BLF Community Battery Pulls Overview Thread (Laptop packs and Tool Packs)
374 posts / 0 new
Legolas Jr.
Legolas Jr.'s picture
Last seen: 11 hours 7 min ago
kronological wrote:
Scored these 4 battery packs at Best Buy a few weeks ago:
Here are the details on them individually:
Lenovo Thinkpad
FRU P/N 45N1027
ASM P/N 45N1026
EU Min 7740mAh
9 orange batteries, UR18650ZT R1122
Other codes on battery: Q26C, QF3ZTBD, 065413
All tested at 4.29mAh right out of the case! :bigsmile:
Toshiba PA3793U-1BRS
10.8V 4200 mAh
6 green batteries with black tops, CGR18650CE, MH12210
Other markings: A19 LXI, B9808, 949 (or 919) 67P EE9
Made in Japan
2 batteries at 3.78mAh, 2 at 3.80mAh and 2 at 3.81mAh Smile
Dell FK890
11.1V “Japan Cell”
9 Lavender batteries with black tops, CGR18650E, MH12210
Other marking: E7810
3 batteries at 4.05mAh, 3 at 4.06mAh and 3 at 4.06mAh :bigsmile:
Dell Ky265
11.1V
9 Pinkish/Lavender batteries
Samsung ICR 18650-26D SDI 972
3 cells at 0mAh, 3 at 1.4mAh and 3 at 2.15mAh Sad
Are the last 3 salvageable at 2.15mAh???
I think you mean V instead of mAh. Wink
“Strive to be a warrior and a scholar. Be forged in fire and tempered by knowledge. If not, you will either lack the courage to fight for your ideals or lack ideals worth fighting for.”
kronological
kronological's picture
Last seen: 1 year 4 months ago
Der…my bad.
Corrected.
No one, after lighting a lamp, puts it away in a cellar nor under a basket, but on the lampstand, so that those who enter may see the light.
My Reviews: Ma
Otanacious
Otanacious's picture
Last seen: 4 months 1 week ago
I joined late last week so I could post this harvest album; Only now do I decide to post it Silly
Notes on opening packs/VDCs in the descriptions for the images. Image thumbnail is a link, otherwise here
Batteries (Not in Order):
DELL branded C6017 (14.8v 4800mAh 71Wh) --> 8x Samsung ICR18650-24E
HP branded 416996-163 (14.4v 63Wh) --> 8x Sony US18650GR
DELL branded JKVC5 (11.1v 48Wh) --> 6x LG LGDAS31865
Generic HP (Barcode: HP8028LH121105070048; Warranty Sticker: 00761E07B) [14.4v 5200mAh] --> 12x Lishen LR1865AH
Sony branded VGP-BPL2 (11.1v 7200mAh) --> 9x Sanyo UR18650P
Generic HP (Warranty Sticker: 00761D14B) [14.4v 7800mAh] --> 8x Lishen LR1865SF
Tools Used:
Needle Nosed Pliers
Wire Cutters
Chisel
Cheapo Harbor Freight MM
2x Nitecore 2014 i4s
1x HZS-002
1x FT charger
Electrical Tape (I was brutal on the shrinks)
downlinx
downlinx's picture
Last seen: 3 weeks 4 days ago
DELL C6017
HP 416996-163
DELL JKVC5
Sony VGP-BPL2
Tools Used:
Needle Nosed Pliers
Wire Cutters
Chisel
I am interested in what cells these batteries produced. Thanks for the post.
BLF Community Battery Pull Thread http://budgetlightforum.com/node/32720
Otanacious
downlinx wrote:
Otanacious wrote:
snip
The thumbnail image is a link Wink
Suncoaster
Suncoaster's picture
Last seen: 1 week 6 days ago
Location: Where the girls are green and the grass is pretty.
2004 Toshiba laptop.
18650 cells
Battery Pack: PA3382U-1BAS
DC 14.8V – 6450mAh
12 Sony US18650GR 2150mAh Green with Black washer
6 cells read 0V, 3 cells read 1.50V, 3 cells read 2.60V
"In the land of the blond the one eyed man is king."
*This message is protected with ROT26 encryption.Old Lumens
Suncoaster
17670 cells
Battery Pack: PA3481U-1BAS
DC 10.8V – 1200mAh
6 Sony US17670GR 2150mAh Green with Black washer
5 cells read 1.50V, 1 cell reads 2.70V
M4D M4X
M4D M4X's picture
Last seen: 24 min 14 sec ago
izzie wrote:
I’m new to the site, but I have a bunch of these Philips packs (M4605A) out of medical equipment. They get replaced every 2-3 years regardless of use. They contain 9 CGR18650CG (MH12210) each and were exceptionally easy to pull compared to the drill packs I’ve done. Cadex charger primed the cells and all of them reached at least 90% of the rated capacity. As back up batteries they probably haven’t been cycled at all and arrive at full charge to be recycled.
I also had 2 of them (another 7 had a friend)
Philips actually have a recall running due to capacity loss before 3 years change cycle!
we measured them between 950 and 1200 mAh …
into the bin!
find all available items in this list
i launched my new blog - all deals for members without MAP B$ Wink
find a short description about my idea here
if you want to buy a flashlight or battery for a better price: just send a mail - i will try to save you money!
Otanacious
Album Link
IBM branded 92P1011/1062 (10.8v 4400mAh) --> 6x Sony SF US18650GR
Lenovo branded 42T5229/5230 (10.8/14.4v 5200mAh) --> 7x Sanyo UR18650FM
IBM branded 08K8193/92P1064 (10.8v 4400mAh) --> 6x unmarked Sanyo UR18650FJ
dchomak
Last seen: 9 months 3 weeks ago
Otanacious wrote:
Album Link
IBM branded 92P1011/1062 —> 6x Sony SF US18650GR
Lenovo branded 42T5229/5230 —> 7x Sanyo UR18650FM (win!)
IBM branded 08K8193/92P1064 —> 6x unmarked Sanyo UR18650FJ
I noticed in your album link that you are “jump starting” cells that are sitting at voltages too low to charge with your i4.
While that may work to get them to charge, these are NOT like Ni-MH or NiCads and this is NOT a good idea. All that energy that those over discharged cells accept could suddenly and catastrophically be released in a very short time (fire). At the very least, I am sure you have already noticed that those “jump started” cells have a high self discharge rate. That alone make them of no use, and if they self discharge in a short period of time you have a problem. You should safely discharge those cells and recycle them ASAP.
Besides, you now have many cells and can “afford” to be selective on which ones you keep. As a rule of thumb, any cell discharged to below around 2.5V is irreversibly damaged and should be recycled.
millerman
millerman's picture
thanks great info in here
This space intentionally left blank…..
Otanacious
Will take that into account; I've had SOME luck with quality cells, but I don't want to push it.
strumble
Last seen: 4 years 4 months ago
I opened my 1st laptop battery pack last week, was from my 6yr old abused Dell Inspiron 6400, the battery failed to hold more than 2mins charge around 4yrs ago and has been used from the mains daily with battery attached for last 4yrs.
Inside were 6 x pink samsung ICR18560-26C, all voltages were 3.4v-3.8v, charged them to just under 4.20v and 5 days later they are all around 4.10-4.15v.
Sorry but I forgot to note down the exact battery part before I trashed the plastic casing, I do have some packs coming my way though so will record the details for the thread.
downlinx
downlinx's picture
Thanks guys, I have been really busy lately and will get things updated soon.
Ledsmoke
Ledsmoke's picture
Last seen: 1 week 3 days ago
Dewalt 4.0 Ah 18 V packs contain 10 pieces of Samsung 20R batteries (green color) 2000mAh.
~ Ledsmoke ~
Dutch humor:
[quote=djozz]
 I do not think that the BLF-community ben
comfychair
comfychair's picture
Last seen: 2 years 11 months ago
dangerous wrote:
Laptop Battery - Acer 5200mah http://www.ebay.com/itm/Acer-Battery-6-cell-5200mAh-BT-00607-074-NEW-OEM... 18650 Battery 6* Samsung ICR18650-26C 2600mah !http://i.imgur.com/cB4NvNO.jpg![/quote]
I've ordered 10 of those & will update when they arrive, relisted here: http://www.ebay.com/itm/141355585144
That's the same seller that had another batch of different ones a while back, can't remember if they were the Panasonic 2900s or Samsung 28As...
TheGloriousTachikoma
Last seen: 3 years 2 months ago
comfychair wrote:
dangerous wrote:
Laptop Battery – Acer 5200mah http://www.ebay.com/itm/Acer-Battery-6-cell-5200mAh-BT-00607-074-NEW-OEM... 18650 Battery 6* Samsung ICR18650-26C 2600mah !http://i.imgur.com/cB4NvNO.jpg!
I’ve ordered 10 of those & will update when they arrive, relisted here: http://www.ebay.com/itm/141355585144
That’s the same seller that had another batch of different ones a while back, can’t remember if they were the Panasonic 2900s or Samsung 28As…
The white ones were Samsung -28A cells.
Also, a Dell PT434 battery comes apart fairly easily. Had one for my ‘gaming’ [it will run WoT on low graphics, and RCT3 @ max cleanly] laptop that wouldn’t hold a charge, popped it apart and the six 2550mA USGR’s inside tested between 3.7 and 3.8v.
Otanacious
Playing battery roulette at the flea market...
Album Link
Sony branded VGP-BPS5A (7.4v 7800mAh) --> 6x Sanyo UR18650FM (All dead; 0.05-0.06v)
Dell branded TC030 (11.1v 85Wh) --> 9x LG LGDB118650 (3x 0.00v 6x 4.12v)
Will heed dchomak's warning and not push my luck Silly
strumble
HP MU06 notebook battery for CQ42 / CQ62 / CQ72 / G62 / DM4-1000
HP P/N: 593562-001
6 cell 11.1v 62wh 5225mah
Samsung ICR18650-28A
scottyhazzard
scottyhazzard's picture
Last seen: 1 week 5 days ago
Thanks for doing this! It’s a huge help.
"Those who hammer their guns into plows will plow for those who do not."
comfychair
26F/26C and 28A have about the same capacity when both are charged to 4.2v, is there any data on whether the 28A will have a longer service life than 26F/C when used under the same conditions?
Otanacious
Album link
Lenovo branded 42T4690 (11.1v 3900mAh 44Wh) --> 6x Panasonic Prismatic CGA103450A @ 1950mAh (1x 0.00v 2x 2.2v 1x 2.6v 2x 2.7v)
These, according to the series name in this datasheet, are LiCo cells, which might make me look like an idiot for doing this.
some info from Keeppower about these
downlinx
downlinx's picture
I got some of these from a Toshiba laptop about a month ago.
Otanacious
Any circa 2011+ ultrabook will most likely carry cells like these in their packs. Too bad there's no host to accommodate them Silly
downlinx
downlinx's picture
I am still working on getting you guys updated in the spread sheet. Some have been updated and will try to get the rest tomorrow and tonight
Otanacious wrote:
Any circa 2011+ ultrabook will most likely carry cells like these in their packs. Too bad there’s no host to accommodate them Silly
A Li-ion powered [pistol grip] spotlight? Dremel-out the peaks in a SRK battery tube and put a coupleafew of those in? A test-bench for driver and LED tuning?
eas
eas's picture
Last seen: 2 days 4 hours ago
Otanacious wrote:
Album link
Lenovo branded 42T4690 —> 6x Panasonic Prismatic CGA103450A @ 1950mAh (1× 0.00v 2× 2.2v 1× 2.6v 2× 2.7v)
Thanks, I’ve never seen those before. Interesting alternative to the pouch-cells that Apple seems to have switched over to.
What is the problem charging them in that charger? The datasheet lists 3.7V nominal, 4.2 charge termination.
comfychair
Would the thread be somehow less informative if the updates were placed in the first post instead of the second?
downlinx
downlinx's picture
I have bee tossing around that idea for a couple days now. When I get a chance I will switch them around. I wish I could add another editor to the spreadsheet post.
GottaZoom
GottaZoom's picture
Last seen: 8 months 1 week ago
The change could better for some. When I open a thread it is only the new posts and in reverse order (except for the original post (post zero). So it is better if the original post is an intro or is packed with info/links and not packed with large images. This also reduces the download streaming requirement at my end – and on the website.
