Gearbest Daily Deal Updated: January 18th,|Yeelight YLXD50YL 470mm $104.99|208 LED Lamp $9.99|Yeelight YLXD42YL Light $87.99
5704 posts / 0 new
leaftye
Last seen: 1 week 1 day ago
Thank you for adding the coupon code for the X3 battery holder.
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
saypat
saypat's picture
Last seen: 1 hour 5 min ago
I have an XinTD V5. Will this battery carrier work in my light?
thanks…
patrick
Werner
Werner's picture
The video title says parallel battery holder….I guess that is a typo it should be serial.
Manx
Last seen: 13 hours 3 min ago
Quote:
Series 3 AA Aluminium Alloy Battery Holder Case Box for Flashlight http://www.gearbest.com/diy-parts-and-tools/pp_89760.html
It is like a 3AA to 1D battery? So it fit in a Maglite 4D? Thank you very much
www.youtube.com/channel/UCeDhMPm0L1yvr3LpygDPgMw my flashlights/knives/gear video reviews
www.absoluteblack.net my dark comics
Manx
Quote:
Nop, it’s 3AA to 26650
Yes, I’ve correct my post, was wrong, sorry
leaftye
GB's web page for that battery carrier originally said it was parallel.  They fixed that pretty quick.  Unfortunately I don't think Youtube allows titles to be changed without reuploading the video.  Since they fixed their title on their website, I think the Youtube title mistake is acceptable to leave up.
And yes, it should be series.  It definitely looks like it's series, and the version sold by another vendor is series.  It'd have to be series for it to work in the X3.
M4D M4X
M4D M4X's picture
Last seen: 15 min 3 sec ago
I am afraid it won’t fit in every 26650 light…
the diameter is 28 mm
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
leaftye
M4D M4X wrote:
I am afraid it won't fit in every 26650 light... the diameter is 28 mm
That is true.  The X3 rattles a little with a 26650, presumably because it's bored a little wider to fit the 3AA holder, which is a funny because the 3AA holder rattles a little too!
Werner
Werner's picture
It don’t will fit in a 26650 light because it’s more a D cell thickness which is around 32mm. The xintd has a inner diameter of around 31mm if I am correct.
A AA is 14mm so two next to each other are 28mm minimum, which is always more than 26mm…
I am unsure if the length will be a direct exchange for a D Cell but I will order two if these are still available in ten days or so, because 3$ is a reasonable price for a ready build adapter of good quality and will come in handy former or later.
Manx
Perfect, will wait for your experience and evaluation Smile
leaftye
A D cell is about as wide as the outer diameter of the tailcap threads on the X3.  The length of the carrier that came with the IOS version is close though, so you might be able to use it in a D/32650 light like the Lumintop SD10 or Maglites.  I'm assuming the GB carrier is exactly the same, and now I have one ordered too.
Beachlogger
Thanks Gearbest for sourcing the battery carrier, much needed and a good price too! Smile
alphazeta
alphazeta's picture
Last seen: 9 months 3 weeks ago
leaftye wrote:
A D cell is about as wide as the outer diameter of the tailcap threads on the X3.  The length of the carrier that came with the IOS version is close though, so you might be able to use it in a D/32650 light like the Lumintop SD10 or Maglites.  I’m assuming the GB carrier is exactly the same, and now I have one ordered too.
I was thinking the same thing. W/O looking up the dimensions of this carrier ur post basically confirmed my suspicions that it will run nicely as a 3aa D-sized serial cell carrier.
Thanks!
EDIT – Oops! should have read further down the thread. Apparently this carrier will be closer to C celled size.
leaftye
That depends if you trust the specs.  Remember that until yesterday it was listed as a parallel battery holder.  More than likely it's exactly the same as the battery holder that comes with the X3 from IOS.  That battery holder is 30mm in diameter, and the body is a little over 61mm long, and roughly 67mm long if the (used) spring is counted.
Manx
Ok, now I’m really confused! :~
djozz
djozz's picture
Last seen: 1 hour 33 min ago
I have build one of these and you need 31-32mm inner diameter to fit it.
ChibiM
ChibiM's picture
Last seen: 2 hours 18 min ago
They might be made a little differently, could be 1 or 2 mm wider/narrower...
it sounds like its the same as the ones shipped with the X3 at IOS.
so if someone has one of those.. he could tell us the timensions?
antiparanoico
ChibiM wrote:
They might be made a little differently, could be 1 or 2 mm wider/narrower…
I have one of IOS X3.
D:30.0mm L:61.4 (w/o spring)/~67.3mm (w/spring)
If anything can go wrong, it will.
Matter will be damaged in direct proportion to its value.
ChibiM
ChibiM's picture
Thanks!
travis
Last seen: 3 days 8 hours ago
Was trying to order a couple more of the Cofly 2AA lights—but looks like they are out of stock ( button is greyed out, not orange)
A well regulated Militia, being necessary to the security of a free State, the
right of the people to keep and bear Arms, shall not be infringed.
gearbest
gearbest's picture
Last seen: 1 day 15 hours ago
Any one interested in this Tank007 ES12 Super Mini Torch
Coupon: Tank007
price: $19.99
gearbest
gearbest's picture
Hi travis,
Thanks for your support Wink
Yes, the Cofly 2AA lights is out of stock and out of production now, there is no supply for this lights any more Sad
DavidEF
DavidEF's picture
Last seen: 1 day 22 hours ago
Coupon: Tank007
price: $19.99
Looks to be a nice light. I just recently bought an Olight i3s Eos for my wife to carry. I like the style of this Tank007 ES12 as well, and the size really is great for carrying in a pocket (or purse). This light also has a higher lumens rating than the Olight. But the Olight comes with both a belt clip (or hat clip, since it’s reversible) and a key chain with a nice clip on the end. And both lights work with 10400 cells for better performance!
- The YKK Philosophy
travis
Now the Cofly KX-D010 2 x AAa light is showing on your site as “in stock”??
( button is orange)
Did you find more of this “out-of-production” light, or is this a mistake?
gearbest
gearbest's picture
Well, another cute and small lights for gifts Santa : KLARUS MiX6
coupon: GBKLARUS
price: $40.99
gearbest
gearbest's picture
travis wrote:
Now the Cofly KX-D010 2 x AAa light is showing on your site as “in stock”?? ( button is orange) Did you find more of this “out-of-production” light, or is this a mistake?
HI travis, PM replied Wink
Woody
Woody's picture
Last seen: 3 days 10 hours ago
coupon: GBKLARUS
price: $40.99
Great price for a nice little AAA light – if I didn’t already have the Au version of this, I’d pick this one up (I’d prefer the Ti to Au anyday).
gearbest
gearbest's picture
Roche M170 with CW and NW
price: $64.99
coupon: M170
Any response? 0:)
gearbest
gearbest's picture
Woody wrote:
coupon: GBKLARUS
price: $40.99
Thanks for your kind reply though Wink
gearbest
gearbest's picture
$7.29 Shipped COFLY 898 Wink
Coupon: COFLY898
