Nitefighter L1A angle head light for $12.79
99 posts / 0 new
lekvar
Last seen: 2 years 4 months ago
I really like the looks of that. If the strobe/SOS can be bypassed, even if just cycling it on and off, I will definitely be picking one up.
southland
southland's picture
Last seen: 1 day 21 hours ago
Ordered 2 about 5 days ago and got an email 2 days ago saying they were out of stock and didn’t know when they would be back in stock.
ericandor
Seems to be almost identical to GSX 85 Lumen Angle-Head Tactical LED Headlamp reviewed at CPF.
And this one Cree Flexi CREE LED Right Angle Flashlight on Amazon, please see reviews there.
What is parasitic drain ?
djozz
djozz's picture
Last seen: 4 hours 6 min ago
ericandor wrote:
Seems to be almost identical to "GSX 85 Lumen Angle-Head Tactical LED Headlamp":http://www.candlepowerforums.com/vb/showthread.php?379686-Real-World-Rev... reviewed at CPF. And this one "Cree Flexi CREE LED Right Angle Flashlight":http://www.amazon.com/Cree-Flexi-Right-Angle-Flashlight/dp/B008MPTLAK/re... on Amazon, please see reviews there. What is parasitic drain ?
The GSX is said in the review to have a terrible pwm on low, while I can not detect any in this one.
The parasitic drain I just measured at 60 micro-ampere
link to djozz tests
“I used to think that top environmental problems were biodiversity loss, ecosystem collapse and climate change. I thought that thirty years of good science could address these problems. I was wrong. The top environmental problems are selfishness, greed and apathy, and to deal with these we need a cultural and spiritual transformation. And we scientists don’t know how to do that.”   (Gus Speth)
ericandor
How about overheating mentioned on amazon ? (link to review)
Quote:
… The only flaw is that it overheats or something if you leave on for too long on bright. It gives out and just won’t stay lit, granted it takes a while to get to that point, but I’ve done it more than once. It takes an extended cool down period, and no it’s not a dead battery. …
BTW. Is there a formula to translate CPF rating to BLF one ? Smile
djozz
djozz's picture
I do not see how a light can overheat on a single alkaline/NiMh battery: the driver struggles to boost the voltage and the output will not easy get over 100 lumen. The light will not be hotter than luke-warm and to kill the led it must have no heatsinking at all.
link to djozz tests
djozz
djozz's picture
I really tried to get the reflector/ledboard out now and did not succeed. Either it requires so much brute force and heating up that destroying the light is likely, or I missed something on how the light is constructed. Is someone else more skilled/lucky?
I measured tail current on a mostly full Duracel (actually the one that came with the light): 1.35A, after boosting I guess there is not more than 300mA leftover for the led. The output on high is about 80 lumen, on low 13 lumen. On an Eneloop the tail current is 1.4A on high, 180mA on low, output is 90 lumen on high, 12.5 on low. (It suggests pwm after all, the efficiency on low is not much better than on high, but this statement is not backed up by any decent calculation).
link to djozz tests
ericandor
I doubt that amazon guy made up that story, he stated that it worked again after it cooled down, so it sounds to be about the heat, maybe just cold solder joint… (no word there about killing the LED).
Regarding LED current, I have seen 350mA mentioned somewhere, but I do not remember where…
djozz
djozz's picture
ericandor wrote:
I doubt that amazon guy made up that story, he stated that it worked again after it cooled down, so it sounds to be about the heat, maybe just cold solder joint... (no word there about killing the LED). Regarding LED current, I have seen 350mA mentioned somewhere, but I do not remember where...
Perhaps something was wrong with his copy. I just ran the light for half an hour on an Eneloop XXXX, the flashlight hardly warmed up, after that the output had gone down from 90 to 76 lumen. I let it cool down for 8 minutes, then switched it on and got 79 lumen. Nothing drastic going on with temperature in my copy.
link to djozz tests
ChibiM
ChibiM's picture
Last seen: 5 hours 38 sec ago
Thanks Djozz for all the pics and info...
Pity, as I hoped it to be a bit easier to replace the Led..
ericandor
How is headband clip?
Quote:
… As you can see the clip to the headlamp strap broke after removing the installing the light in the same positon on the strap. …
(link)
djozz
djozz's picture
Quote:
... As you can see the clip to the headlamp strap broke after removing the installing the light in the same positon on the strap. ...
("link":http://laserpointerforums.com/f66/what-lights-do-you-have-52220-33.html#...)
Well, it did not break yet...
But it sure looks like it could break at some point, it is plastic and it is used to clamp something, not the most robust solution I can think of. But then, it could just work fine for years..
link to djozz tests
ericandor
djozz
djozz's picture
ericandor wrote:
Will that one do? "FT: Headlight Mounting Strap for 18650 Flashlight":https://www.fasttech.com/p/1258004[/quote]
That one will probably be too wide, I think a simple one like this will work fine for this small light:
http://goinggear.com/klarus-headband.html
link to djozz tests
hank
hank's picture
Last seen: 1 week 3 days ago
Thanks djozz.
So — easy to get the driver and switch out (and so to mod them and get them back in?)
Waiting and hoping on the LED result; as the reflector is deep — WOW, from your picture, the reflector goes all the way to the back side of the head with the LED at the back wall?!
Could all that space be used for a slug of copper, to raise and heatsink a better, floody emitter?
Heck, I’d be happy without a reflector, full flood — tho’ I wonder if a little aspheric could be found and positioned in place of the lens, or a Carclo-type optic. Are there threads at the reflector socket or just press fit?
Very tempting already. One ordered.
(I’ve got a couple of Z1s, a Z2, and a Moon M6 — none reasonably moddable, plus the one I destroyed trying and passed on)
Beachlogger
Mine showed up and it also has a glued in reflector, also a big halo around the hot spot, this needs some kind of a diffuser or something to blend the lights together, has a pretty cheezy headband holder and a narrow headband,but for the price it’ll make a ok light for working on the car, oh yah one more thing, the battery tube is really thin
mrmatt
mrmatt's picture
Last seen: 5 days 6 hours ago
Just got mine as well. The driver works like this:
High-Low-SOS-Strobe-Off (SOS and Strobe may be switched, I didn’t pay attention)
If it is left on a mode for 3 seconds, then the next click will be off, so it is possible to skip all the blinking modes. I also did not notice any PWM (I consider myself sensitive to it and always check).
I like the finish on the light, matte and feels good, not sure how it will wear but I didn’t see any blemishes or scuffs.
The spot is small with a ring around it, it would be better suited with a bigger die, a (more) OP reflector, or diffuse lens.
I consider it a great buy for $12, gave mine to the wife since she didn’t have a right angle or headlight so I might get another one.
lakemonster1
Last seen: 11 months 2 days ago
I ordered one of these today. I can’t wait.
lekvar
I finally took the plunge too. The last budget angle light I bought has some issues, I’m hoping this one’s better.
sandanbob
Last seen: 7 hours 25 min ago
There are definite rings in the beam, but the output is good for my purposes. While walking, the light holder will pivot, so the light starts to point more down than wished. I turned the band over, and rotated the light to counter that. For the money, I like it.
hank
hank's picture
First thing it needs is a diffuser; very ringy as noted.
Feels like solid hardware though, fairly thick wall, smooth threads feel ok.
Glad Djozz already pulled his apart so I don’t have to do that just out of curiosity. I’ll wait on someone else to mod it; typical blue-white emitter is the next thing that needs replacing.
And of course it’s hi/low/strobe/sos.
No-mode-memory — it reverts to high each time it’s left shut off, that’s tolerable.
Of course I wish for moon/l/m/h; that’ll be a mod later, I hope.
lekvar
I’m really liking mine so far. Battery life seems good, and it’s nice and floods for close work. No PWM that I can notice, and it feels nice and solid in the hand but light in the headband. A lower low in addition would be nice, but For the price I’m satisfied.
apt323
apt323's picture
Last seen: 9 hours 24 min ago
anyone do any mods to this yet?
Beachlogger
Your post reminded me how much I hate the ringy beam so I just stuck a piece of 3m removable tape over the lense and cut around the circle with a razor and it made a real nice blended beam Smile
lakemonster1
I’ve had mine for a week already. The beam is really ringy but the light serves its purpose and is much more comfy than the energizer one It replaced. I’m happy.
lekvar
It’s definitely ring-y when you shine it at a wall but I’ve been using mine pretty consistently over the past week, mostly for close work, and I never noticed it and it certainly didn’t cause any problems. I got the Cofly angle light a while ago and it has bad PWM and whines on low. This two bucks more but a better light (though I really like the bendy neck on the Cofly).
lakemonster1
Yeah, I’m not really worried about the beam being ringy. It doesn’t bother me. Its a nice little light for the price.
Boaz
Boaz's picture
Last seen: 15 hours 59 min ago
It is bad enough that it was begging for a bit of diffuser material stuck onto the lens but  ringy really isn't a problem when you find good diffuser material  you actually learn to appreciate the throw .Flood is easy to create .. throw is impossible to create out of a floody light .Just add 2 cents worth of material and the beam is smooth as a babies butt .
If the plastic piece ever breaks you can always buy a silicone holder for a few bucks . < even zebralight sold them cheap.
a better tint with higher cri would be nice  but for the price it's a good headlamp option
ericandor
I have just received mine, headband clip broke after first use…
Is there a cheap headband worth trying ?
I would prefer not to pay 50% of flashlight price for headband..
bikenber73
bikenber73's picture
Last seen: 2 days 2 hours ago
My clip broke after first use as well and I am kinda disappointed withe the ringy beam pattern. The fit and finish is great but the output is meh!
