Look what I found in the recycle bin
258 posts / 0 new
dchomak
Last seen: 2 weeks 1 day ago
gauss163 wrote:
It is indeed true that there is little capacity left if you continue the discharge at the same rate. However, this is not what happens. Instead. the undervoltage protection disables the pack, then the voltage rebounds to its resting value. If – as for power tools – the discharge rate was very high, the voltage rebound may be fairly large, and there may be 10-20% or more capacity left if you continue the discharge at a much lower rate (which is what occurs during self-discharge). The undervoltage protection value is usually chosen so to leave adequate such residual capacity for self-discharge.
You are certainly right about that, I will not disagree.
In any case I still believe that it is the self discharge after a pack is fully depleted that is responsible for so many “like new” packs ending up in the bins. That 40V Ryobi seems to be disproportionately prevalent in the bins perhaps because they are used in “seasonal” yard tools. Just the kind of tool pack that will sit around for months slowly discharging itself during the off season.
dchomak
gauss163 wrote:
dchomak wrote:
[…] In any case I still believe that it is the self discharge after a pack is fully depleted that is responsible for so many “like new” packs ending up in the bins […]
That’s certainly possible. My point was not to dispute that but, rather, to emphasize that the residual capacity after UVP will be much higher at the much lower self-discharge rate (ditto for the low quiescent standby current of the BMS before it goes into very low power sleep mode).
I will say this, once you mentioned that bounce back effect it got me thinking back to where I compared the total discharge capacity of a cheap Carbon-Zinc AA cell versus an Alkaline.
At low current draws, 200 mA on the OPUS, the Carbon-Zinc kept bouncing back overnight and as I added each discharge session the Carbon-Zinc cell approached the total discharge capacity and probably would have exceed that of the Alkaline. The Alkaline would bounce back also, but not a much as the C-Zn
After a week of overnight rests and discharge sessions I lost interest in the experiment and didn’t continue on.
What I did learn from it though was that ordinary Carbon-Zinc cells are probably a better choice in low drain appliances such as computer mice and TV remotes.
I started the bounce back test with a drill pack, and you are right. They bounce back quite a bit overnight after the initial low cutoff at high draw. Knowing that is a relief to me as I now realize that a discharged pack is not sitting on the ragged edge of the cliff, ready to fall off.
Speed4goal wrote:
I’ve started to get picky as well. One of those 40v ryobi is the 1300mah one. The one on the right op4026 the good ones are the 4040 like on the left. A lot of the ryobi 1.3-1.5 I’ll leave there. Or take to go dig in another bin. I usually walk up with stuff so I don’t draw much attention. The only place I can dig freely is lpwes. Since I worked there for a couple years and still know some people. Best buy only ran me off once. I prefer the 2.0+ tool packs I already have like 70 1300mah 25amp lg cells from ryobi 40volt. I don’t really have much use for such low mah cells besides vaping. And hurricane preparedness.
I had been so busy, I didn’t even notice one of those 40V Ryobi’s was a 4Ah. Facepalm
After all the speculation there is no mystery as to why those three packs were in the bin.
Actually 2, one of the 2.4Ah packs charged up and works perfectly and a full capacity. I have the tools and the charger Wink
You are right, 1300mAh cells are not that useful, but functioning packs are, to me.
As for the other 2, after taking them apart I found that the 4Ah pack had all of it’s cells sitting at 3.3V
BUT
No hope to repair the BMS board, but the cells are in good shape.
The 2.4Ah pack has a similar problem. Both look as though they were standing upright and got wet. All of these cells are sitting at 2.8V Both of these 2 packs came from the same bin on the same day.
As an experiment I will clean this up and perhaps replace the FET. Even if I get it working, I will never trust it.
kennybobby wrote:
……….and you don’t have to worry about your garage catching on fire while you sleep because some salvaged cells went thermal. just sayin’
You are right! Even though that pic was shot in the garage those packs did not stay there. I put them back into my van which is parked away from the house. Until I get a chance to unload it they will stay there, then they will be moved into the shed.
kennybobby wrote:
Theoretically, if you can open the cover and manually charge up the cells directly from below the LV cutoff, it should be possible to un-brick it and use it once again in normal operation. i did this on 3 packs to test it out and they seem to be holding.
2 years ago I performed an experiment and did just that with some drill packs. All held their voltage for 1 1/2 years even though they were out there for 2 summers and a winter. They perform surprisingly well considering.
BUT I DO NOT TRUST THEM and they stay out in the shed.
kennybobby
kennybobby's picture
Last seen: 1 week 1 day ago
Those screws on the heatsink are all rusty and nasty, but i’ve repaired circuit boards that looked much worse. Alky-hawl and your wife’s toothbrush oughta clean er right up…
dchomak
Craftsman = Ryobi
With all the packs I have pulled, I have never seen a Sears Craftsman Li-Ion pack.
Today I found one. As soon as I held it in my hand I suspected it was built at the same factory as the Ryobi.
The labels on the bottom look like they came of the same press.
Same cells, FET’s and heat sink.
Similar case and parts.
This last shot is a 100% sized picture of the BMS boards. The basic boards are identical and for the most part have the same identical componets. They differ only in some features that are specific to each brand. Pads are used on one or the other depending.
Just thought it would interesting if I displayed this.
Speed4goal
Last seen: 2 weeks 2 days ago
Of the 4 ryobi packs I’ve found so far all 1.3ah cells the BMS board screws have been rusted. Looking like water damage of some sort. Testing my cells now finally getting around to tearing it down. I misplaced my t8 security bit for the bottom two screws so had to get another. Besides for high amp vaping. There not bad for testing a light you just built. They will provide low resistance and high amps for a good 5 mins. But for as edc use not gonna happen. For night lights work fine for several nights. I’m keeping them mostly for hurricane back up. I’ve given a couple away. To get people away from ultrafire batteries.
If you can use the full packs. Then the smaller mah would be useful. The one I got seemed to be working. So far all 20 cells same 3.63 volts maybe it wouldn’t charge right after water damage but 2 lights lit up on the battery charge when I pulled. I didn’t get to check today. Home depot was bogarting there bin today. Found one laptop pack at lpwes. A good one actually in frustration I damaged 5 of the 6 cells. Of course the garbage packs open right up a good one close to full mah is epoxied together.first time I’ve actually damaged the cells before besides a wrapper.
Just all the pack pulls I’ve kept over the last several months I can only imagine the 10s of millions of good cells that go to recycling yearly unclaimed. I swear I’d love to be the guy who goes and picks up all the bins in the area. After being ground zero for katrina. I’d like to be stocked up for immediate family to have a handful of lights and batteries for a couple weeks. Its usually a week or two before power comes back on. Also good to save my good cells and use these around the house.
Maybe one day I’ll find one of those 56v packs. Or some milwalkee 6.0 packs. These 1.3 ryobi 18 and 40volt are getting old. Still undecided if I’d grab one or just leave it next time. Just hate to see good cells be recycled for no reason.
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
kennybobby
dchomak wrote:
Craftsman = Ryobi This last shot is a 100% sized picture of the BMS boards. The basic boards are identical and for the most part have the same identical componets. They differ only in some features that are specific to each brand. Pads are used on one or the other depending.
Yes, that is very interesting, thanks for sharing. Would you be able to determine if the processor chip U2 has a hitachi part number underneath the white marks.
dchomak
Right your are!
http://www.datasheetbay.com/search/HA1839.pdf.html
I grab any and all of the Ryobi 40V and packs greater than 20V. I figure it out later.
That 56V 4Ah Echo looks new and 3 of 4 status lights are lit.
The Makita 4Ah pack is absolutely unused and all cells are in like new condition. I have no way to test if either pack will charge or discharge through a tool though. All I know is that the cells are in perfect condition.
This can be dangerous because sometimes people throw CFL’s in the battery bin. At this point I can pretty much tell the brand of battery by feel, just reaching in with my hand. I don’t even need to be able to see it.
Of course physical condition requires eyes on.
aarone
Last seen: 10 months 3 days ago
Sadly I don’t find anything super awesome in any of the bins in my area so I’ve not gotten picky. I’m grabbing what Li-ion packs there are.
kennybobby wrote:
Those older packs with the 1300 mah cells may not be worth the effort since they are selling the new packs online with 2200 mah cells, 20 cells for $145 is ~$7/cell delivered to your door with brand new cells in a pack. That seems really cheap and you don’t have to worry about your garage catching on fire while you sleep because some salvaged cells went thermal. just sayin’
You can get 6 of the OP4026 1300 mAh packs “broken” for $80 shipped on ebay as well. It’s not bad at $0.67 a cell if you have a use for the 1300 mAh cells. Of course I’d prefer they were free and found in a recycle bin but that’s a good cost per cell. Since the batteries carry a 3yr warranty I wonder if it’d also be possible to get a warranty swap on them without a proof of purchase just going by the mfg date on the pack and by calling customer service.
dchomak
Well I found a 3rd 40V 4Ah pack in the bin in a store in Canada. It too had been used only a few times and was tossed. When I opened it up, it also had signs of water damage?
This is 3 of 3, 4Ah packs with the same cause of failure. Could these come from the Ryobi lawn mowers and somehow get wet with use?
All cells are sitting at 3.57V, so I am hopeful that the cells are OK
It would appear the water enters via some vent holes for the FET’s
And the angle the battery sits in it’s cradle could provide an easy entry point should any moisture pool in the bottom!
Maybe a really, really dumb design.
kennybobby
It seems like they advertise them as being waterproof or something—i had noticed that dumb design also, and if the FETs get wet, short and fuse out, then they will open the low side of the pack and brick it—no way to charge or discharge after that. The average person has no choice but to just pitch it in the bin.
dchomak
I am hoping that is all that is wrong with this pack, blown FET’s.
They are easy to replace and I have done it before. Innocent
dchomak
It looks like Ryobi realized there is a problem with moisture getting inside their 40V packs.They have come out with a newly designed pack, the “OP40261”
Here is the old number next to the new.
Here are some pics of the FET-Heatsink area. There is a more massive, material wise, heatsink and NO ventilation holes.
Perhaps because battery packs have a limited run time, a more massive sink can be used in lieu of ventilation.
Note the insulated heat shield to protect the end caps of the cells. This sink must get very hot!
This is where vent holes used to exist.
The rest of the pack has been redesigned too.
I found this particular pack fully charged, but drawing more than 10A shuts it down. The “fuel” gauge doesn’t work but it will charge back up once it is depleted. Ordinarily I would think it has 1 weak cell pair that falls below the low cutoff voltage when there is a heavy draw, but that seems not to be the case here. I’ll try a heat gun on the circuit board and see if that repairs a poor solder joint somewhere.
kennybobby
thanks for posting the new pack—i had noticed the part number on the new packs for sale in the store and wondered what was the difference. Wonder why they didn’t go with the 5Ahr pack with the new design?
i had nearly finished tracing the circuits of the older design, and now they go and change. Probably a good thing since so many packs were “failing” with good cells.
i doubt they left the part numbers intact on the microcontroller and cell monitoring chips—the two quad flat pack chips. i’ll try to look them up if you can get the part numbers.
aarone
and the new packs are more of a pain to disassemble since the cells are completely enclosed in the holders which snap & screw together.
kennybobby
Different layout and orientation of the cells.
There appears to be 2 current sense locations: the central trace with the necked down section looks like a custom current sense resistor on the high side of the pack, and the fat trace at the bottom left is the current sense for the FETs at the low side.
You could try soldering some wire across the necked-down section to lower the resistance and see if the “10 amp” current limit changes.
Aaron, if you have one dismantled can you post a photo of the bottom of the board?
dchomak
kennybobby wrote:
I believe that top section you made note of is a fuse.
The fact that the fuel gauge doesn’t work to me means that it is not as simple as a poor solder joint in the high current path. I will fully discharge this pack, determine it’s capacity and then recharge it to see if anything is “reset”
Here are the numbers after cleaning the gunk off the 2 microcontrollers.
aarone
My finds from 4 bins this weekend.
2 × 2.0A Kobalt 40V, 1× 2.5A Kobalt 40V, 1× 2.0A 24V Kobalt, 4.0A Rigid pack (Samsung 20R cells)
Few assorted laptop batteries
kennybobby
Thanks for the excellent photos. Unfortunately these tool packs are kept under wraps.
The O2 Micro, ic U3, is the BMU chip to monitor the cells. i haven’t been able to get any information or datasheets on their devices, even with an email request. There is no info on the www, they are a secretive company with HQ in the Cayman Islands—great place for a semiconductor company…
The other device, ic U1, will be the microcontroller with firmware to run the board. The chip id has been hidden behind proprietary numbers. If we ever get the devices identified and pull the firmware then we will see the stupidity that they are forcing on us and bricking packs with good cells.
Check the condition of the electrolytic caps C1 and C6, that would be my first guess of leaky caps causing it to not work. i see a solder joint labelled “power”—it might be that you could remove that big glob of solder to take power off the controller, then solder it back to turn it on. Don’t know why they put so much solder on the cell voltage monitoring points—there is no significant current in those circuits.
i thought about the necked-down section being a fuse, but only if there is a mechanism to blow the fuse if the controller commands it to disable the pack. Otherwise i’m guessing it is a new current sense that is disabling your pack and the fuel gauge.
Those 40V Kobalt packs look very similar to the Ryobis—has anyone taken photos of the insides? i’m sure they will have the same patent number.
aarone
Here’s the internals of the KB 245-06
http://imgur.com/a/aWGYK
It’s unlike any other pack Ive taken apart or the Ryobi 40V packs. It appears the board is split into two and the front board with the battery gauge also has the main BMS stuff but it’s covered under a ton of goop.
The pack has space for 20 cells but only 10 are populated. It’d be trivial from the looks of it to double the pack capacity.
dchomak
I posted your pics for you.
Is that a 2.0Ah pack or the 2.5? Maybe the 2.5Ah pack has 25R’s in it.
aarone
thats the 2.5A pack. its UR18650NSX
sbslider
sbslider's picture
Last seen: 3 hours 16 min ago
Small potatoes compared to what I am seeing above, but today I pulled 12 AAA eneloop cells from the bin at work. They all light my Maratac copper AAA on high, so it seems like a good start. Not sure what to do with 12 more backup batteries yet . . .
and now I see why they were in the recycle bin. Not charging immediately with my BQ-cc17, but hoping with my RC battery charger and some power cycles I may nurse them back to some health. All I have all my AAA lights full of these batteries and they have been running for 2 hours now. Should get 4-10 hours with fresh eneloops, depending on the light. Still seeming promising. These are 2nd gen eneloops, so they could be 8 or so years old. Looked like new from the outside, no obvious wear or damage. They are marked made in Japan, and PN HR4UTGA
dchomak
Not small potatos, I found some less desirable Duracells in post 173
I had fun bringing back 4 of the 8 “exercising” the cells just as you plan on doing. I didn’t need them, but I still had fun doing it.
And it’s a learning experience.
sbslider
sbslider's picture
That was fun to read about, thanks for sharing.
I tried to charge all 12 cells in my BQ CC17, and most just gave the blinking light, the others charged for 30 minutes or less. The blinkers I put a constant 0.1A for 15-30 minutes. Now I am running them. First set of 4 ran for 2:55 in lights that would discharge them in 4-10 hours. Not bad. I charged those 4 up overnight and am running them again for 3 hours. I don’t have a nice charger like you, but so this will take a bit more time . . . but interesting for me Smile
dchomak
Today I found one of those Kobalt 40V packs in the bin. How did you get yours open. I find 4 screws on the corners. Are there others hidden under the labels?
aarone
There’s just the 4 screws and then pressure clips along the sides. I wedged a small flat blade in the top/bottom seam along the front panel (with the battery indicator). Then while putting some pressure to open the seam I ran another small screw driver along the seam until the clips popped on one side. Then just pull it the rest of the way open.
dchomak
Thanks, that’s just what I needed to know. It is always embarrassing to find after hacking something up that there was one more screw Facepalm
This pack was brand new but as it turned out all cells were sitting at exactly 0.0V.
That’s a 40A fuse on the right side of this board.
What I did get out of this find is a project case of excellent quality, and it is vented.
Also, I can use these “4 – 10 cell holders”
dchomak
I found another drill pack in the recycle bin. It appears to be brand new!
But what brand is it????
Oh, it’s one of those “No Good” brand packs LOL
Actually it is a clone of a Makita drill pack, the first one I have seen.
This will be very interesting to me, to see how they are made. Here are 2 real Makita packs with the clone in the center.
The one on the left is a brand new 4.0Ah Makita, clone in the center and an old spent Makita 3.0Ah pack on the right.
Looking at the 3 packs from the bottom reveals the brand of the clone.
The clone is an “AKPOWER”. I looked that brand up on the internet and there are many sellers selling them.
I opened the 3 packs to compare and find out why the clone pack was thrown away.
The first thing that I noticed is that there are NO balancing leads to the cells. Actually I have noticed that in earlier versions of the Makitas and reported that in this thread earlier on. With photobucket not linking those photos they are not now available.
It also looks like the BMS board is bare, devoid of any parts whatsoever.
However that is not the case, they are on the bottom.
I checked the voltage of each cell pair, there are 5, and found that one pair was sitting at 0.0V.
The reason this pack was tossed. It’s no good.
Already it is very evident that this pack is not constructed as well as an authentic Makita. But what I didn’t expect was that this 3.0Ah rated pack would actually have Samsung 15M’s in it! I was shocked!
Here are other pictures showing poor and very poor manufacturing techiniques.
As I mentioned there are no wires leading to each cell to sense their individual state of charge or discharge.
Also note the wimpy connecting tabs and spot welds. They are not up to the usual standards of authentic packs.
An authentic Makita pack on the left has a direct soldered connection to the terminal and is fused. Those are 2 – 50A fuses in parallel. This pack is capable of putting out close, but not more than 100A.
The clone on the right uses a wire that is spot welded, VERY poorly to the tab. And no fuse.
My take on this is that yes, this clone pack would work, and with authentic Samsung cells probably work quite well.
But it would not be as safe to use as an authentic Makita pack and I presume it would tend to fail at an earlier date.
allcool
Last seen: 2 weeks 5 days ago
Whats the best way to remove the spot welded strips from batteries..?
I’ve tried a few different methods but all seem to dent the battery base out, sometimes no dent, sometimes just a very little, sometimes much more. Seems to depend on how good the spot weld took… Don’t like the dent in the bottom of battery case, not sure how much it matters or not..? But would think its a bad thing for a li ion case to not keep its perfect integrity…?
dchomak
You’re right, it’s easy to dent the cells and that would not be good. The welded tabs on laptop batteries are much easier to separate, the spot welds are not as robust as the drill packs.
I use a narrow wood chisel to get under the tab and press the sharp edge against the weld joint. Then I gently wiggle it to cause a slight flex at the weld joint. After awhile the weld joint fatigues and breaks off. I am most gentle on the negative end of the cell, the positive end is easier to deal with.
I have tried drilling part way through the weld, but that is not a good way as it is VERY easy to drill too far.
DON’T do that.
