Fire-Foxes FF4 HID Flashlight Review (As usual, picture heavy)
82 posts / 0 new
SaCRiiD
SaCRiiD's picture
Rating: 9.5/10 stars
Site: Wallbuys
Listed Price: $237 USD plus shipping
Date Ordered/Received: 25th of March 2014, received on the 7th of April 2014
Link: Wallbuys Fire-Foxes FF4
Intro
When it comes to exotic flashlights such as this beast, supply is limited to certain stores. Wallbuys happened to offer this flashlight for the lowest price, and appeared to be a reputable distributor of flashlights amongst other gadgets.
I have been asked on multiple occasions about my enduring obsession with flashlights, and more specifically, owning the most powerful flashlights. I have also been asked why I spend so much money on flashlights, and this light is a prime example. Many people could not imagine spending over $200 on a flashlight, for obvious reasons. However this light is not just a flashlight. This light is the pinnacle of exotic “pocket-sized” flashlights; the offspring of motivation, inspiration and a passion for wickedly bright flashlights. And whilst this flashlight may not be the most practical in many situations, it represents perfection and the human desire for improvement and “more”. That being said, this light would be suitable for caving, hunting, and search and rescue operations.
Fire-Foxes is a Chinese owned company that specialise in HID flashlights, despite also selling LED flashlights. The predecessor to this flashlight is the FF3, which is also an amazing flashlight. Their flagship flashlight, the FF4, is recognised as one of the world’s most compact HID flashlight. Let’s have a closer look.
Initial impression (Unboxing)
Wallbuys shipped this flashlight in its retail box, enclosed with Styrofoam in another cardboard box. Despite their fantastic packaging, the inner box was slightly crumpled at one corner, although the thick foam that surrounded the flashlight ensured that it was nice and safe. The retail box also contained a piece of fluoro paracord (black would have been better?), a lens cap, a spare reverse-clicky switch, an information pack and of course, the flashlight.
The information pack consisted of a Chinese Manual, warrantee cards as well as an authenticity verification card.
The lens cap appears to be a camera lens cap for 67mm diameter filter threads, and is attached to a handy string. The addition of the lens cap is a unique touch of elegance that looks cool as well as being functional.
External packaging
Inside the package
WYSIWYG
Contents of the retail box (strange paracord colour)
Build Quality
I was surprised by how light the flashlight was when I first picked it up. Weighing in at a mere 500g without batteries and just over 700g with, this is one of the lightest HID flashlights. Despite this, the build quality was superb; the machining was perfect, threads were cut nicely (albeit a bit dry) and the reflector was spotless.
The design in general is quite eye-opening; the beefy heatsink on the head, the rubber covered clicky switches, and the rectangular cut knurling all look fantastic. Grooves are cut out of the primary heatsink to prevent rolling. “Fire-Foxes® FF4” is laser engraved onto the head, and on the other side, “Caution hot” (wise words of warning as this beast does get quite toasty after a while). This light tailstands very well.
Disassembled light
Light with batteries installed on scale
The anodisation is outstanding, and is very matte unlike the Skyray King. This is probably the best anodisation that I have ever seen. There are no missing patches or scratches to be seen anywhere.
The threads are of a round cut and are anodised like the body. Possibly the only complaint I have about this flashlight is about the dryness of the threads and o-rings. This is an expensive flashlight; would it really be that difficult to lube the threads at the factory? The harsh creaks that I heard as I unscrewed the tailcap were subdued by some synthetic motor oil, and a good cleaning. It may be the anodisation that caused the squeaking, which is quite reasonable.
Dry, round cut threads (Note double o-rings)
Heatsink fins and side switch (Coca-cola and SRK in background)
The pair of switches that tame this stallion are positioned on the bottom and side. Both are covered with a silicone boot. The side switch is black, and is surrounded by a thick stainless steel ring secured by four hex screws, adding to visual aesthetics. This switch seems to be a momentary switch, similar to the SRK. The bottom switch is a reverse clicky switch covered by a true GITD tailcap that illuminates when it is activated (more about that later). Both switches have a very solid tactile feel and seem to be of good quality.
The reflector is a SMO reflector, and is made of high grade polished aluminium. The reflector is flawless; there are no bumps, impurities or scratches, allowing for maximum efficiency. The custom parabolic design is suited for HID lamps, and as a result the shape is distinct from LED reflectors. The bulb is centred perfectly, allowing for a clean, circular beam pattern. Kudos to Fire-Foxes for perfecting the reflector!
The lens of the flashlight is made of uncoated glass, which is slightly disappointing. All lights in this price range should have an AR coating, and many do, but this doesn’t. Bummer.
Perfect reflector and uncoated glass (the little wire leaves a slight shadow in the beam pattern)
Size comparison (From the left: Skyray King, Coca-Cola, Fire-Foxes FF4)
Overall, this flashlight’s build quality is by far the best I have ever seen. The only shortcomings were the dryness of the threads (although to be fair not many flashlights come with lubed threads) and the uncoated glass.
Operation
This light accepts 4 unprotected 18650 batteries, which appear to be wired in parallel (poles are aligned), but are actually wired in series. Four Li-ion batteries wired in series can be a ticking time bomb if the batteries are not matched, therefore care must be taken to ensure that good cells are used. Batteries with protection PCBs will not fit, though trimming the springs will allow for protected cells to fit. The battery carrier houses a protection circuit, as well as the clicky switch. The carrier is built quite solidly, with solid copper positive contacts and thick gold plated springs. The carrier sits flush with the body tube of the flashlight; there is no rattling at all when the flashlight is shaken.
Battery carrier
Due to the high current draw, good quality cells should be used with this light. Many recommend the Panasonic NRC18650B (3400mAh), which provide adequate current and a fairly long runtime (1+ hours on 40W).
This light has 3 modes; high (40W) and low (24W), with a hidden turbo mode (60W). The quoted luminous outputs are 2000, 4000 and 6000 lumens respectively. I do not own a light meter, though others have confirmed that these ratings are quite close to the actual output. On click of the tail switch illuminates the green standby LEDs under the tailcap, and puts the light into standby mode. A press of the side switch initiates the ignition of the lamp at 40W. Being an HID flashlight, this light requires about 10-20 seconds to warm up to full brightness. A second press lowers the lamp down to 24W, and any further presses switches between these two modes. A long press of the side switch while in low mode brings the light into turbo mode. Turbo mode will cause excessive heat to be produced, therefore after a few minutes in turbo mode, the temperature sensor will trip and bring the light back to 40W mode. The light will step down to low mode when the batteries are nearing depletion, or if it gets too hot.
Even the 24W low mode is enough to blow many LED flashlights out of the water. The Skyray King cannot compete, neither can the Ultrafire C series or the HD series. The eBay HID had more throw (bigger reflector), but its 85W mode was equivalent to the 60W mode of the FF4. The eBay HID also had a comparatively colour temperature, 6000K, compared to the much more pleasing 4300K of the FF4. Side by side the eBay HID’s spot seems blue.
At 60W, this light outputs enough photons to blind a bear. The amount of light emerging from this tiny flashlight is incredible, and cannot be described with words. It truly is pocket sunshine.
The ballast would consume an extra 25% of the nominal power output, but the light is still very efficient.
Beamshots
From the left: Ultrafire C12, Skyray King, FF4, eBay 85W HID. All on high. (ISO 1000, f/27, 1/500")
At 60W the FF4's beam completely destroys the LED lights in terms of output. The 85W eBay HID is comparatively bright, but the colour temperature is much higher.
Outdoor beamshots are taken in a suburban backyard. Trees are around 50m away. Back fence is around 15m away. All photos have been taken with ISO 1000, f/4.8 aperture, and 1/8" shutter speed.
Control shot (ISO 1000, f/4.8, 1/8")
FF4 turbo (60W). Mouse over for eBay HID high (85W)
FF4 high (40W). Mouse over for eBay HID medium (65W)
FF4 low (24W). Mouse over for eBay HID low (45W)
(Just for fun) FF4 turbo (60W) and Skyray King High
The throw on the FF4 is definitely not as concentrated as the eBay HID, although the wide area illuminated is as bright as the spot that the eBay flashlight illuminates. This light is a photon cannon.
Conclusion
This light is just amazing. The build quality is amazing, the light output is phenomenal, and the compact form factor makes it even better. Obviously, this flashlight is not for everybody, but for those who are true flashlight enthusiasts, there is nothing else this small that comes close.
This is my first experience shopping with Wallbuys, and I must say that I am very impressed with their service. The staff were professional and courteous when I queried about the product. They shipped the flashlight on the same day that I ordered it and it arrived within 2 weeks!
This is not a budget flashlight. That is why I took off 0.5 from the score. But even so, it is worth every cent for every eye-searing lumen in the portable form factor. I recommend this light to anyone who is looking for the brightest “pocketable” flashlight, because it truly is!
Edited by: SaCRiiD on 05/09/2017 - 10:19
ryansoh3
ryansoh3's picture
Great photos, thanks for the review. Smile
BLF ≠ B-grade Flashlight Forum
atbglenn
atbglenn's picture
Last seen: 2 min 25 sec ago
Amazing! can you get spare parts if needed?
SaCRiiD
SaCRiiD's picture
To my knowledge doingoutdoor.com sell a spare battery carrier. As for the rest, I’m not too sure.
The bulb has a ~2300 hour lifetime, so sooner or later that will need replacing. I haven’t heard about anyone selling a spare FF4 bulb.
atbglenn
atbglenn's picture
chriszhou wrote:
To my knowledge doingoutdoor.com sell a spare battery carrier. As for the rest, I'm not too sure. The bulb has a ~2300 hour lifetime, so sooner or later that will need replacing. I haven't heard about anyone selling a spare FF4 bulb.
Plus there's a ballast that could go bad as well. I'll tell you though, it's very tempting to buy one of these. I can't believe how bright it is! Totally insane!
LSX
LSX's picture
Last seen: 2 hours 7 min ago
Thanks for the review. I was looking for a review like this before I bought mine but there wasn’t any good ones around.
I agree with all you have said. My FF4 still blows me away when I use it. Everyone else I show just stands there shocked at its output.
DayLighter
DayLighter's picture
Last seen: 11 months 5 days ago
nice light.. but how long can you use it before it shutdown by itself?
The only way to do a great work is to love what you do.
M4D M4X
M4D M4X's picture
Last seen: 42 min 31 sec ago
the light is just: wow!
find all available items in this list
i launched my new blog - all deals for members without MAP B$ Wink
find a short description about my idea here
if you want to buy a flashlight or battery for a better price: just send a mail - i will try to save you money!
sesgum
sesgum's picture
Last seen: 16 hours 53 min ago
Thanks for the great review. Look at that gorgeous tint when compared to SRK!
ImA4Wheelr
Last seen: 18 hours 47 min ago
Congrats on that awesome light and thank you for a great review.  I've wanted one of those lights since I first laid eyes on one.  You just made me want one even more.
HID's don't get much love here.  Nice to see there are a few HID fans still around.
unknown00101
Last seen: 1 day 16 hours ago
The ebay HID looks to have just slightly more throw, but that FF4 really shines with the massive flood and very respectable throw.
I imagine it has something to do with the reflector. My [generic 75w HID] has a pretty cheap reflector, but that ff4 reflector looks dang near perfect.
atbglenn
atbglenn's picture
I like that it uses 18650's instead of cheap chinese priority crap . This may be my next major flashlight purchase...
Jerommel
Jerommel's picture
Last seen: 1 month 23 hours ago
Whoa! 8^°
droooll….
..but costly..
Not in any way possible to adjust the focus, by moving the bulb more in or out somehow?
I like the big flood of light though!
PS:
Advantage of dry threads is you can drop parts in sand or what not, won’t stick in the threads when dry.
..waiting for parts..
Still looking for 5” parabolic reflector (for recoil light)
InfinitusEquitas
InfinitusEquitas's picture
Last seen: 1 year 8 months ago
For sheer power, with plenty of throw, currently nothing beats this light, relative to size.
Theoretically, if one were mechanically inclined, one could make a reflector extension to screw into the light... reduce the spill, and probably gain quite a bit more throw.
lawallac
lawallac's picture
Last seen: 16 hours 38 min ago
I know a lot of people that had purchased this light or any other HID have gotten rid of them because of the 10-15 sec warm up time. But even while warming up the lights will still output more light than many high-output LED lights. The FF4 is around 7000 Lumens on turbo and I measured 428K lux.
Even though I probably haven’t used my lights nearly as much as they deserve, I’m still keeping them. The ability to switch between modes on the FF4 is a huge advantage over the FF3, but, I actually prefer the simple single on/off operation of the FF3 and it has much better balanced feel. FF4 has a SMO reflector and FF3 has LOP.
lionheart_2281
lionheart_2281's picture
Last seen: 2 days 9 hours ago
Anyone considering one of these should first check this out:
http://www.candlepowerforums.com/vb/showthread.php?381409-WTS-MM15vn-Noah
More output, smaller, LED, but much less throw I’m guessing.
Even more expensive though…
InfinitusEquitas
The difference in the throw will be huge.  The MM15vn will be a flood monster, with ok throw dedomed, probably around 40kcd, but that pales vs the FF4 throw with 400kcd+.
unknown00101
This, and the VN costs more. I imagine it wont handle the heat those emitters produce as well as the HID handles the minimal amount of heat generated.
SaCRiiD
SaCRiiD's picture
It really depends on the batteries used and the mode.
With Panasonic 3400Ah NCR18650B, runtime should be 60+ minutes on 40W before it shuts down, and probably 75+ minutes on 24W.
60W shuts off within 5 minutes no matter what batteries you use, due to the thermal switch being tripped.
Although the thermal switch would probably trip before any of the aforementioned runtimes are reached
lionheart_2281
True, the MM15 will be a ridiculous wall of light, like a SRK on steroids. I imagine the FFIV would be like a TK75 on steroids (alot of throw and spill)
xmint
xmint's picture
Last seen: 3 years 6 months ago
Jerommel wrote:
Whoa! 8^°
droooll….
..but costly..
On the early ones there were some focus issues, mine was around the 350 kcd mark after burn in. It is possible to adjust the focus but it is not a couple of minutes work. A friend worked with mine and got to over 460 kcd but we knocked it back to 400 kcd as I preferred the beam pattern.
Bulbs are readily available as are carriers, the last time I asked the ballasts as well, though whether if you lived in the States the lipslockin still applied I don’t know. AFAIK the only problems in the wild concerned a few carriers. There is a five year warranty on them anyway, applies with the lipslockin I presume?
________________
Couple of things, Turbo is limited by a timer to 3 minutes not by a thermal switch.
If Turbo is not used, my standard FF4 has never thermally switched down to low from high, but then I live in the UK.
Concerning batteries, although the panny Bs & Gs work fine as do the Sanyo blue tops, the PD/PFs are better. I have used the 30a 2200 Sony and they also work very well the Sony 30a 2600s should also be fine and would have the runtime of the blue tops. The HD cells runs cooler and are better suited to the light and a necessity for a modded 4.
As for run-times I have never managed to get anywhere near an hour on high (standard FF4), in low yes. (on Bs) But now only use pd/pfs so obviously slightly less runtime.
Edit: Sorry should have said congrats chriszhou on getting the FF4 and the review!
The views in this post are mine, they are views and beliefs only, and not to be taken as facts.
leaftye
Last seen: 4 hours 41 min ago
It's amazing that LED flashlights are only just starting to catch up.  Vinh's Supbeam X60 comes very close, but at nearly double the price and no longer for sale.  There are a couple other lights that can match output, but I don't think any of those also have anywhere near the same throw.  I'm eager to see what the BTU Shocker v2 is going to be like.
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
xmint
xmint's picture
No way would I ever say ‘minimal amount of heat generated’ with regard to a FF4… it’s small…it gets Hot, but as you said it does handle it well.
Also If you are stuck without a lighter it can ignite newspaper. Great party trick LOL :bigsmile:
unknown00101
Minimal compared to 2x MTG2. Silly
I think I had the giant ebay HID in mind when I typed that. The ebay hid handles the heat ridiculously well for the sheer amount of output. I can definitely see a lot more heat generated in the tiny (by comparison) FF4 package. I did happen to see a few of those burn videos with HID lights. Pretty entertaining watching someone scorch cardboard with a flashlight. Smile
xmint
xmint's picture
Ah mt-g2s at 10A = heat = yup fun Oops I have found MT-G2s have zero chance of survival in my presence. I am zero for 6 at the moment :ghost:
Oh yes those ebay hid’s do have some beef to them, doubles up as weights for ones morning exercise :bigsmile:
InfinitusEquitas
I wish.  On turbo the FF4 generates an absurd amount of heat.  Personally after I run it for a while, 10-20 minutes max, I take it apart, take batteries out, separate out the tube and head.
The head actually gets hotter, 2-3 minutes after the light is off.  You could cook on it...
No need to imagine... http://laserpointerforums.com/f66/fire-foxes-4-vs-fenix-tk75-battle-big-... Big Smile
lionheart_2281
The head actually gets hotter, 2-3 minutes after the light is off.  You could cook on it…
No need to imagine… http://laserpointerforums.com/f66/fire-foxes-4-vs-fenix-tk75-battle-big-... Big Smile
Yep, I saw that thread of yours ages ago, it’s a really nice post with good information and really great photos
FmC
FmC's picture
Last seen: 2 weeks 4 days ago
I’ve always wanted one of these bad boys >)
Just tried to get one using the “FF4HIDWD” coupon, but the coupon did not work.
I’ve PM’d Cherry….but in the mean-time, is this currently the best deal for the FF4 ??
Cheers Beer
josn
josn's picture
Last seen: 2 years 6 months ago
Wonderful review, as far as i know, FF4 is the most powerful flashlight with long beam,except its “pocketable” design. I supposed that how long could FF4 run at Turbo mode. maybe 2-3 mins? it’s exactly suitable for flashight enthusias :bigsmile:
Ejected Filament
Ejected Filament's picture
Cheers Beer
Im pretty sure theres a BG offer at US$199. Needs a code, but search the BG thread. I might be confusing it with another though…
Edit: Here ya go
SaCRiiD
SaCRiiD's picture
Cheers Beer
Oh sorry that’s a typo.
It’s “FF4HIDWB”
It brings the price down to $208 USD, at least it did when I used it…
Personally I chose Wallbuys because it was the cheapest option, although I’m not sure whether that is still the case.
