Quick UF F-13 mod, for a member + beam shots
12 posts / 0 new
Old-Lumens
Old-Lumens's picture
Last seen: 3 years 3 months ago
Here's a simple and quick mod for the F-13 light.
13a
An F13, a Qlite 3 amp driver and an XM-L2 U2 1A on a Noctigon
Started at 10:20AM
13b
Complete tear down in about 4 minutes. I will use the stock driver as a contact plate and I will be doing the copper braid mods to the springs. I will also add 4 more chips to the driver. I expect about 4 amps.
13c
I have added 4 chips to the driver and I have soldered 18ga wire on the star.
13d
Arctic thermal paste, (not adhesive), is under the star. The reflector will push down on the star, when it's all together.
13f
I used a dremel to open up the stock driver, so it's an outer ring now, for ground. I soldered it to the Qlite driver. It's not very pretty, but it is held in place and it works. I wanted to add copper under the stock shelf, but with the 18ga wires and the extra chips, there just wasn't room. The stock shelf should be fine, it's thick enough and 4 amps should be ok, with no problems.
13g
Driver is in place.
Modified light on the Left, stock light on the right.
13b1
Same thing, but with a slower shutter speed.
13b2
I did nothing to make the spot larger. It's simply that the modified light is putting out more lumens, so the camera shows a larger spot, due to a more brilliant spot. That's my story and I'm sticking to it...
Now, it's off to pack it up and send it off.... In a day or so that is. I got to play with it tonight first.
Just about an hour and a half, to get it all put together and under a total of 2 hours, to get everything put away and beam shots done.
Oh, it measured 3.97 amps with a Sony 26650 and a 20R 18650.  It really does not have the room for a protected cell, at least the modded one doesn't.
Mouse Out = Modded HD2010   Mouse Over = Modded F-13
13bs1
13bs2
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Edited by: Old-Lumens on 06/10/2014 - 09:50
djozz
djozz's picture
Last seen: 13 min 17 sec ago
Nice, those are the basic mods that make all them cheap lights instantly desirable Smile
WarHawk-AVG
WarHawk-AVG's picture
Cheap basic upgrade…that is pretty much the defacto beginners mod right there…easy enough for practically anyone to do (other than the driver, moving the wire to the non-resistor side is the easiest but the Nanjg has alot better UI)
Awesome as always OL!
Oh there are a few contact rings made by wight that will help not have to strip stock drivers down
http://budgetlightforum.com/node/29562?page=29#comment-596518
http://oshpark.com/shared_projects/vDNmPf9B
MRsDNF
MRsDNF's picture
Last seen: 21 hours 4 min ago
Thanks OL. You will have to come up with some hotrod mods that dont involve soldering. Wink
sunnycoaster
sunnycoaster's picture
Last seen: 3 years 5 months ago
Still beginner modding so looking forward to doing this this weekend (except adding chips. I would destroy them in the process, so I'll use a new driver) Thanks Old-Lumens.
Tom E
Tom E's picture
Last seen: 1 hour 13 min ago
Nice quick job! Wondering though, to get 3.97A from a 4.44A (3.04A + 1.4A) configured driver with braided springs, 18 AWG wires, on a XM-L2 Noctigon, low resistance cell, seems like it should do better maybe? I'm thinking I've seen over 4A, maybe over 4.25A on something close -- can't recall exactly.
Even at 4A though, it's a lot of light from a relatively small, cheap light for sure...
Other note - that centering piece is probably blocking a bit of output. Could be filed/sanded down or replaced with a flatter one, but you may run into issues of the reflector not fitting tight -- more modding, ugh.... Bigger mod job Frown.
leaftye
Last seen: 3 weeks 3 hours ago
Maybe one of the 7135's is a dud.  That's why I like Warhawk-AVG's tester.
https://oshpark.com/shared_projects/Yzy2hxoA
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
Old-Lumens
That's a tail cap reading and I was having a problem making good contact with the end of the body. I really don't like ground seating on just the end of the tube, as it is not much of a seat at all. Might be a bad 7135 chip, but I didn't check right off the driver, so I can't say for sure. I figure 4 amps in that light is way more than enough. I thought about the centering ring, but I am seeing that Mfgs are using them to "make a tighter spot". At least that's what they seem to be doing and with them. Cut down, the spill seems to be brighter. Well, that's what my eyes tell me, but hell, sometimes I see spots with no lights on...Laughing
Old-Lumens
Well, that bonfire photo you had in your build thread is probably a "hot mod" and it doesn't need soldering.Tongue Out
Old-Lumens
Added beam shots in the OP
MRsDNF
MRsDNF's picture
Thanks OL. As usual nice shots. Do you think you can keep modding it until its brighter than the HD2010? No you cannot send it to me. Thanks again. Wink
Chicken Drumstick
Thanks OL.
That white centering ring really does affect the throw and OTF I think and of course makes that weird perfectly round hot spot.
I’m not convinced the reflector is actually designed for an XM-L/2 at all, it just doesn’t seem to focus them right at all, and the white ring seems to be a last ditch effort to make is usable. I wonder if the reflector was really intended for something like an XR-E.
