NOTE: Mod is located here.
Sami at EachBuyer asked if I would like to review a couple of their products. This headlamp was selected by him for me to review. It includes a battery pack and charger. Here are the package contents (with mouseover):
Initial Impressions:
Very nice. Best beam pattern in a bike light/head lamp I have used to date. Large hotspot, good flood, and wide spill. Hot spot isn't too defined which is a good thing for both biking and headlamp use. Appears to be a Solar Storm X2/FandyFire X2 clone.
Throw calculated to 10kcd when measured at 10 feet. Momentary swith with the following short click mode cycle: Low, Med, High, Off. A long click to go into slow flash mode from any mode.
Pro's:
- Nice mix of throw and flood. It favors flood which I desire in a headlamp. Has wide spill.
- Quite bright. The brightest I have in a stock headlamp.
- Light weight
- 3 modes (Low, Med, High) with good (but not excellent) separation
- The light stands off far enough from your head to not feel the heat. It gets hot fast on high.
- Good thermal path. The heat comes out fast. Since the light is so light weight, it gets too hot to hold after several minutes on high. Later thermal path testing indicates there is a thermal bottleneck somewhere in the light. See Cons.
- Voltage indicator lights
- Hidden slow strobe mode (about the speed of a car's hazard flashers)
- Appears to be water proof if you keep the front plate flat (don't let bend). Water resistant for sure.
- The driver seem very well regulated (see mod thread).
Con's:
- Has a thermal path bottleneck. Although the pills are pressed in nicely, my testing indicates that they or the aluminum bases are not pulling out the heat fast enough (Had significant thermal sag, but current remained steady at 2amps/emitter and exterior temp only hit 195F).
- Battery pack is heavy and awkward. Would be fine for mounting to a bike though.
- Voltage indicator lights a bit too bright. Not a problem for headlamp, but I would cover for handlebar usage.
- Charger appears to only charge to 8 volts (Maybe for safety purposes)
- Possible high parasitic drain as the bright battery voltage Indicator LEDs are always on. Unplug when not in use.
- Has no thermal protection in my testing.
- Battery pack (2P2S 18650's) is sub par. Total capacity measured about 2.2 amps and internal resistance measured an average of about 52mR.
I have not evaluated the charger or battery pack. I don't have the expertise or equipment to properly evaluate them. There is a circuit board in the battery pack the Member ledoman stated here that it probably does not perform cell bank balancing.
General Information:
Here it is with some of it's new friends. It looks a little startled by all the attention, but it soon relaxed (mouseover):
Package Contained:
1 x Headlamp with 2 XM-L's (Wired 2S)
1 x Extendable head band
1 x US charger (Input: AC 100V-240V, 50/60Hz, Max350mA, Output: DC 8.4V 1A)
2 x Rubber band (One large and one smaller size)
1 x battery (2S2P 18650) and battery holster
Current was as follows:
Low .41 - - .42 amps
Med 1.04 - 1.05 amps
High 2.07 - 2.08 amps
The battery pack has a circuit board in it. It connects to the Positive, Negative, and connection between the 2S banks. It also feeds the output wires (approximately 22 or 20 gauge). I don't know it's purpose.
The cells are not labeled and are wrapped in a baby blue wrappers. They take full voltage charges. Internal resistance and capacity tested as follows, respectively:
Cell A = 54mR, Cell B = 52mR, Cell C = 51mR, Cell D = 51mR
Cell A = 1,122mA, Cell B = 1,079mA, Cell C = 1,073mA, Cell D = 1,131mA
Connected DMM between emitters and the driver and put a lux meter in front of the light and ran on high for 10 minutes. Light on it's back on a a paper towel and no air circulation. Current ran dead solid at 2.07 to 2.08 amps the whole time. Lux dropped significantly. Light seemed to stabilize at 195 degree Fahrenheit. This means that there may be a thermal bottle neck within the light. Probably the relatively thin pill's contact with the sides of the casing.
Tear down Shots:
The "pills" appear to be pressed in fairly tight. That's a good thing. There are some versions of this light out there with no pills. Just the emitter bases resting on the casing's internal ledge.
LED leads are 24 gauge silicone wire.
This mounting system is simple and seems to do the job well. So far the headlamp has not shifted down while in use.
Front of the charger has a charge status light that is Red while charging, Yellow as completion of charge nears, and Green when charging is complete. When I put a volt meter to it, I only got 8 volts. Also, when it finished charging the pack, it was also only at 8 volts.
The driver has a couple parallel R200 resistors. It has not step down thermal protection. I does not work on one cell. Just flashed on voltage indicator LED continuously.
Switch side of driver:
Cells Uncovered (Like much of this review there are some mouseovers to save space):
The wires exiting the pack (inside the black sheath) appear to be about 22 or maybe 20 gauge.
I tried to test the board in the picture below by doing the following:
- Connected to 2 cells that were below 2.5 volts. The board did not feed power.
- Connected to 2 cells above 2.5 volts but over 1 volt different in voltage level. The board did not feed power.
- Then connected to 2 cells, both at 4.15 volts. The board did not feed power
What did this tell me? Nothing. It could be that the board permanently shuts down after an imbalance or low voltage occurs. It could be I did something wrong. I did tell me that I am not qualified to evaluate this board.
Beamshots:
The above is High mode. I will take shots of the other modes soon. It has a flasher mode that activates by pressing and holding down the mode switch button.
Conclusion:
Reminder that the charger and cells have not been reviewed here. I recommend you assume they are junk. If they turn out otherwise, it will be a pleasant surprise. With that in mind:
- As a Bike light, I like it a lot. May be better suited for on-road then off-road riding. I think one would want even wider spill for off-road.
- As headlamp, I really like it if you ignore the obtrusive battery pack. Once I replace that, this will be my go to headlamp.
