Are You On Pot????? (potting and heatsinking with epoxy and silicon carbide)
52 posts / 0 new
18sixfifty
18sixfifty's picture
Last seen: 5 months 5 days ago
Not that kind! Potting.
Do you pot your drivers?
As I have been pushing my drivers more and more and expecting more out of them I have been potting pretty much all of them. On some of these lights I'm sure it's overkill but I just like the idea of keeping my drivers safe. I really wish I had started doing this a long time ago. I am not exaggerating when I say that not potting has cost me a ton of money. I have at least a couple hundred dollars in destroyed drivers. Many of them from simply pushing them way too hard. I am convinced that some of my early disasters could have been avoided if only I had started doing this sooner.
Please chime in with your potting compounds and advice.
For me I have been using a combination of JB Weld and Silicon Carbide. I use equal parts of the JB Weld just like normal and mix in the fine grit silicon carbide until I reach the consistency that I'm looking for. The more silicon carbide I mix in the more like putty it becomes. Thicker stuff is good for molding around smaller drivers. Use less and it's good for running in and filling up areas on lights. I also use this on lights as well for adding heatsinking.
These are links to the silicon carbide and the JB Weld that I buy.
http://www.ebay.com/itm/141375753041?_trksid=p2059210.m2749.l2649&ssPage...
http://www.ebay.com/itm/110645240073?_trksid=p2059210.m2749.l2649&ssPage...
Here are some picture of the mixing process and what it looks like before and after.
It starts out a lot like making dough for bread. It really doesn't seem like it's going to mix together at all. It's all clumpy and stuff. But you just keep at it kind of mashing it up and stuff and before long it all mixed together. Keep adding more until you get it the thickness you are looking for.
One of the big things is keeping air out. I will actually roll it up a bit to make sure that the air is squished out of it before applying and after I squish it down even more to do the same.
This is a SRK driver. Yes I'm potting the driver. I also epoxy extra heatsinking material to the back of the "pill" sometimes washers or copper whatever I have that I can fit that will be as solid and conductive as possible. The entire area under the pill will be filled with copper and potting compound on this light when I'm done.
This is a 4x so those are 8 wires coming up off of a JB driver. They come up through the center of the pill. As I'm filling everything in, I slide the wires down with it. So when it's done I have the entire head completely filled with copper and potting compound. I then clip the wires, strip them and wire it up. Noctigons and XM-L2's two with domes and one without is what this light got.
How do I know it works? Well the light gets hot very fast, the heat transfer to the outside of the light is almost instant. Also the lumens stay high instead of dropping off like they would without all the extra heatsinking and potting. I have over driven drivers and killed them without potting and then done the same mods to the same driver and potted they run just fine. This makes them corrosion free, impact resistant and it's much less likely that you will burn out a driver.
So are you on Pot??
I’m a junky, I mod lights so I can sell lights so I can buy more light to mod so I can sell lights to buy more lights to mod.
Edited by: 18sixfifty on 08/20/2014 - 04:01
djozz
djozz's picture
Last seen: 4 min 33 sec ago
I do not pot my drivers, but my mods are almost always small lights with either lineair drivers that have 7135's close to the edge, or recently 105C-based FET-drivers that produce hardly any heat al all. I did extra heatsink a lineair driver once using copper rings soldered over the outer ring that drove an infrared Oslon led, because the ledvoltage was under 2V and the 7135's had to burn 700mW each.
Do you use silicium carbide because it has particularly high thermal transfer properties, or is it just a filler to get the right consistency?
18sixfifty
djozz wrote:
I do not pot my drivers, but my mods are almost always small lights with either lineair drivers that have 7135’s close to the edge, or recently 105C-based FET-drivers that produce hardly any heat al all. I did extra heatsink a lineair driver once using copper rings soldered over the outer ring that drove an infrared Oslon led, because the ledvoltage was under 2V and the 7135’s had to burn 700mW each.
I bought it in the first place just for the thermal transfer but because you can turn it into a putty it makes working with it really easy. One thing I didn’t state that I should have is that as long as you use glass and clean up right away you can re-use the same bowl over and over. I messed up one night and forgot, so now I need to make another trip to the second had store to pick up another glass bowl.
I wonder how much different this is than Arctic Silver 5? I know that arctic silver also has silicon carbide. I looked up all the numbers on the different ceramics and silicon carbide was a lot better for heat transfer than alumina that they use in arctic alumina and others. Also the hotter it gets the faster it transfers heat and over time it will transfer heat even more. I guess it doesn’t even max out until it’s been used for 200 hours.
djozz
djozz's picture
That sounds like you found the perfect stuff for potting, except for the dull colour: does JB-Weld come in fashionable colours as well? Big Smile
(I live in that part of the world that struggles to cope with the unavailabilty of JB Weld)
18sixfifty
No JB Weld? How on earth do you ever fix cars, motorcycles and snowmobiles? Wink
On the colors that's a good idea you could make a million bucks. Kinda like duct tape used to only come in grey. Between duct tape, JB weld and a hammer you can fix anything.
ImA4Wheelr
Last seen: 1 week 3 days ago
I'm a mad potter too 18650.  Even if it just pulls out a few degree, they're the most important ones to get out.  Just my opinion which may not be based on fact.
Cereal_killer
Cereal_killer's picture
Last seen: 3 months 1 day ago
I’ve yet to start potting, considered it but I just mess with the FW to much. One thing I’m thinking about is finding a tiny 5 pin M/F connector and start adding those to my lights I need to reflash a lot, then I could pot them but still be able to flash, just leave the head of the connector sticking out of the pot.
will manners
will manners's picture
I’ve seen someone pot a driver entirely with Fujik. Would it even benefit from that stuff?
I like the idea of filling in gaps to maximise heat efficiency, although it means that you are no longer able to replace or make adjustments to the potted driver.
djozz
djozz's picture
will manners wrote:
I've seen someone pot a driver entirely with Fujik. Would it even benefit from that stuff? I like the idea of filling in gaps to maximise heat efficiency, although it means that you are no longer able to replace or make adjustments to the potted driver.
anything conducts heat better than air, so Fujik will help. But while you're at it it doesn't harm to use something better and this recipe sounds good.
Ledsmoke
Ledsmoke's picture
Last seen: 11 months 3 weeks ago
Nah. But I´ve used it before but based on ordinary silicone from the hardware store and mixed in lots of the silicon carbide dust you also use.
Gives you a few hours to work with it. And it mixes quite well. I put a few drops of silicone oil in it to make the mixing better. Also seemed to keep the air out of it better.
This compound can be remowed btw. If you know you might remove it later you can spray the driver and cavity in a thin film of silicone oil before applying it. Then it is quite easy to get out.
~ Ledsmoke ~
Dutch humor:
[quote=djozz]
 I do not think that the BLF-community ben
Overclocker
Last seen: 2 years 3 months ago
djozz wrote:
will manners wrote:
I’ve seen someone pot a driver entirely with Fujik. Would it even benefit from that stuff? I like the idea of filling in gaps to maximise heat efficiency, although it means that you are no longer able to replace or make adjustments to the potted driver.
anything conducts heat better than air, so Fujik will help. But while you’re at it it doesn’t harm to use something better and this recipe sounds good.
try “depleted fujik”. spread it thinly on paper and let the paper absorb the silicone oil. scrape it off then spread again on another sheet. the consistency of putty
well there’s still convection and radiation of heat. so styrofoam is worse than air
dangerous
dangerous's picture
Last seen: 5 years 1 month ago
BLF
ImA4Wheelr
Great tip.  I will be trying this.  I've just been using my potting recipe that I have a thread on.  It's great because there is not curing time, but it's a hassle to remove.
RaceR86
RaceR86's picture
Last seen: 4 years 1 month ago
Thanks for sharing.
Do you, or anyone know of a good place to buy suitable silicon carbide with free shipping?
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
ImA4Wheelr
Here in the USA it's almost always available domestically on ebay.  Hopefully, you will have the same there in Norway.
fellfromtree
fellfromtree's picture
Last seen: 5 years 4 months ago
I compacted a pure copper scrubber in my 15 led light. It does seem to help.
raccoon city
raccoon city's picture
Last seen: 1 hour 31 min ago
You're on the pot.
Cereal_killer
What grit of silicon carbide powder do you guys use?
ImA4Wheelr
I use one that is a mix of like 220 and 4xx.  I have some 1500, but I don't use it because it goes airborne easily and I don't want to inhale it.
18sixfifty
I noticed reading up on Arctic silver 5 that they actually use different grits in their mix. I’ll be ordering more silicon carbide soon in various grits. Makes sense to mix the smaller particles with some larger depending on what you are using it for.
KawiBoy1428
KawiBoy1428's picture
Last seen: 21 min 52 sec ago
Then there is this…..http://www.pflexpro.com/ At the top of his page Flashlight 101, then to the left the list “Potting”
KB1428 “Live Life WOT
KawiBoy1428
WarHawk-AVG
WarHawk-AVG's picture
Crazy question…would sensor safe RTV or silicon and the above silicon carbide make a softer easier to remove potting for say drivers in case you needed to “peel it off”
18sixfifty
That is cool and they are right on about the potting. I also like the copper ring they use for the outside of the drop in. That is exactly what I do and it works. I can’t remember who it was on here that suggested that instead of the aluminum foil trick but they were sure right. Easy to take on and off and works perfectly. I have thought about going the extra yard and even filling that in more with potting compound but then it would no longer be a drop in at all. Still it would have some advantages depending on how hard you want to push it. I built a couple 502B’s with 5 amp dimming drivers and was tempted to pot the drop ins so they would bet even better thermal transfer. But like I said, they would no longer be drop in’s then. I did of course pot the drivers anyway.
DanielM
DanielM's picture
I didn’t know silicon carbide, a mineral, was such a good thermal transfer material.
Old-Lumens wrote:
I love modding, but I don't have much use at all for flashlights in general.
WarHawk-AVG
any material other than air is much better at moving/absorbing heat, especially stagnant air inside a pill that isn’t moving…air does “ok” if it is moving, but if it is just sitting there it really does no good at moving heat away from an object
http://www.engineeringtoolbox.com/air-properties-d_156.html
http://www.engineeringtoolbox.com/thermal-conductivity-d_429.html
http://www.ioffe.ru/SVA/NSM/Semicond/SiC/thermal.html
with mixing epoxy and silicon carbide, it still averages out much better than stagnant air
I actually put a blob of silicon over the chip on my TP4056 charger module…what I noticed was that instead of the chip getting so hot you can’t touch it at 1A draw, the entire board is now quite warm but not crazy “burn your fingertip hot” when air was the only medium to move the heat from the chip (sure if they had it soldered to a surface mount vias or whatever it would be better but the IC in that package pretty much just sits above the board and doesn’t transfer heat very efficiently), sure there is the issue of it maybe keeping the heat in, but when it diffuses the heat over a larger area, and allows the heat to soak away into the board it lowered the temperature (I’m sure there is a laundry list of calculations and maths involved…but it breaks my brain)…all fine and dandy until you put the daggum battery in backwards (no reverse polarity protection = kaput IC…dangit)
That is pretty much my real world experience with conformal coating/potting/heatsinking…
18sixfifty
It’s actually really interesting stuff. It’s man made now and it’s considered a ceramic. It has very high thermal conductivity. On the chart I was looking at it was the best of the ceramics by quite a bit. I can’t find the chart right now but this site is pretty good shows it’s properties. Really neat stuff.
http://accuratus.com/silicar.html
18sixfifty
It probably would, Also I know that you can coat the emitter first with wax so that it will peal off. Comfychair does that I think. I would do that if I had an application where I was going to be messing with the driver later. But for me, I’m done once I finish. Some people of course want to be able to flash the driver later to change modes and stuff like that.
texas shooter
Last seen: 4 hours 7 min ago
Great idea thanks for sharing. I’ve got two drivers I’ve held back on.
This also looks like a solution to a too thin LED shelf. Straws to protect the shelf holes then pot the under side to a more desirable thickness. Maybe cap off the underside with an Aluminum or Copper plate.
Tom E
Tom E's picture
Last seen: 4 hours 5 min ago
Wow, this is really helpful - 18sizfifity, thanx! I really should buy some silicone carbide and whip up a batch. This just may solve some problems - I'm thinking the hot J18's I got with the beast drivers, most of which out there seemed to have died, but I use my J18's very sparingly...
18sixfifty
Tom E wrote:
Wow, this is really helpful – 18sizfifity, thanx! I really should buy some silicone carbide and whip up a batch. This just may solve some problems – I’m thinking the hot J18’s I got with the beast drivers, most of which out there seemed to have died, but I use my J18’s very sparingly…
Thanks Tom and I never got to try it on that driver because mine died. It’s one of the first things I thought of when I started using this. Dang wish I had used in on that driver. Especially when I killed one driving 3x MT-G2. The light was sweet while it lasted and if I had potted it well it might have lived.
