How to see if a battery is protected
51 posts / 0 new
light-wolff
Last seen: 16 hours 13 min ago
Allmaybe wrote:
Will the added protection board cause difference in diameters?
Some (like Soshine) have their protection on the positive pole and only one wrapper layer. Such cells have the same diameter as unprotected cells.
mattjk
mattjk's picture
Last seen: 10 hours 28 min ago
Want to see if its protected? Short it with 10 gauge or similar cable if it gets really hot or blows up its probably not protected. If it does nothing it probably has a protection circuit.
Hunter
Last seen: 1 month 1 week ago
Shocked
or just send them to mattjk so he could test them by shorting + a – !!!
If he answers after testing = its protected,
if no answer for 24 h or more = it’s not protected and he is in hospital waiting for skin grafting…
light-wolff
Unprotected cells with PTC won’t heat up cables because they limit short circuit current (but I don’t know what “10 gauge” means).
mattjk
mattjk's picture
gauge (AWG) is the measure the yanks use for the cable size. 10 is good for about 50 amps depending on length
And yes i was obviously kidding!
Dimbo The Blinky
Dimbo The Blinky's picture
Actually, Sony did that when they were conducting the required Engineering Testing when they invented these batteries. Not with wire, but with a “dead short rig”.
Those early batteries must have been made better than the “modern” ones, since all they did was discharge to some low-low voltage & get hot.
So, all the fear-/belief-based hype and hysteria is great fun, but reality has a tendency to be far more boring.
“There is no darkness but ignorance.”
HKJ
HKJ's picture
Last seen: 6 hours 51 min ago
You forgot “vent”, this will often happen when batteries gets hot and it is only a problem if there is a spark.
Dimbo The Blinky
Uh, no, I merely quoted their publication of their results. And they also recorded the actual highest temperature (I would say “QUITE hot”) and the fact that there was no venting or bulging or other failure.
The only evidence I can find of “venting” (with or without flames) is on youtube videos, where the actual rigs used to create the desired result are poorly or falsely “documented”. Which is why your measurements, HKJ, are so vital to posterity.
HKJ
HKJ's picture
Usual tests are passed with “no flames and no explosion”, i.e. venting is acceptable.
I have had a few batteries vent during test when they got too hot and when I notice the venting I include the information in the review, but my guess is that I have missed some vents (They are not dramatic in any way).
I forgot to say: Except if they happens in a airtight flashlight.
Allmaybe
Allmaybe's picture
Thank you for explaining.
For quicker, easier and safer charging.
www.allmaybe.com
https://www.facebook.com/allmaybeCN
amycheung
amycheung's picture
Last seen: 2 years 1 month ago
Awesome …thank you so much HKJ!
amycheung
amycheung's picture
light-wolff wrote:
Unprotected cells with PTC won't heat up cables because they limit short circuit current (but I don't know what "10 gauge" means).
Here is more information of gauge and voltage drop for your reference.
huntking
Very professional post. I learn.
Ultrafire.Spain
Ultrafire.Spain's picture
Last seen: 1 year 4 months ago
Hola a todos
Iniciamos nuestra aportación en este foro.
En principio si se nos permite lo haremos en Español para los usuarios de habla hispana y el ingles
Conocéis las nuevas baterías de UltraFire?
Estas a diferencia de las tradicionales protegidas, el PCM/BMS de protección se encuentra en el polo positivo, la ventaja es que esta ya no tienen la típica cinta de cobre que conecta el polo positivo con el PCM.
Hello everyone
We started our contribution in this forum.
In principle, if we are allowed, we will do it in Spanish for Spanish-speaking users and in English
Do you know the new UltraFire batteries?
Unlike traditional protected PCM / BMS protection is in the positive pole, the advantage is that they no longer have the typical copper ribbon that connects the positive pole to the PCM.
Nos presentamos. UltraFire España s.l. Estamos en España en la provincia de Alicante
Tenemos una plataforma de presentación y venta de productos. www.ultrafire.es
Somos distribuidores de la marca UltraFire para Europa
Nuestra intención es poder llegar a todos los usuarios de habla hispana en el mundo.
Informar de las novedades de la marca y denunciar las falsificaciones que habitualmente se vende en Europa.
Gracias por dejarnos participar en este foro.
snakebite
snakebite's picture
i doubt anyone here cares about ultrafire batteries with blatant lies on the label.
other than to point at them to show others what to avoid.
Jack Kellar
Jack Kellar's picture
Last seen: 1 hour 38 min ago
Pretty much, yes.
JacksonMiller
JacksonMiller's picture
Thank You for information
firedome
Great info! Thumbs Up
“We can easily forgive a child who is afraid of the dark; the real tragedy of life is when men are afraid of the light.
-Plato
giaancona315@gm...
giaancona315@gmail.com's picture
Wow! Thanx for sharing info! I friendly want to recommend you a website check it out that inspired me to play golf. Wishing you a good day and inspiration!
ActiveAl
ActiveAl's picture
Last seen: 5 hours 40 min ago
Thanks HKJ. I've gone through this post twice. But since I am a slow learner, I and will probably come back again!
