Test/Review of Brillipower 26650 4000mAh (Black)
Official specifications:
  • Model: Li-ion 26650
  • Brand Name: Brillipower 26650 4000mah
  • Nominal capacity: 4000mAh
  • Nominal voltage: 3.7V 26650
  • Battery material: Li-ion battery
  • Positive pole: Flat top
  • Impedance: <80mOhm
  • Cycle life: >500 Cycles
  • Operation temperature: Charge(0 ~ 45°C)Discharge(-20 ~ 60°C)
  • Storage Temperature: -5 ~ 35°C
  • Dimension: Diameter 26mm, height 65mm
  • Weight:About 95g
The large size LiIon battery with more capacity than rated.
The two batteries tracks fairly well, but the over current protection is a bit low, it trips the 5A trace.
Conclusion
The cells used looks good, but the protection current limit is on the low side, and the battery does not have that great performance at a couple of ampere, compared to other 26650 batteries.
Notes and links
The battery was supplied by msitc-shop for review.
