Roche F6 hacking
274 posts / 0 new
Halo...
Halo...'s picture
Last seen: 3 years 7 months ago
Why did they make it 16340 instead of 18350? Oops
Tom E
Tom E's picture
Last seen: 18 min 4 sec ago
Weird - seems like they list stock on all 3, but you can only order the 14500. Could be the 16340 tube may fit 18350's - length is close, just a matter of the inside width - from the pics it looks like the 14500 tube is made with a thicker tube, dunno bout the 16340 tube.
I just submitted a Q to the seller - I'll find out, but probably they only have the 14500's left. This is basically an old Sunwayman C15A with the AA size tube, C10R with the 16340 tube.
This seller, btw, is  the tube manufacturer. Probably got stock with inventory, and tried to sell remaining ones off themselves.
Tom E
Tom E's picture
Ordered the 14500 tube on Sep 24th and it arrived yesterday in record time, no special shipping option! It fits the F6 light perfect!!
I mean perfect... Sorry no pics, but with the 14500 tube, the light is the same length as a slim AA zoomie with the head retracted, about 92 mm in length! SmileSmileSmile
Only negative is it has the same uncoated steel spring in the tail, but also has the same quality machining, anodizing and quality stainless steel cap with the accessory threaded hole.
Here it is, $10.46 shipped: http://www.aliexpress.com/item/Compatible-tube-adapter-m18650-14500-16340-tube-hard-oxygen/1908125904.html
tristanxoxo
Last seen: 8 months 3 weeks ago
I mean perfect… Sorry no pics, but with the 14500 tube, the light is the same length as a slim AA zoomie with the head retracted, about 92 mm in length! SmileSmileSmile
Thanks for the heads up Tom.
LightRider
LightRider's picture
Last seen: 1 year 11 months ago
Anyone have another source for these shorter tube options?
vresto
vresto's picture
Last seen: 58 min 5 sec ago
http://www.banggood.com/Maeerxu-CREE-XM-L2-Tactical-LED-Flashlight-Attack-Head-p-1022779.html
i bought right now this one..looks like roche copy..hm..i will open it and report…but,this light looks very very good:)
i just wonder-the battery indicator is only on the original??or made by you?:)
ah i see-ots the BG version..no more available anymore:((
EDC-Emisar D4V2 XPLHI,Sofirn IF-25,Mezzol X8R-L nw
Headlamp-Thrunite th30
comfychair
comfychair's picture
Last seen: 3 years 10 months ago
Halo… wrote:
Edit I see comfy’s digikey cart also has the indicator leds and resistors. The red led would get the higher value resistor. Since red uses a lower voltage it needs a higher resistor.
Incorrect. Tom has his resistors backwards. Yes, red LEDs have much lower Vf, but in this case the red is only on when VBAT is already significantly down, and most importantly the red appears dimmer to the eye. 1KR for the green, 470R for the red.
ToyKeeper
ToyKeeper's picture
Last seen: 4 hours 2 min ago
comfychair wrote:
Am I still asleep? Did comfychair make a new post? Is comfychair really “back”?
Tom E
Tom E's picture
Holy cow!!! Bout the resistors, oh boy - I've had it backward all this time? Not good... I still use the light regularly, though the old obsolete Sunwayman (forget model) is a better deal - more compact, lighter in weight - I prefer it. I grabbed a couple of the last ones from ILLUM.com a while back for a great price.
Man, I'm glad to see you back comfy!!! If I could figure how to insert a smiley face, I'd put in a couple dozen!
Halo...
Halo...'s picture
It’s all, a dream.
Hope you’ve been ok.
Also opps on the resistors. Oops
LightRider
Woa woa woa!!! Did I miss something? I just finished installing an rgbw driver in the f6. I put in the battery and I got out my DMM to test the voltage at the led dies to make sure I had it wired correctly. However, after 15-20sec I noticed it was getting hot and before I had the battery out it was hot hot! I believe it short from batt+ to the retaining ring. It was a button top battery and when tightend I can’t see anything from stopping a short. Did I miss something? Have others had this happen? Is it only compatable with flat top? I’m wondering if I reinstalled the contact assembly correctly, but I don’t know what I could have missed? Anyway, this just happened so I needed to vent. Let me know if you have an idea of what I could have done wrong…
LightRider
Here is a link to a picture. For some reason I can’t get it to show up without the link. http://m.imgur.com/a/f9xab
wight
Last seen: 2 weeks 16 hours ago
PPDB22 wrote:
[…] I believe it short from batt+ to the retaining ring. It was a button top battery […] Is it only compatable with flat top? […]
I don’t really have much helpful to say, but it seems to me that a flat-top cell would be the problem cell if there was going to be a problem . Flat tops have a wider contact area.
It’s good to see you post again.
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
mapache
mapache's picture
Last seen: 6 months 1 week ago
Probably a silly question, but did you remember to put the gasket back between the reflector and emitter?
Rufusbduck
Rufusbduck's picture
Last seen: 1 year 2 weeks ago
Could the spring slide off the button and short the tube?
Scott
comfychair
What’s hidden under the retainer? Is it a secret?
Dedicated F6 direct-fit driver? Some other driver piggybacked onto something else?
LightRider
Under the retaining ring is an rgbw driver from dr jones. I added some chips to the spring side of the driver so I had to mill out some of the underside of the retaining ring. Everything is still in the same place though. Only difference is that there is an extra layer of chips under the ring.
I fit the battery tube again using a thin insulator over the retaining ring. This kept the battery from shorting. I just can’t figure out why others havnt has the same problem. As it is for me, most batteries will make a short without the insulator there so I’m wondering if I didn’t assemble correctly.
For anyone who has an f6, is the little white insulator ring that is right around the spring contact button free to push in along with the button? On mine it is. If it were held in place, it would keep the battery away from the ring. But I can’t see how it could be held in place. Even if I glued it, it wouldn’t hold the pressure of tightening the battery and tube.
Sorry, I am normally not able to read at this time of day so my writing may not be clear.
Thanks for your help!
Tom E
Tom E's picture
Don’t have my F6 with me, @work, but I only use high performance flat tops in this light – would never consider using a button top, so I’m not sure how that white insulator ring works on my setup – I never had any troubles though.
comfychair
I use a very very stiff spring on the driver under the stock brass button. The squat beefy Nanjg 105C spring. It’s not quite compressed far enough to get coil bind but it’s close to it. I only use flat top cells.
The anodizing on these lights is very good, so there is (or should be) no electrical connection through the threads, only through the bare non-anodized face of the battery tube and the brass driver retainer. I think you fixed the short by making sure there’s no way to get -BAT connection to the rest of the circuit.
LightRider
Yes I think this did the trick. There has to be something that I changed for this to happen. Idk what though.
I was lucky. Normally I use a half drained Xtar protected battery for testing. This time however, I used a Sanyo 18650b unprotected because I gave my last protected cell away. After the event when the battery cooled down I checked the voltage. 255mv left in the cell. I completely drained the cell from a short circuit in less than 30sec. I’m thankful that nothing serious happens and I will be ordering some more protected cells.
…do you think I can revive this cell or did I ruin it for good?
wight
Personally I’d call that cell toast and walk away.
comfychair
It takes about 20 seconds to grab your meter and check between B+ and GND before you apply power the first time. You’d be amazed how many times a problem is discovered even when you ‘know’ everything is perfect.
LightRider
Ok. I’ll lay him to rest like a sick family pet… Maybe I’ll keep him on my desk a bit longer. He was my best and favorite cell Crying
wight
You’d think that ‘learning the hard way’ would eventually teach me this lesson. No luck yet. :-/
DrJones
DrJones's picture
Strange, my F6s never had an issue with that, even though I used cells with a quite large (in diameter) button top, unprotected. The white plastic insulator can be pushed in. Maybe you cell was longer and pushed up with more force?
LightRider
Yes. The cells are not longer, but I changed the spring in the tail and it is a much tighter fit. Maybe there is more room in stock form and the stock spring in the tail was much more loose than the driver spring. This would keep the cell from compressing the driver spring to the point of shorting out. I might have to take the tail apart again and adjust the spring. That’s not a fun task on this light, but doable. Either way, I’m now going to keep an insulator on the retaining ring. No more accidents. :-/
LightRider
Well. I’m terribly disappointed right now Sad I’m afraid that the battery short may have damaged the driver. I have it assembled now with no response to the button. I also tested with removing the battery tube. I connected it straight from the driver to a power source.
Now I need to disassemble the head. Getting all the wires through the holes was difficult so I was planning on not having to do that again. Im also afraid that I damaged the driver when adding Amc chips. Adding the chips went well so I’m not sure. This is the point in a build where you just need to put it down for a couple days. But dr jones is playing fun games related to this driver so he is making that difficult also Wink I’ll do some thinking, then take it apart.
lampyris
lampyris's picture
Hi folks, does anyone know where I might be able to buy a new switch for the F6 driver? I have looked at RS, but can’t find a similar switch. Any help with this is much appreciated.
Tom E
Tom E's picture
The Helios driver has it’s own switch. comfy published the complete parts list, think it was a DigiKey cart list wayyy back. Did you look at posts #20 and #21? Not sure if it helps. Dunno what RS is… If you can’t order from DigiKey in the UK, maybe you can at least use them as a resource to search for one?
comfychair
Need to know which version driver first. The early stock driver and the Helios driver use one type (http://www.digikey.com/product-detail/en/MJTP1117/679-2400-ND/1795496), the cheaped-out 7136 driver uses a smaller one.
