
Sirius9's picture
Last seen: 15 hours 38 min ago
EDIT2: It’s free shipping for one unit, $49.55 shipping for 2 units.
Thats a good deal Big Smile for me shipping is only 90.65 US$ FedEX or $ 137.69 DHL They are pulling this numbers out of their buts Flat Stare
keltex78
keltex78's picture
I ordered the light from the second link about three weeks ago, and it arrived yesterday. This light is identical to the “Ultrafire” variant I reviewed previously:
http://budgetlightforum.com/node/35779
It has the very-loose-fit drop-in pill, and the plastic reflector/lens combination and the same “XP-E” (counterfeit?) emitter. As Pulsar13 pointed out, a strong point of this light is that the tailcap has a removable/replaceable switch with a proper threaded retaining ring vs. the cheaper press-fit style. Also, as I mentioned somewhere I can’t find at the moment, the battery tube from this host is a good fit on a 501b host, if you’re looking for something a bit different.
Due to the poor heatsinking, I would only use this as a host for lower-power builds. My previous Ultrafire ended up as a host for an EDC-sized UV build, and it works very well for that. Keep the factory reflector, or replace with a 20 mm aluminum reflector, replace the plastic lens with glass, and swap in a 3535-sized UV emitter (purchased via eBay). I’ll likely end up using the Vander host for the same purpose, but with the newer 365nm UV emitters I received at the same time… 8)
Antenne
Antenne's picture
Last seen: 3 weeks 2 days ago
Some time ago I’ve bought a similar cheap S5 copy from eBay in silver. It had the same loose pill. I’ve searched for a replacement and found a pill with the matching threads at Kaidomain: http://www.kaidomain.com/product/details.S024126
Instead of the reflector I’ve used a 30° TIR together with a XML-2 and a 101-AK-A1 driver.
But there goes the bargin… together with the new parts it’s a nice, working light but to be honest too expensive compared to other cheap hosts.
keltex78
keltex78's picture
That’s a nice looking pill via KD:
…but you are right… after ordering a $3 light and a $3.30 pill, you’re better off ordering the C20 host for $6.87 + BLF discount. Then you have a quality light with a good switch and a brass pill to work with.
Kim Dotcom
UltraFire AT-007
$3.61 (Free Shipping)
I have been tempted to buy one of these flashlights for a while now and so far, this is the lowest price I have seen.
http://www.ebay.com/itm/361352256422
ImA4Wheelr
I love that Hugsby and a good deal so I ordered one (not 2).  Aliexpress sent me email warning that the buyer protection was about to run out on the purchase.  So I opened a claim and said please wait as long as possible for the package to arrive.  Next day I was refunded.  Aliexpress said the vendor could not produce tracking information.
Anyone else that bought from this vendor may want to see how much time they have left to open a dispute.
