Finally.. after a very long time, and many tries..
I could get the head of my Klarus P2A off.
The Klarus P2A was one of my more expensive torches I bought a few years back...(just $32) from dinodirect.
First I bought another little strap wrench. (now I have 2).
Then I put the head in a small plastic ziplock bag, and put in the freezer for about 5-8 hours.
(some of you will see the polished fins.. they were damaged in earlier tries, so I just removed the ano, and polished them)
Then I boiled some water, and threw the bag with the head inside the boiling water for 2 minutes.
When that was done, I opened the ziplock bag, and used my 2 strap wrenches to open the head.
First it didnt want to budge, but then finally I saw some movement.
I did it a little different from what I thought was the best way.
anyhow, this is how I first tried it,
and this is how I succeeded.. I used more rubber and pushed with both of my thumbs.
still the light slipped a bit, but not as bad.
and this is the result.. finally I can change the led.
I`m not sure how many times I had tried to open this thing up, but without success.
I tried to boil it before, but could get it moving with just my hands.
I put it on a boiling hot pan for a few minutes.. still didnt get it loose..
I then bought 1 small rubber strap wrench, and it still didnt work.
Then I bought 1 big strap wrench, which I thought was rubber, but it wasnt as grippy as the smaller one. so that didnt work.
Then Finally today i bought the seconds small strap wrench, and with the method described above, it finally gave way.
Yeahhh. I think I like modding again..
that P2A has been hunting me for a long time.. I just couldnt get over it... and every time I failed.
Now is my day!
if anyone wants to get it open, Put it in the Freezer for a couple of hours. Then directly in a boiling pan for a few minutes, and use 2 rubber strap wrenches.. and hopefully you`ll be as lucky as me..
