Understanding the difference between Linear, Buck, Boost and Direct Drive drivers
77 posts / 0 new
wight
Last seen: 2 months 2 days ago
lagman wrote:
Ok, I agree with you. I wasn’t thinking that the VDD of the 7135 chip is powered by the MCUSmile
Smile
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
Rufusbduck
Rufusbduck's picture
Last seen: 10 months 2 weeks ago
Great read you guys!
Scott
seasam
Last seen: 3 years 6 months ago
great read. if only I had read this a few months ago. would have saved me a lot of time :bigsmile:
quickster47
quickster47's picture
Last seen: 4 years 7 months ago
What a great wealth of information. Thanks for taking the time to compile it and share it with us who are light challenged. Smile
Carl
Genesis 1:3 And God said, “Let there be light,” and there was light.
flashination
Last seen: 1 year 1 month ago
Excellent resource. Beer
'I pledge not to get drawn into cpf/blf arguments, & just understand that both places have their own merits'.
AnhTran
Last seen: 3 weeks 1 day ago
Thank you lagman for your great explanation!! I’m new to this forum and have been searching for a completed guide about flashlight driver but I haven’t found yet.
Could you draw simple circuit diagrams of some popular drivers and explain its components/ how it’s work..?
I have some knowledge in electrical physics but not in electronic components, the driver boards are too complicated to me Facepalm
DoubleA
DoubleA's picture
So will a linear regulator have better efficiency when using a IFR (LiFePO4) cell than ICR,IMR or INR since it is about 3.2V nominal?
and on the first day he said "Let there be light"...
kemakara
Quote:
Boost
This is also called a step up driver. and is part of the SMPS (link is external) (Switched Mode Power Supply) family.
It is easily recognizable thanks to the big inductor. Sometimes the inductor is black.
This is very similar the the Buck driver, but as its name implies, it will increase the voltage.
A boost converter (step-up converter) is a DC-to-DC power converter that steps up voltage (while stepping down current) from its input (supply) to its output (load). Step-up switching converters, also called boost switching regulators, provide a higher voltage output than the input voltage. The output voltage is regulated, as long as the power draw is within the output power specification of the circuit. Many of our step-up switching regulators are designed for driving strings of LEDs.
If your step-up/boost application is not power intensive (IOUT < 0.5A), you may prefer a different power conversion technology for boost applications.
joker145
joker145's picture
I would like to build a quad for solarforce with an extension tube. What driver can I use? Is it possible? Planning on buying my parts from mtn. Thank you.
The Best Revenge Is Massive Success
KawiBoy1428
KawiBoy1428's picture
Last seen: 3 hours 33 min ago
What size driver would you need? Is it a 3volt LED quad your building? Is it for a P60 drop-in type (17mm driver)? You can get a 2S 3volt 17mm driver @ 5.5amps as long as you have 6+mm of clearance for the Coil Craft Inductor from RMM.
http://www.mtnelectronics.com/index.php?route=product/product&path=67_11...
KB1428 “Live Life WOT
BlueSwordM
BlueSwordM's picture
Last seen: 9 hours 3 sec ago
@joker145, use a buck driver.
This will allow for fully regulated brightness with 2S over the course of the entire runtime.
joker145
joker145's picture
Yes 3 volt led, and a P60 drop in that I bought from Kiriba-ru
Would like to use nichia led.
joker145
joker145's picture
Thank you, also I can use one cell if needed?
KawiBoy1428
The driver I linked is the one you want. You have to go with the Coil Craft Inductor to get 5.5amps 3amps is Max for the standard inductor.
virencelights
virencelights's picture
Last seen: 17 hours 51 min ago
does a boost driver at 9Amps Turbo, go into direct drive?.
am I wrong ?.
Virence ArmyTek Viking Pro Quadtrix 9080 E21A 5700k, Virence Skilhunt H04 RC Quadtrix 9080 E21A 5000k, Virence Jetbeam AAA 9080 E21A 5000k, Virence Jetbeam AAA Nichia HCRI Red Led.
SammysHP
SammysHP's picture
Last seen: 27 min 19 sec ago
A boost driver cannot go into direct drive.
