I'll just start off with the spoiler. It really is over 7,000 lumens. So if that is what you are looking for you can just skip the rest of the review. Not kidding guys this thing is amazingly bright.
Light provided by Lightscastle for review. Non-affiliate link below.
This is their info on the light.
Brand:UltraFire
Model:LW-12L2
Quantity:1
Material:Aluminum Alloy
Color:Grey+Silver
Emitter Brand: Cree
LED Type:XM-L
Emitter BIN: T6
Number of Emitters:12
Color BIN:Cool White
Working Voltage:7.2-12.8V
Power Supply:3*18650/3*26650
Current:2800mA
Theoretical Luminous:7920LM
Actual Luminous:7200LM
Runtime:2~3hrs
Number of Modes:5
Mode Arrangement:Hi>Mid>Low>Fast Strobe>SOS
Mode Memory:No
Switch Type:Reverse clicky
Switch Location:Tailcap
Lens:Glass
Reflector:Aluminum Smooth
Working Depth Underwater:300m
Strap/Clip:No
Other Features:Hard anodized
PackingList:1 x Flashlight
3 x Battery sleeves
Just to start with a few corrections. Although this light does have very nice O rings I still don't think it's possible that it can function at 300m underwater. And it does in fact have memory mode. Unfortunately it's next mode memory.
THE GOOD
It's unbelievably bright
Did I say it was bright?
The driver is a very simple FET model with really nothing to go wrong with it.
I like the finish a lot on this light.
The heatsinking is excellent with the large fins it conducts heat well and considering how many lumens this thing is pumping out it needs it.
Did I say it was bright? Well it is it's easily the 7,200 they claim. In fact with my Sony 30amp batteries it was close to 8,000 on startup and the 7,200 was right on the button with king kongs.
The beam pattern is super on this light. It has a ton of flood with no rings and it actually still has a decent hotspot too.
Switch and springs are all good quality
All Led's well centered in their rings and on one large star that was held down with the correct amount of thermal paste.
the emitters were all clean.
THE BAD
Next Mode memory tops the list and is really the only thing I don't like about this light.
I could not run this light on protected batteries. The amp drain was so high that it popped the protection. I would really only recommend this light for really high quality high amp batteries.
The Average.
Typical 5 modes with two of them being blinkies.
Clear glass lens but not AR coated like higher end lights. But still it's very clear and came in clean.
Reflector is on par with these lights.
The led spacers are Good, not too high that they effect lumen output but could have been a tad lower I guess.
Cool White Tint
MOD POTENTIAL
I think it would be possible to get rid of the next mode memory. The Star is removable so a person could de-dome the emitters if they wanted to. The wires could be replaced with heavier ones. Of course if a person wanted the emitters and star could be replaced with sinkpads and XM-L2's. Spring mods would also bump this light up a bit. Who knows it might even be possible to hit 10,000 lumens with this light.
BACK STORY
Many of you have already asked me about this light and know that I have recommended it. Also this review is overdue because I was supposed to have been sent an XM-L2 version. Lightscastle's supplier dropped the ball on this twice. However I can see how it would be missed. The spacers are so tight that you can't see the green boards under the reflectors so it seems as if they are silver because all you get to see is the tiny silver that is apart of the emitter itself. Lightscastle fixed their listing on this so they are being sold correctly with the listing stating XML-T6
CONCLUSSION
Buy this light if what you are looking for is a barn burner of light. This is by far the brightest stock light that I have owned and I have owned a bunch of multi-emitter lights including a 15x and other 12x's. It has a great beam profile and I am very picky about lights with ringy beams. The only real downfall is the next mode memory. If you can get past that buy this light. Outside of getting a modded up light there is nothing else that I know of that comes close to this light in pure power.
