Banggood Daily Deals- Banggood's Daily Deals-Yeelight 1S YLDP13YL16.99$+ WAINLIGHT C8+ 9.99$+
1166 posts / 0 new
Werner
Werner's picture
Last seen: 8 months 4 days ago
What about a deal of one of those small lights with magnetic ring like this one:
http://www.banggood.com/Niteye-EYE10-CREE-XM-L-U2-260lm-3-Modes-Magnetic-LED-Flashlight-p-81672.html
fx10a
fx10a's picture
Last seen: 6 months 4 days ago
Hi Banggood,
Can I have a code for this?
10 LED PIR Motion Sensor Light
Thank you.
alberto7
Last seen: 3 days 12 hours ago
Hi, i want to buy 4 pcs of panasonic 3400 seiko this link:
http://www.banggood.com/es/2PCS-NCR18650B-3400mAh-3_7V-Gold-Plating-Rech...
Any disscount¿?
Thanks.
Banggood
Banggood's picture
Last seen: 1 day 4 hours ago
alberto7 wrote:
Hi, i want to buy 4 pcs of panasonic 3400 seiko this link: http://www.banggood.com/es/2PCS-NCR18650B-3400mAh-3_7V-Gold-Plating-Rech... Any disscount¿? Thanks.
of course
code:FDDNCR   price:$17.5
9% discount for all flashlight & Lasers
coupon code: 4BLF
Warehouse:CN
Link: https://www.banggood.com/Wholesale-Flashlight-c-1057.html?
Business inquiry
E-mail: chendongling@banggood.com
Skype: swiling88
After Sales Problems:
E-mail: cservice@banggood.com
alberto7
Banggood wrote:
of course
Finally i buy 2 pcs. Thank you Smile
Banggood
Banggood's picture
Deal 21/7
Shadow JM35 CREE MT-G2/XHP-50 1900LM LED Flashlight 2x26650
code:5902fe   price:$38
two 26650 and longer runtime than JM35 single battery
coupon code: 4BLF
Warehouse:CN
Business inquiry
Skype: swiling88
Banggood
Banggood's picture
coupons free for flashlights,e-cigarette,lasers
coupon code: 4BLF
Warehouse:CN
Business inquiry
Skype: swiling88
will34
will34's picture
Last seen: 4 hours 31 min ago
Can this new JM35 use a single 26650?
Banggood
Banggood's picture
no, it need two 26650 battery
coupon code: 4BLF
Warehouse:CN
Business inquiry
Skype: swiling88
ahirshy
Last seen: 37 min 37 sec ago
Errm, I don’t think this is correct! I understand it still operates with a single cell, just like the previous short version. Else why would this new revision come with an optional extention tube, and not just a single long battery tube?!
Also is photographed in its short form without the extension being used. Would be a pretty rubbish backward step of it needed two cells at all times!
Hirsh
Banggood
Banggood's picture
ahirshy wrote:
Errm, I don't think this is correct! I understand it still operates with a single cell, just like the previous short version. Else why would this new revision come with an optional extention tube, and not just a single long battery tube?! Also is photographed in its short form without the extension being used. Would be a pretty rubbish backward step of it needed two cells at all times! Hirsh
I think so, but the manufacturer make the driver it is.
I think it need yours to give suggestions
coupon code: 4BLF
Warehouse:CN
Business inquiry
Skype: swiling88
BLightSam
Quote:
Please do not use protective 26650 battery for this flashlight.
Can not use 1× 26650 battery.
2 series batteries, but use only un-protected batteries!
Why cannot use only 1 battery? Can’t the extension tube taken out?
marcl
MTG2 needs 2 cells, XML2 only 1.
Marc.
Eagles may soar, but weasels don't get sucked into jet engines!
M4D M4X
M4D M4X's picture
Last seen: 13 hours 15 min ago
only a rule of thumb…
there are also boost driver (mtg 1 cell)
and buck with 2 ( or more) for xml
 all new deals are posted here:
deals.m4dm4x.com
ask MARTIN@M4DM4X.COM - i will try to save you money!
will34
will34's picture
I guess BG wants us to order to find out! Personally I don’t think it would work with a single cell even if it should being an “updated version”, I don’t see shadow developing such boost/buck driver for a $39 light.
But then what’s attractive about this version? It’s the ability to power a 6V Led from a single cell that made it interesting in the first place.
Banggood can you just simply put some batteries and try it? Thanks.
ahirshy
will34 wrote:
I guess BG wants us to order to find out! Personally I don't think it would work with a single cell even if it should being an "updated version", I don't see shadow developing such boost/buck driver for a $39 light. But then what's attractive about this version? It's the ability to power a 6V Led from a single cell that made it interesting in the first place. Banggood can you just simply put some batteries and try it? Thanks.
This model light (Shadow JM35) has always worked in the SINGLE CELL configuration. It was first launched without any extension tube option as a Single cell ONLY version for both MTG2, then XHP-50 , options. It uses a boost driver and has been reviewed and discussed extensively here on BLF. (see M4D M4X's review).
I see no reason why the new revision of the same model (just now has dual-switch and extension tube) should be any different...
Hirsh
saypat
saypat's picture
Last seen: 5 hours 55 min ago
why do you say this new offering has an ‘extension’ tube? Maybe it is only 1 piece and thus has to run on (2) cells. The specs don’t list an extension tube?
ahirshy
saypat wrote:
why do you say this new offering has an 'extension' tube? Maybe it is only 1 piece and thus has to run on (2) cells. The specs don't list an extension tube?
EDIT: Bizarrely the listing does state "Note: Please do not use protective 26650 battery for this flashlight.Can not use 1x 26650 battery."
So I don't know if they're mistaken or this is now a just badly designed light compared to the previous JM35 version!
Hirsh
saypat
saypat's picture
works for me Wink
ahirshy
saypat wrote:
works for me ;)
EDIT: Bizarrely, despite the photos (and logic!), the listing does state "Note: Please do not use protective 26650 battery for this flashlight. Can not use 1x 26650 battery."
Suppose we just need to get one to be sure... Wink
Banggood
Banggood's picture
Deal 22/7
2PCS NCR 18650B 3400mAH unprotected
code:NCR146   price:$12
2PCS NCR 18650B 3.7V 3400mAh Protected
CODE:bgf182  PRICE:$13
coupon code: 4BLF
Warehouse:CN
Business inquiry
Skype: swiling88
beam0
beam0's picture
Last seen: 10 hours 58 min ago
Bangood have you tried this with only one cell?
Has anyone got this “new version” 2-cell JM35 in MTG-2?
I would like to know if it really only runs on 2 cells or will it also run on one?
Trying to decide which version to get
http://www.banggood.com/buy/Jm35.html
beam0
beam0's picture
Dead thread??? Almost 3 months and no new deals here???
or is there a new banggood deals thread?
Werner
Werner's picture
Currently available for 7.99$
Until now all Blitzwolf were worth their price and this looks like a nice lantern…
http://www.banggood.com/BlitzWolf-BW-LT3-Multifunction-LED-Magnet-Light-Outdoor-Camping-Tent-Emergency-Night-Lamp-p-1030716.html?utm_design=39&utm_source=emarsys&utm_medium=mail_mid48_email&utm_campaign=newsletter-emarsys&utm_content=Claire&sc_src=email_1684451&sc_eh=9934b6591346351a1&sc_llid=127130&sc_lid=77896473&sc_uid=BnChhN7m7x&emst=BnChhN7m7x_127130_1684451_86?p=S32820122914201301PY
Nonaff
koyotee
koyotee's picture
Lol, that is no deal, competition sells them for 4,49$/piece
Finaly, proud owner of a Powerex Maha mh c-9000 for my Eneloops:)
fx10a
fx10a's picture
$4.49 per piece!
And I was just considering getting some NCR18650B from BG!
Am I glad that I look in here.
Koyotee, would you PM me the link?
jref3
jref3's picture
Last seen: 3 years 9 months ago
Is it just an issue on my computer or did li-ion batteries suddenly become unavailable on Banggood? Every single one I clicked shows as sold out…
EDIT: It’s a battery shipping issue – as I suspected.
1dash1
1dash1's picture
Last seen: 1 year 1 month ago
jref3 wrote:
Is it just an issue on my computer or did li-ion batteries suddenly become unavailable on Banggood? Every single one I clicked shows as sold out… EDIT: It’s a battery shipping issue – as I suspected.
Can you update your profile (My account —-> Edit) and add your location so we know which countries are having shipping problems?
I just checked the Banggood site and had no problems ordering any batteries for delivery to Hilo, Hawaii, USA.
Rule 1-1 as it applies to life, take it as it comes.
jref3
jref3's picture
Sorry, I forgot to specify my location. It seems to be affecting some EU countries.
Werner
Werner's picture
Just Seen this:
http://www.banggood.com/AMASS-T-Plug-Connector-16AWG-30cm-Charging-Cable...
Could be an easy 3.7$ DMM current measuring setup. AWG 16, just cut the connector and make a probe with a bit solder on the wire and voila.
