Recommend flashoholic to play this light.
Work with 20W,50W,100W,240W incandescent lamp; Come with 100W bulb by default. Fairly easy to replace different bulbs.
Flashoholic Version include:
Flashlight+ 3x18650 battery carrier+6x18650 battery carrier (all in series) +6x18650 battery carrier(3 parallel ;2 series) 100W bulb 1 battery pole (to help cut down and adjust the voltage; see last picture)
Emitter: 24V 100W incandescent bulb ( Can be replaced by 3.7 20W ; 50W;100W;200W bulb )
Battery: 6 x18650 FOR 100W / 240W bulb (need to use 10A~15A 18650)
3 x18650 For 12V 20W / 50W bulb (Normal 18650)
Dimension: 180mm+65mm (Length with extention tube) x 70mm head x47mm body
Netweight: 470 g / 570g with extension tube
That looks like a BTU battery caddy in the first pic. That extension tube kinda looks like BTU knurling too. I’d be willing to bet that…
The only issue would be the 6s battery carrier. Unless the BTU can operate off of 7.4v, in which case a bit of careful dremeling and drilling and soldering would rehash it into a nice 2s3p carrier.
Our many requests for a 6 x 18650 battery carrier for the BTU Shocker was mostly ignored and unanswered in both threads and in all my emails to Ric. Sorry Ric, but that’s just really bad business. :Sp You snooze, you lose. Now Acebeam has taken your market and produced a superior product.
Now we have a MUCH BRIGHTER light that completely annihilates the BTU Shocker and holds 6 x 18650 to power 5 XM-L2’s. The price is also very attractive! The group buy sale for the Supbeam X60 is under way.
Not even close. Street lamps are HID, and are usually 250W, 500W, 1000W HID at that. Now, if you live in a city that has sidewalk post lights, you may be able to outshine one of those with the 240W bulb in this light. Maybe.
