Just wanted to post a thread, first, to thank the community @ BLF for some wonderful content, and secondly, to maybe gain some advice. After reading some reviews, I've placed orders for the KD c8 XML from KD, and the Xtar wp6 charger and some trustfire flame protected 18650s from Manafont. I haven't received them yet, but am very excited to get a "real" flashlight, and play around a bit.
I've also ordered the L2T from solarforce, but haven't chosen a dop-in yet. I'm still doing some reading about the various offerings from the vendors, but admittedly, am a little overwhelmed with the amount of info out there. I think I'm getting the jist of all this mumbo jumbo, but am always grateful for advice from the experts.
Anyway, just wanted to introduce myself, and see what others have to say. Have I done alright so far with my purchases? This seems like a real friendly bunch, and I'm really glad I ran across you guys!!! Thanks a lot, Dave
Your purchases show you have done some reading. As far as dropins go, if you want an XML then the ultrafire three mode from manafont is well regarded. Even better is the ultrafire with strobe from manafont. No need to fear the strobe! They are the ones on manafont that show the ultrafire box in the pictures (too lazy for a link on my phone) and welcome to the joint
Thanks for the advice. I'll check out the Ultrafire drop-ins from Manafont, and likely give one a go.
With regards to the Flames, do you think they will be fine to start out with??? I'm one of those guys that think it's better to spend more if you are indeed getting a better product. I've heard some good things about the AW and Xtar brands, but just don't have the experience/knowledge to know if they're worth the extra premium.
Basically, I don't want a fireball on my hands!!! LOL
What do you guys think of this drop-in from Manafont? Comes with two reflectors, which is appealing, as it'll give me a first hand experience with the two types...
That is the dropin I have been buying. I love it. On every one I have bought so far the second reflector wont screw onto the pill. I still like getting the extra reflector though.
What is keeping the op reflector from working properly? You would think that they should work together considering they are being sold as a set... lol Have you had any luck fitting it to any other pills? or is it basically useless?
The threads just dont quite match up. The OP reflector did fit nicely on a KD dropin I have. Its like the threads are the right size but the tolerance is off too much. It's budget quality tolerances.
Great dropin though. If you get it you can come on here, talk about how awsome the strobe is and get a rise out of somebody.
Just to appease my imagination as I was reading 98dinan3's choices. Would anyone have beamshots of the Ultrafire XML T6 with OP on a P60 host (maybe the Manafont Skyray or the L2T) with a DX aspheric lens..
Any idea? Too much artifacts, even with an OP reflector?
I love your choice of hosts but I'd say go out of your way to avoid strobes .Because no matter what you do... you'll end up with a million of them anyway like it or not .Can you solder is a good question because it opens up another window of options ,tints ,drivers etc..most of which is pretty standard fare ...sounds like you're doing fine .I might have suggested choosing another emitter like the xpg ,and I might have suggested a different battery choice like a AA. but i like your pick of the solarforce l2t well enough to simply repeat what langcjl said ..looks like you know what you're doing .
*I'm sure someone out here is a real expert ....I just haven't met them yet ..Are you refering to fishinfool? :P
Welcome 98dinan3. Since you've already got the XM-L with your C8 you might get a XP-G drop-in for the L2T or a XR-E for some throw or maybe both just to see what those 3 types are like.
XM-L flood, XP-G large hotspot with some throw, and XR-E with a small hotspot and more throw!
I agree regarding the strobes! Soon you'll (probably) be avoiding them like the plague :)
I don't think you're going to like an aspheric with a reflector. You're probably not going to like an XM-L with an aspheric but that's a personal preference I suppose. Personally I only like aspherics with a XR-E.. Regarding the reflector/aspheric combo though...try it sometime as see how you like it.
EDIT: Actually I have a 6P with a XM-L drop-in (Thrunite) with an OP reflector and I have a 28mm lens from DX laying around and it's now dark here so I took all that outside to see what it looked like and how it performed.
It looks like a disco ball until you get to the reflecting of the emitter image. That image is of course larger than that of a XR-E but it didn't throw that far. It didn't throw much further than if I didn't use the aspheric. It certainly didn't throw as far as a XR-E in the same 6P using the same aspheric would have thrown.
My particular XM-L is only driven at 1.4A. One driven at 3A would throw a little further still not as far as a XR-E. 3A can get pretty warm in a small 6P anyway.
I would recommend http://www.bavauto.com/ they are right up the street from my house and they have everything you could possibly need. I think these would be the best budget light for your application.
Thanks for the detailed and quick reply.. Since I'm not a dancer, the disco ball XML is not for me..
but you're right, probably will buy an XRE R2 or XPG R5 drop in, and the aspheric lens since its so cheap, and try it.
I guess all flashaholics get that itch sometimes a lot of times, to experiment with various "legoable" parts available, just to see the result and get it out of the way.
