Review: Warsun CT9T (1x18650)
Warsun CT9T
Overall Rating:
Summary:
Battery:
1x18650
Switch:
Side switch
Tailcap switch, clicky
Modes: Turbo, High, Med, Low, Strobe, SOS
LED Types: Cree XM-L2 cool white
Lens:
No anti-reflective coating
Tailstands: Yes
Price: 33.99 USD (22.99 for flashlight only)
Pros
  • Good throw
  • Firm side button
  • Low battery warning indicator
  • Tailcap lockout possible
Cons
  • Sharp tailcap and bezel crenelations
  • PWM (most noticeable on Med and Low viewed through my camera)
  • Warsun 18650 cell is not 2800mAh
  • Charger wiring a concern
  • Turbo mode only lasts a minute
Contents include one power supply, Warsun 18650 cell and lanyard. According to the product page there should also be two spare orange o-rings:
Top of box is written "German Schott optical lenses":
Warsun "ICR18650 2800mAh"
Construction
Anodizing is nicer than many of my budget lights but there was a couple of bare spots, possibly factory wear.
The sharp crenelations remind me most of UltraOK ZS-2s and for me spoil what would be a really likeable light.
On weight alone I can see myself taking this instead of the XinTD X3.
Emitter is well centered:
Side switch:
Tail switch with Warsun stylized silicone boot:
Silicone power socket cover:
Since I opened the power socket cover I have not been able to get it to close again. I would suggest, if you don't ever intend to use this socket to leave it closed. (Update -- I did get it to close by pressing on it in a circular fashion)
CT9T beside C8 for size comparison:
Large orange o-rings:
Bezel:
Bezel, reflector and top part of head. Reflector is aluminium, 40.5mm long and 39mm inner diameter. Head is 48mm diameter.
Nice machining of reflector:
Aluminium star in lower part of head:
Where the battery tube joins the head threads are not anodized. There are two black o-rings to seal:
Positive terminal has an orange silicone insulating sleeve isolating it from brass retaining ring. Even with ring removed it is quite tricky to get the driver out.
Driver underneath:
Tailcap:
To remove the driver one must desolder the star and unscrew the side switch bezel. The side switch has a thick clear silicone o-ring surrounding the button which makes it harder to press (it still has click action).
This is good for users that want a switch that won't turn on easily.
Warsun driver, Atmel 24C02BN (click for hi-res):
Above the switch (right) is a red SMD LED. I tested it and it does not seem to be bi/tri-colour. Maybe this CT9T driver is an earlier version. Silicone wires are used to connect star to driver.
With driver removed (there is no centre hole, only two smaller holes for wires):
Under the star is a non-anodized area, polished and with thermal paste applied, for the best heat transfer:
This substrate is approx 2.5mm thick. A star up to 21mm can fit:
Max diameter for driver board:
Operation
The side button cycles through modes H-M-L-Strobe-SOS and the tailcap switch controls power, and with brief presses also cycles modes. Turbo mode is activated from any mode by a quick double press of the side button.
Unfortunately the CT9T cannot be turned on by the side button unless it has already been turned on first by the tail switch, then turned off by the side switch.
To turn off by the side switch one must press and hold the button for three seconds. Release a little too soon and it will change to the next mode.
Holding the side button for one second turns the light back on in the last mode, so it is possible to store a strobe and recall it, for example.
The addition of side switch does make the light a little more flexible. I do find the side button quite stiff and my thumb is a little sore from repeated pressing, but this is only from testing and in normal use shouldn't be a problem.
Also, the sharp tailcap presses into my palm a little due to the grip. This may or may not be an issue for you depending on hand size and grip.
The side switch starts flashing red when cell has reached low voltage.
Beamshots
White wall beam shots taken at 100 ISO, with auto white balance.
High mode:
Medium (approx. 33%):
Low (approx. 6%):
XinTD X3 (left) with 1A XM-L2 looks greenish next to the CT9T (right):
.<" style="width: 100%;">
I find the X3 1A tint is more yellowish than green around the hotspot to the non-adapted eye.
There is PWM on High mode but it is not as noticed by my camera as Med and Low modes.
For these outdoor shots I am using evaluative white balance and 400 ISO which seems a little more accurate reflection of the diverse range of lighting as it appears. Mouse-over for control shot.
Control:
Outdoors, it has impressive throw, and tight beam. The tree it is pointing at is 133 metres (146 yards) away:
For comparison, a XinTD X3 with XM-L2, 1A tint:
CT9T Light saber
Measurements
I tested high mode with both included Warsun cell and Sanyo UR18650FM. Capacity test of Warsun cell is 2126mAh, using 1A discharge, noteably less than the stated 2800mAh. A peek under the Warsun label reveals a blue wrapper with "1800mAh", but nothing that indicates manufacturer.
The Warsun "ICR18650 2800mAh" cell delivers slightly more current than Sanyo UR18650FM in the beginning (faint orange trace). Blue trace is infrared temperature of hottest part of the head.
Weight of CT9T with Sanyo 18650 cell inside was just under 300 grams.
Charger disassembly
I have not tested the included YH-003 charger.
Though the label says it's rated 100-240V operation the two thin leads connecting PCB to mains pins look like they can barely handle 2A and there is not enough of a gap on the PCB layout in case of a surge.
充电器 is not the maker, it means "charger".
Solder side:
Closer view of component side:
I did test the charging socket with 4.2V supplied from a Miller ML-102. It seems there is no circuit inside the CT9T to handle charging; the socket on the side connects straight to positive and negative of the flashlight/cell.
I expected the ring around the side switch to light green but there was no light during charging. An unexpected feature: the light can still be used whilst charging. In fact, I had to turn off the light when I plugged even though it was already off.
Conclusion
Despite the PWM and sharp crenelations and other quirks I find this light very likeable, thanks to internal construction, reflector shape and weight (let's forget that charger!). Next to a generic C8 it feels like a more serious flashlight, one I wouldn't feel bad about carrying (now that I've filed down the edges).
Thank you Banggood for providing the light for review! And thank you for reading! ^_^
Very nice review and the thought of you dismantling a perfectly working things shudders me :smiley:
It is one of my favorite light actually… I liked it so much over my other C8 sized varieties including Convoy L4, I bought 3 of them :bigsmile:
One of them was modded by Tom E put out over 1500 lumens is one of my favorite C8 style light :smiley:
Warsun CT9T reflector are deeper than other C8 varieties and it can out throw most if not all other C8s stock for stock
and the driver can be boosted easily too using resistor mod, too bad there’s no way to disable those annoying strobes.
I agreed the side button is little to stiff for my taste, I wonder why they changed it? the old CT9S is much softer and easier on the finger.
BTW you can also change modes using the tail cap button ( my X60 side switch button goes kaput on me and I’m still able to switch modes using the tail cap button )
Why they designed both buttons to work identically is beyond me, but one thing for sure these Warsun lights are indeed nice!
You can feel the solidness of these lights… identical feels to those of Nitecore lights ( more pricey) :smiley:
Very nice review. Will this out-throw the Convoy L4?
Nice review Chloe, I have a CT9S and like it very much, nice lights for the money.
Thanks so much for the very well documented review! :beer: :slight_smile:
I wonder if you replace or stack other resistors you can increase the current to the led…
Looks like an interesting light to have!
Thanks Chloe. Another nice review. Correct thread this time.
nice looking light. can you turn the light on and off using the side switch? or is that only to change modes?
Thanks, everyone!
You can turn it on/off by side switch, but only after turning the light on first by the tailcap switch.
Hold the side button for three seconds to turn off, and hold for one second to turn it on.
the cell looks to be a Great Power Battery, not a very high quality cell.
I think i will have to pick up a ct9t. Warsun lights for the most part are solid with good anodizing. I have the warsun mx900 find 6 and think it is a great light. I kind of like this ct9t better because it isnt as busy as the mx900 find6. Mr fang at warsun is supposed to be upgrading these lights to have a blue “on” light in the side switch, flatter anodizing and a little more output.
thanks for the review
A fast double click of the side switch should take you into slight turbo high. Also, if you are in the high mode, double click and there should be an extra 10% increase in output. Im assuming its a similar driver to the mx900 find6.
Thanks, phsinvent. I was wondering about the Turbo mode. This makes it even more likeable! :smiley:
280g! Wow, pretty beefy. Daylighter would you say this can handle heat well?
Not impressed with the battery relabeling. Thanks for the review Chloe. What country do you live in?
Thank you for the review :-)
Fantastic review Of the Warsun CT9T Chloe.
Your breakdown misses nothing and the photos are professional. I don’t think you missed anything. Just super!
One thing I noticed with mine is that the battery tube seems a little thin.
Its thick enough not to be a problem (especially considering the short length of it) but compared to solarforce lights a little thin.
The head seems nice and solid as does the tail cap.
Anyone get the accessory to charge phones with it?
I only really bought it to use as a battery bank and in the photo at Banggood they had a picture of it connected to a mobile phone.
For the price its pretty good.
Good long distance beam.
Great job, Chloe! I love my Convoy L4 but I do like that you can put this Warsun on standby using the side switch. The L4 only changes modes. Having the tail switch on the Warsun is a positive, not a negative since you can still operate the light solely using the side switch if you wanted. On the L4 you have to use both switches and it can be a bother.
Has anyone tried loading the CT9T with 2X16340 cells?
I know it worked a treat on a C8 I have, though that wasn’t running off an AMC7135 driver.
Might just resistor mod it rather than take the risk, I’m sure ImA4Wheeler has already beat me to it though :bigsmile:
Have to be careful with WARSUN multi-cell claim. In fact, I just burnt my FX900 diver last night with 2x18650 config. I got too carried away when it hit 90+Kcd with stock driver :) I have already rebuild the whole setup within a night, but I am thinking of MT-G2 with buck driver.
Sorry to hear bud, I couldn’t help myself and just tried it with one 16340 and an Eagletac 3V CR123, has given it a considerable lumen boost no doubt, now if I can only resist the urge to load it up with 2X16340 cells >)
