Test/Review of Windyfire 18650 2000mAh (Green)
9 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 10 min ago
DSC_5924
Official specifications:
  • Brand/model: Windyfire
  • Type of Battery: IMR 18650/2000mAh
  • Size(mm): 18mm(Diameter) x 65mm(Length)
  • Positive Shape: Button top
  • Weight(g): 42±2g
  • Nominal Voltage: 3.7V
  • Nominal Capacity: 2030mah(0.2 C Discharge)
  • Mininum Capacity: 2000mah(0.2 C Discharge)
  • Discharge Cut-off voltage: 3 V
  • Standard Charge: 0.4 A /4.2V
  • Maximum charge current: 2A
  • Quick Discharge Current: 4A
  • Max Discharge Current: 10A
  • Initial Impedance: Max:40mOhm
  • Cycle Life: 310times: discharging capacity>85%, 510times: discharging capacity>60%
  • Temperature Characteristics: -10°C/0.2C >80% Capacity; 20°C/0.2C =100% Capacity;60°C/0.2C >95% Capacity
  • Charging Time: Standard charge : 5-7hours, Rapid charge : 2-3hours
  • Operating environment: Charging, 0°C ~ 45°C ; 65±20%RH, Discharging, -20°C~60°C ; 65±20%RH
  • Storage environment: Temp(-20°c -35°c) / Relative humidity (45-75%)
Windyfire%2018650%202000mAh%20(Green)-info
A fairly low capacity cell without any high current ability.
DSC_5910
DSC_5912DSC_5913
DSC_5915
DSC_5925
Windyfire%2018650%202000mAh%20(Green)-Capacity
The cell does very good up to 7A, the curves are tracking nicely and with nearly constant capacity. This is a very good result for a 4A rated cell.
Windyfire%2018650%202000mAh%20(Green)-CapacityTimeHours
Windyfire%2018650%202000mAh%20(Green)-Energy
Windyfire%2018650%202000mAh%20(Green)-PowerLoadTime
Windyfire%2018650%202000mAh%20(Green)-TripCurrent
Windyfire%2018650%202000mAh%20(Green)-Charge
Conclusion
The cell looks to be of good quality, but the capacity is fairly low for todays batteries. If the price is low, this cell will be interesting.
This cell gets an acceptable rating.
Notes and links
Compare to 18650 and other batteries
lagman
lagman's picture
Last seen: 6 days 3 hours ago
One review everyday… You are the best!
My English isn’t perfect but I’m trying to improve it. If you see something that doesn’t sound right or is just plain wrong, please feel free to point it out! Smile
dazed1
dazed1's picture
Last seen: 8 months 4 weeks ago
Amazing amount of reviews, great job HKJ, you are a legend Smile
Fenix TK61 MOD> resistor, transistors, copper heatsink, Artic Cooling MX4, dedome, 3A > 5.7A ~ 1700 lumens > (600.000cd)
HKJ
HKJ's picture
lagman wrote:
One review everyday... You are the best!
dazed1 wrote:
Amazing amount of reviews, great job HKJ, you are a legend :)
I have a couple of old reviews laying around, the capacitors was some of them. There might be a few more during the next week.
And I do not expect any lack of reviews in the near future, I have more than 30 batteries in queue, but that will NOT be one each day.
lagman
lagman's picture
Just keep doing what you do, you are a great source of reliable information. Smile
I wish you could add some RC Lipo packs to your comparator in the futur.
http://www.hobbyking.com/hobbyking/store/__9463__Turnigy_4000mAh_4S_20C_...
http://www.hobbyking.com/hobbyking/store/__56847__Multistar_High_Capacit...
The second link is supposed to be an upgrade in power density. I would love to be able to directly compare the power density of these packs. And compare them with the best 18650, just for comparison. I did some maths calculations already (Wh/Kg), but it is much easier to compare with nice discharge curves.
HKJ
HKJ's picture
I do not have any actual plans about that, I do also believe my test equipment is on the wimpy end to test that type of battery packs (My loads can only handle 300 Watt) .
lagman
lagman's picture
Too bad, we could really use some accurate data in the RC world.
I guess you already have too much work so I understand you in a way! Smile
Thanks again!
ryansoh3
ryansoh3's picture
Last seen: 3 weeks 2 days ago
I don’t think these are true IMR, maybe some poor quality ICR cells?
Shows similarly poor performance to XXXFire cells.
BLF ≠ B-grade Flashlight Forum
HKJ
HKJ's picture
ryansoh3 wrote:
I don't think these are true IMR, maybe some poor quality ICR cells? Shows similarly poor performance to XXXFire cells.
They do not look like IMR cells, but I will not call them poor quality, they cells match way to good for that.
