Test/Review of Tensai 16340 RCR123A 650mAh (Blue)
Official specifications:
  • Nominal Voltage: 3.7V
  • Rated Capacity: 650mAh
  • Limited Charge Voltage: 4.2V
  • Charge Current: 0.325A
  • Maximum Continuous Charge Current: 0.65A
  • End Charge Current: 0.044A
  • Maximum Discharge Current: 0.65A
  • Cut-off Voltage: 2.75V
A CR123 sized protected LiIon battery, i.e. this battery has the same length as a CR123 battery.
Performance is acceptable at least for one of the cell, the other cell has lower capacity.
Conclusion
The cell is not the very impressive, but as long as it is used one at a time it will work fine. Notice the size is correct CR123 size, not a few mm to long.
On this cell I have seen a UN38.3 test report, this shows that the cell is fairly safe.
Notes and links
The batteries was supplied by ENERDan for review.
Comparison to other LiIon batteries
CR123A and rechargeable substitutes
