Test/Review of Windyfire IMR18350 850mAh (Red)
6 posts / 0 new
HKJ
HKJ's picture
Last seen: 7 hours 11 min ago
DSC_5901
Official specifications:
  • Type of Battery: IMR 18350/850mAh
  • Size(mm): 18mm(Diameter) x 35mm(Length)
  • Positive Shape: Button top
  • Weight(g): 22±1g
  • Nominal Voltage: 3.7V
  • Nominal Capacity: 880mah(0.2 C Discharge)
  • Minimum Capacity: 850mah(0.2 C Discharge)
  • Discharge Cut-off voltage: 3 V
  • Standard Charge: 0.4 A /4.2V
  • Maximum charge current: 0.85A
  • Quick Discharge Current: 0.85 A
  • Max Discharge Current: 4 A
  • Initial Impedance : Max:65mOhm
  • Cycle Life: 310times: discharging capacity>85%, 510times: discharging capacity>60%
  • Temperature Characteristics: -10°C/0.2C >80% Capacity; 20°C/0.2C =100% Capacity;60°C/0.2C >95% Capacity
  • Charging Time: Standard charge : 5-7hours, Rapid charge : 2-3hours
  • Operating environment: Charging, 0°C ~ 45°C ; 65±20%RH, Discharging, -20°C~60°C ; 65±20%RH
  • Storage environment: Temp(-20°c -35°c) / Relative humidity (45-75%)
Windyfire%20IMR18350%20850mAh%20(Red)-info
This is a IMR cell, but only with moderate high current ability, but good capacity.
DSC_5900
DSC_5922 DSC_5923
DSC_5902
DSC_5903
Windyfire%20IMR18350%20850mAh%20(Red)-Capacity
The cell does fine up to 3A load, but at 5A load it loses significant capacity.
Windyfire%20IMR18350%20850mAh%20(Red)-CapacityTimeHours
Windyfire%20IMR18350%20850mAh%20(Red)-Energy
Windyfire%20IMR18350%20850mAh%20(Red)-PowerLoadTime
Windyfire%20IMR18350%20850mAh%20(Red)-TripCurrent
Windyfire%20IMR18350%20850mAh%20(Red)-Charge
Conclusion
These batteries has good performance at moderate loads and I will rate them acceptable.
Notes and links
The batteries was supplied by Windyfire for review.
Comparison to other LiIon batteries
Edited by: HKJ on 08/17/2014 - 11:39
islisis
Last seen: 3 years 6 months ago
thanks for the review hkj Smile
850mAh at 3A looks about as good as it gets for 18350!
seems to me that for a xp-g2, xm-l2 etc two of these might supply buck regulated 5A at emitter for around 12 mins, with driver losses. longer than a 18650?
i wonder what prices these cells will come out at…
HKJ
HKJ's picture
The combination of current and capacity is good, but you can find lower capacity that can deliver more current.
Ledsmoke
Ledsmoke's picture
Last seen: 6 months 4 days ago
Nice capacity for such a little cell.
I cannot help but wonder what these retail at and from where since the recent battery shipping troubles. Time will tell though.
Thank you for the review.
~ Ledsmoke ~
Dutch humor:
[quote=djozz]
 I do not think that the BLF-community ben
leaftye
Last seen: 4 days 6 hours ago
It's good to see more IMR 18350 reviews.  Thanks for the review HKJ!
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
travis
Last seen: 31 min 16 sec ago
Windyfirecom had these for $1.68, and AW IMR’s for $1.99 !
but only payment methods are Western Union, China Bank AND
no free shipping ( shipping cost to be emailed, and DHL was default over HK post)
Boo Sad
A well regulated Militia, being necessary to the security of a free State, the
right of the people to keep and bear Arms, shall not be infringed.
