Home Depot Deal Alerts & Discussion Thread
2565 posts / 0 new
ActiveAl
ActiveAl's picture
Last seen: 14 hours 2 min ago
The Defiant 500-Lumen Utility LED Light is $9.97 at Home Depot. It runs on four AA batteries which are included. Actually the batteries provided are Defiant alkaline batteries with a 2023 expiration date.
The light is cool white and the beam is very homogeneous over about a 160 degree cone. The advertised 500 lumens looks accurate. Since I'm going to store it in the trunk of my car, I replaced the alkaleaks with AmazonBasics High Capacity Ni-MH AA batteries. Plenty of room is provided in the battery compartment for these slightly over-sized high capacity batteries. The overall build quality of this utility light is actually quite good.
This Home Depot special has been posted on BensBargains.com off-and on for a week, but I haven't noticed it in this thread. Pardon if I've double posted.
Edit:  If anyone is interested in some limited test data on AmazonBasics High Capacity Batteries, check out this post. << Conclusion, you may be better off with Eneloop batteries for longevity.  Edited.>>
Pete7874
Pete7874's picture
Last seen: 3 hours 32 min ago
Nice work light. I might have to check it out.
Costco had a deal recently on a pack of 2 CAT 500lm work lights for $9.97, and they had 2 brightness levels, but that deal seems to have expired now.
Pete7874
Pete7874's picture
After watching some youtube reviews, I ended up picking one up. The main complaint about it is fairly short runtime – realistically about 2 hours, but with plenty of NiMH cells on hand, I’m not too worried. Otherwise, it seems like a pretty good utility light. I like it. Thanks ActiveAl for heads up!
ActiveAl
ActiveAl's picture
Pete, thank you for the photos, the YouTube tip, and helpful info about the run time.  I looked at several of the YouTube videos, and this one was my favorite. In it, the guy disassembles the Defiant utility light, puts in a tripod mount, adds a stick-on heat sink to some very hot resistors on the circuit board, and reassembles. It is a little long (35 min) but was entertaining.
Pete7874
Pete7874's picture
I thought I’d verify runtime on this Defiant 500 utility light. This is using AmazonBasics High Capacity NiMH cells and ceilingbounce app:
Test #1: NiMH
As you can see, the light flatlined after about 24 minutes and it would not turn back on. The cells were at 1.27V when I pulled them out and were fairly warm. I put in another set of cells, and the light still would not turn on. I waited half an hour. Still no signs of life. I opened it up, but did not see any burned elements and nothing smelled burnt. I put the light back together and it started working again. Weird. I’m currently recharging my NiMH cells so that I can redo the test and see what happens this time.
Wondering if it’s some kind of overheat protection mechanism that shut it down? Maybe this light wasn’t designed to run on as much current as NiMH cells can deliver? I haven’t come across anything that would suggest that…
Anyone else care to do a runtime test on theirs?
Test #2: NiMH
This time I had the light standing vertically up on its long side. The previous run where it failed, I had it standing on its shorter side – maybe it did not like that?
The light was still on when I ended the run at about 120 minutes, but the light was fairly dim at that point. Cells were down to around 0.9V after I pulled them out.
EDIT
Test #3: Alkaline
FYI, the light continued to run for a long time past 120 minutes, at this low, roughly 4-5% light output.
Initial lumen output on NiMH was about 35% higher compared to alkaline. But from about 100 minutes onward, the light output on alkaline cells was actually higher than on NiMH, although both were fairly dim at that point – only good for maybe a night light.
Boaz
Boaz's picture
Last seen: 3 hours 2 min ago
 My question is how badly does having the tweeter in front of the woofer affect the bass?
i bought these instead .... Baby said..  bump bump
                                  https://www.gty.org/
    Still selling diffuser film  >…  http://budgetlightforum.com/node/42208
nottawhackjob
Last seen: 2 weeks 5 days ago
“ My question is how badly does having the tweeter in front of the woofer affect the bass?”
If you play Electric Light Orchestra tunes it really rocks otherwise it sounds like Barry Manilow kicked in the nuts.
“In many things in order to truly understand the small picture you have to understand the big picture first.”
Pete7874
Pete7874's picture
FYI, I found a “stereo” version of this light on Gearbest
This one can be powered by either AA cells or 18650. It also has 2 USB ports – not sure what exactly they’re for, or what the lumen output is.
Klotski
Klotski's picture
Last seen: 2 hours 22 min ago
!{width:100%}https://des.gbtcdn.com/uploads/pdm-desc-pic/Electronic/image/2018/08/31/...!
Pete
I believe the micro USB is for charging and standard USB is power bank function, I purchased one but has not arrived yet.
Pete7874
Pete7874's picture
Yeah, but charging which cells? The 18650 cells maybe. I don’t think it would be a good idea to charge 4 AA NiMH in series.
Also wondering if you can also use the micro USB port to power the light from a wall plug without any cells in it.
Please let us know when you get it, if you can.
garrybunk
garrybunk's picture
Last seen: 4 hours 25 min ago
Modes: High, Low, & Strobe! LOL! Why on earth would they include strobe??!!! I’m interested in hearing more about this light (or various other similar models on GearBest).
(Now this thread is going off-topic.)
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
NOTE: Moving my photos from PhotoBucket to Flickr. PM me or post in the thread if you can’t see my images and need me to fix or send a gallery link. PhotoBucket images should remain visible until November 2018.
ActiveAl
ActiveAl's picture
Pete7874 wrote:
. Also wondering if you can also use the micro USB port to power the light from a wall plug without any cells in it. Please let us know when you get it, if you can.
According to Gearbest, you can't run it on USB power alone. Here's the correspondence:
Dear ActiveAl,
Thank you for your inquiry regarding https://www.gearbest.com/led-solar-lights/pp_009306164569.html
Your original question is "Can this light be operated without batteries on USB power? Thanks!"
Here is the answer from Our Customer service Team:
Hello ActiveAl,
This product can be charged and you need to use it after charging.
Let me know if you need any further assistance.
I was also curious so I contacted them through the Ask a Question link on the product page, and got a reply within 36 hours.
Pete7874
Pete7874's picture
Agreed. Having a low mode is nice – I wish the Defiant light had it. But strobe? That’s idiotic unless maybe if you plan on using it as a disco light.
Also, to get back on topic: final update on that Defiant 500 lm utility light from HD: it ran for 72 hours non-stop on alkaline cells. Granted, the light output was fairly low after the first two hours or so, but still usable to find your way around in the dark, at least during the first 24-36 hours – roughly 10 lumen (guess).
Pete7874
Pete7874's picture
Thanks. I also asked them a question, but never got a response. I was hoping they would just post the answer in the Q&A section on the product page.
garrybunk
garrybunk's picture
I just noticed that dchomak hasn’t been on BLF for over 3 months now. Hope everything is ok with him. Unlike him not to post Home Depot deals for such a long stretch!
-Garry
Bort
Bort's picture
Last seen: 4 days 22 hours ago
-Garry
Indeed, i always looked forward to his posts
I also hope all is well with him.
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
ruffles
ruffles's picture
Last seen: 3 weeks 5 days ago
@pete7874 — When the gearbest light finally comes, can you let us know the color temperature as well as all the charging stuff?
Pete7874
Pete7874's picture
I did not buy one.
ruffles
ruffles's picture
Oops — that’s what I get for reading too fast. Maybe @Klotski will be able to help us out…
Klotski
Klotski's picture
This is the one I bought https://www.gearbest.com/led-solar-lights/pp_009610562020.html?wid=1433363
-No light wont work with Micro USB without batteries it does with batteries installed.
-Micro USB is for charging the 18650 batteries only
-The 4 AA NiMH are not charged with Micro USB
-USB port is supply for power bank output
-UI starts in hi, low then strobe
-I was using some batteries from a laptop pull that measure 65.MM and they fit really loose.
I like the light and I am going to try and find one without the strobe function.
ImA4Wheelr
Last seen: 2 days 14 hours ago
garrybunk wrote:
I just noticed that dchomak hasn't been on BLF for over 3 months now. Hope everything is ok with him. Unlike him not to post Home Depot deals for such a long stretch! -Garry
Oh my, he seemed to be around less frequently.  But 3 months is more than just being busy.. I sure hope he has just been pulled away by a new interest.  Man, I hope he is doing ok.
Pete7874
Pete7874's picture
Ballpark lumen output?
tatasal
Last seen: 14 min 26 sec ago
I’ll wait for the Quadrosonic version then BeerBig Smile
tatasal
ImA4Wheelr wrote:
garrybunk wrote:
I just noticed that dchomak hasn’t been on BLF for over 3 months now. Hope everything is ok with him. Unlike him not to post Home Depot deals for such a long stretch! -Garry
Yeah, l sent him a pm a month ago and no reply yet.
Klotski
Klotski's picture
I don’t have much to compare it and would only be guessing 250- 400 lumen its lights up a 8-10’ spot on the wall at at 6’ away.
mmalive
Picked up new Defiant 1200 lumen flashlight, usb powerbank flashlight combo x 2.
BTW, where’s Dmchock? He is the king of deals from Home Depot?
lichan
Last seen: 1 day 7 hours ago
Dchomak hasn’t been on in over 4 months and I fear that is not a good sign! I’m sure he has been messaged and I fear the worst.
keithd
keithd's picture
Last seen: 2 months 4 days ago
Hey all,
Found these shelves on sale, for 1 penny:
I got the last 2 at the Papillion, NE store and the sales lady didn’t want to sell them to me for 1 cent. Luckily the duty manager didn’t care. I didn’t know they were a penny when I went to pay for them, else I would have done self-checkout.
I saw these on the clearance rack:
I found these at the clearance rack of more than 1 store, they have been there for a while.
BTW – there’s a Milwaukee impact in the clearance listed for $210.00, is that the lowest it’s gonna go?
ActiveAl
ActiveAl's picture
A three-pack of defiant 80-lumen headlamps is on sale at Home Depot for $9.97. Check this post for the link and a short review.  Somehow we now have two Home Depot threads - one is just for flashlights.
Boaz
Boaz's picture
lichan wrote:
Dchomak hasn't been on in over 4 months and I fear that is not a good sign! I'm sure he has been messaged and I fear the worst.
  I looked to see if I had his address since he had sent me a light . I was surprised that I couldn’t find his address since I consider him a true friend here on the forum.
 If anyone has it You can pm me and I’ll drop him a note in the mail.
In my mind he’s either “ lost his mind  n muttering  ‘penny penny penny ‘ at a home depot “ ... ‘“ too busy to be posting on BLF” or died in his garage pinned to the wall when 4 pallets of Ryobi drills toppled over  and now he’s in heaven watching over all the home depots he loved so dearly .
Clearly a truly great BLF member who is missed no matter the circumstances.
