Jax Z1 XP-G2 S2 dedomed @5A
47 posts / 0 new
Kenjii
Kenjii's picture
Last seen: 10 months 2 days ago
Hy,
after reviewing this little flashlight i decided to do some modding with the Jax Z1. The stock Z1 was measured at 43 Kcd so i was sure that there is some room for improvement.
I used the LCK 5A Driver which is powerful and should fit the pills diameter. Bad luck, the driver fits in diameter but not depth.
So i measured the length of different batteries to check, how much space i can loose and the batteries still fit. After i checked that i was sure, that the space left should be ok for unprotected cells. To save space i didn´t use a spring. So i potted the driver with Fujik thermal adhesive on the inner side and took epoxy for the outer side to the batteries. This was pressed together with a clamp to the size i needed.
LED change to XP-G2 S2. Nothing special.
As the LED was not centered perfectly i did that again using the original centerring combined with an XP-G2-XM-L adapter. Now it sits perfect in place.
I removed this centerring after the LED was changed as it produced some ugly rings in the spot. After that the ring was gone but another ugly “shadow” showed up. Only visible up to 1,5 metres but i want to remove that later.
After the mod only unprotected cells fit. I use 2x AW 18350 for a runtime of about 10 minutes Big Smile The body gets warm now really fast.
I measured Lux from 6 metres at 6350 Lux. That´s calculated to 1m 228.600 Lux@1m/Cd or 946 metres range (ANSI).
Beamshots
Distance to target 254 metres, Nikon P100 f=3,2, 2 Sec., ISO400.
Control Shot
Jax Z1 XM-L2 @3A
Jax Z1 XP-G2 dedomed @5A
That´s a beam i can work with 8) The color is neutral nothing greenish. Now i like this little flashlight even more.
Greetings
Kenjii
Edited by: Kenjii on 09/18/2014 - 06:22
MRsDNF
MRsDNF's picture
Last seen: 16 hours 13 min ago
Wow. What a difference. Looks like your trying to sear a hole through the building. Thats interesting to hear about the tint after dedoming.
Xandre
Xandre's picture
Last seen: 1 day 4 hours ago
WOW !!!
Good job Kenjii and the pictures are great.
Xandre
djozz
djozz's picture
Last seen: 1 min 57 sec ago
Nice! Smile
I would not mind knowing the led-current, but that is different from tail-current with a buckdriver, so not easy to measure Sad
Kenjii
Kenjii's picture
Hy,
my multimeter is crap. Volts are ok to measure but Amps are not accurate. But i think 5 Amps to the emitter are realistic.
Theory: 43 KLux (Original) x 1,6 (XP-G2) × 1,9 (dedome) x 1,6 (5A) = 209 KLux.
Greetings
Kenjii
djozz
djozz's picture
Kenjii wrote:
Hy, my multimeter is crap. Volts are ok to measure but Amps are not accurate. But i think 5 Amps to the emitter are realistic. Theory: 43 KLux (Original) x 1,6 (XP-G2) x 1,9 (dedome) x 1,6 (5A) = 209 KLux. Greetings Kenjii
Smile Thanks, I like this type of calculation Smile
Tom E
Tom E's picture
Last seen: 13 hours 48 min ago
Nice mod and good results! Good to know how it does with a hot setup. I'd prefer a FET based driver for single cell use though, but your setup would be great for a pair of good 26650 cells w/extension tube.
Legolas Jr.
Legolas Jr.'s picture
Last seen: 16 hours 44 min ago
Sweet mod! I’m jealous now!
“Strive to be a warrior and a scholar. Be forged in fire and tempered by knowledge. If not, you will either lack the courage to fight for your ideals or lack ideals worth fighting for.”
nofearek9
nofearek9's picture
Last seen: 1 hour 13 min ago
nice mod ,great thrower.
lionheart_2281
lionheart_2281's picture
Last seen: 3 hours 56 min ago
Vinh HAS to do a run of these with the XPG2, what a fantastic mod, well done
downlinx
downlinx's picture
wow, amazing mod kenjii, maybe i will send you mine, hehe
BLF Community Battery Pull Thread http://budgetlightforum.com/node/32720
ImA4Wheelr
Last seen: 3 weeks 2 days ago
Nice work.  That final beam shot picture is cool.
Kenjii
Kenjii's picture
Tom E wrote:
Nice mod and good results! Good to know how it does with a hot setup. I’d prefer a FET based driver for single cell use though, but your setup would be great for a pair of good 26650 cells w/extension tube.
You mean like this? Smile
I already have a second one for our man in Amsterdam (not djozz). But this time i am going to take the most powerful one. When modding the Thrunite Catapult he got the better one.
Greetings
Kenjii
Cereal_killer
Cereal_killer's picture
Last seen: 1 week 3 days ago
Does the head twist or slide?
Great work, I always like seeing the red threw aspheric’s.
JohnnyMac
JohnnyMac's picture
Last seen: 2 years 3 weeks ago
I absolutely love the look of that light in shorty mode.  Next time use the FET driver in it. Cool
Kenjii
Kenjii's picture
Twist. And very smooth, too.
djozz
djozz's picture
Hi Kenjii, I did a similar mod on the Uniquefire UF-1406 (here) and I am curious about how they compare. Are you able to measure the output (in lumens) of the modded Jax at zoom-in and zoom-out?
lionheart_2281
Kenjii
Kenjii's picture
Hy,
no unfortuantly i can´t measure lumens. Never did ceiling bounce, too. I am only interested in Lux/candles Smile
Yes, i saw the Z1vn but i don´t think they will be comparable to mine as Vinh uses a single cell driver, so it will be almost impossible to reach stable high currents. MT-G2 and SBT-70 are nice but i think they might produce too much heat for this host.
Greetings
Kenjii
Kenjii
Kenjii's picture
Hy,
the second Z1 for our man in Amsterdam is finished. Both lights perform almost identically. Measured 225-228 KLux/Kcd.
Greetings
Kenjii
Beamshot slightly overexposed due to foggy weather Wink
Ervin Anastasi
Ervin Anastasi's picture
Last seen: 3 years 10 months ago
cool beam shot and great work.
some of my actual experiments and reviews:
UF-T20 review and mod —->http://budgetlightforum.com/node/30186#node-30186
My EBRZM, over 1 million cd thrower—-> http://budgetlightforum.com/node/30274#node-30274
Ervin’s try (2nd. Annual BLF Scratch Made L
Kenjii
Kenjii's picture
Now listed as Host-only: Jax Z1 Host
and the Lens: Jax Z1 Lens
Beachlogger
Last seen: 1 month 1 week ago
Wow, love that last pic
ToyKeeper
ToyKeeper's picture
Last seen: 1 hour 23 min ago
Hi, er, when taking the Z1 apart, did you have any trouble getting the pill out?
I’m trying to unscrew the pill, or unscrew the black retaining plate at least, and it gets really stuck after about one turn. I managed to bend my tools trying to get it to turn farther.
At a guess, it looks like the black plate might be glued onto the pill or star, and might perhaps have different threading than the pill. So, they turn in sync. It turns easily at first, but rapidly gets difficult and stuck.
So, I’m looking for advice on getting past that, to get the pill out.
Kenjii
Kenjii's picture
Hy,
i had no problems taking out both parts. There was no connection between pill and black plate. I could unscrew the black plate by pressing it with two fingers. Threads are surely different but as i said there shouldn´t be a connection between pill and plate. Perhaps the centerring ring on the LED is stuck at the plate?
Regards
Kenjii
ToyKeeper
ToyKeeper's picture
It’s too bad I ordered this just a few days before the host version was released.
It seems like the pill, star, and black plate are pretty solidly glued together. I’m hoping I can let it sit in the maximum-unscrewed state for a while to stretch the glue, unscrew it a little more, stretch, unscrew a little more, etc… and eventually get the pill out. With any luck, doing this will actually stretch the glue instead of compressing it…
I had heard that the MCPCB was glued on with something pretty strong, but I wasn’t expecting the black plate to be stuck too. Glue is a lot easier to deal with after the pill is out.
Kenjii
Kenjii's picture
Hy,
my Z1 is now running with the LED4Power LD-1 5A Driver and an Efest Purple 26650. Short, strong, good runtime Wink Measured at 212 KLux@1m/Kcd.
Greetings
Kenjii
Xandre
Xandre's picture
Our man in Amsterdam give it to me.
Will try with LD1 and a Photon Collar (Aluminium)
Thanks Kenjii
bibihang
bibihang's picture
Last seen: 2 weeks 5 days ago
That looks very neat, Kenjii.
ToyKeeper
ToyKeeper's picture
I got an empty host and put it together with a de-domed XP-G2 and BLF22DD driver. However, the optic is slightly deformed (right in the center) so it gets lower throw than it should. With the battery at 4.10V, it clocked in at only 173 kcd. I assume it would be higher with a totally full cell, but it’s still lower than expected, and I can see a weird asymmetric blob to one side of the beam while focusing it.
So, I may see about getting another optic. It’s still pretty good as-is, just not as much as I expected.
LinusHofmann
LinusHofmann's picture
Oooh that looks like a very tasty Zoomie/Aspheric thrower. Tempted to pick up the host and do some tinkering, I like the look of the coated lens as well.
Interesting stuff! Thanks for posting.
